Certificate number: 13965/D1 BV
File number: ACI4000/032/006
Product code: 5300H
PIPE, CABLE, DUCT PENETRATIONS IN FIRE DIVISIONS
A-class Single-Cable and Multi-Cables sealing system with multidiameter technology, R series frames
A-class Single-Pipe and Multi-Pipes sealing system with multidiameter technology, R series frames
SOLAS 74, as amended, Regulations II-2/9
IMO Res. MSC.307(88) (2010 FTP Code)
IMO MSC.1/Circ. 1488
IMO MSC.1/Circ. 1276
This certificate will expire on: 30 Mar 2025
At BV COPENHAGEN, on 22 Feb 2023,
Hans-erik ERICSSON
signature
| BV Mod. Ad.E 530 June 2017 | This certificate consists of 7 page(s) |
1. PRODUCT DESCRIPTION:
1.1 - A-Class Single-Cable and Multi-Cable sealing system with multidiameter technology, R series frames
(including EMC and Ex versions)
Consisting of Roxtec R-series frames (standard, EMC or Ex), filled with Roxtec RM modules (standard, Ex or EMC, PE, ES,
BG, BGB), mounted in sleeves that are welded or bolted (depending on the type of sleeve) or attached through expansion (R X
kit) onto steel divisions.
Additional insulation on penetrations and/or cables:
- should be approved as having the same level of performance as the penetrated division and expected classification of
penetration,
- is to be fitted as shown in the referred Manufacturer’s drawings (see §2.1 & §2.2) and also according to Manufacturer’s
insulation guidelines.
1.1.1 - Standard and extended length (400 mm) SL R sleeves (for welded mounting)
| Division | Bulkhead | Deck |
| Penetration sizes | R50 to R200 | R50 to R200 |
| Length of sleeve (mm) | 55 | 55 |
| Depth of the penetration (mm) | 71~75 | 71~75 |
| Overall outer diameter of the penetration (mm) | 60 to 215 | 60 to 215 |
| Packing space (mm) | 30 x 30 ~ 120 x 120 | 30 x 30 ~ 120 x 120 |
| Max. cable diameter (mm) | 90 | 90 |
| Filling ratio | 0 ~44% | 0 ~ 44.2% |
| Classification | A-0 to A-60 | A-0 to A-60 |
1.1.2 - SLF R sleeves (for bolted mounting)
| Division | Deck |
| Overall outer diameter of the penetration (mm) | 60 to 115 |
| Max. cable diameter (mm) | 47 |
| Filling ratio | 0 ~ 19.3% |
1.1.3 - SL A sleeves (for bolted mounting)
| Penetration sizes | R50 to R100 | |
| Length of sleeve (mm) | 55 | |
| Depth of the penetration (mm) | 71~75 | |
| Overall outer diameter of the penetration (mm) | 60 to 115 | |
| Packing space (mm) | 30 x 30 ~ 60 x 60 | |
| Max. cable diameter (mm) | 47 | 50 |
| Filling ratio | 0 ~ 48.2% | 0 ~ 54.4% |
1.1.4 - SL X sleeves (R X kit)
| Penetration sizes | R70 to R200 | R75 to R200 |
| Overall outer diameter of the penetration (mm) | 85 to 215 | |
| Packing space (mm) | 40 x 40 ~ 120 x 120 | |
| Max. cable diameter (mm) | 67 | 83 |
| Filling ratio | 0 ~ 28.3% | 0 ~ 37.6% |
1.2 - A-Class Single-Pipe and Multi-Pipe sealing system with multidiameter technology, R series frames
BG, BGB), mounted in sleeves that are welded or bolted (depending on the type of sleeve/pipe) or for steel pipes only, attached
through expansion (RX kit) onto steel divisions.
penetration,
1.2.1 - Standard and extended length (400 mm) SL R sleeves (for welded mounting)
| Pipe | Steel | Cu/CuNi |
| Division | Bulkhead/Deck | Deck |
| Length of sleeve (mm) | 55 | 400 |
| Overall outer diameter of the | ||
| 60 to 215 | 60 to 215 | |
| penetration (mm) | ||
| Pipe outer diameter (mm) | 6-95 | 6-54 |
1.2.2 - SLF R sleeves (for bolted mounting)
| Pipe | Steel or Cu/CuNi |
| Division | Deck |
| Pipe outer diameter (mm) | 6-54 |
1.2.3 - SL X sleeves (RX kit)
| Pipe | Steel |
| Depth of the penetration (mm) | 71 |
| 85 to 215 |
penetration (mm)
| 6-54 (bulkhead) |
6-95 (deck)
2. DOCUMENTS AND DRAWINGS:
2.1 - A-Class Single-Cable and Multi-Cable Sealing System
As per the Manufacturer’s installation/insulation drawings:
2.1.1 – Standard SL R/SLF R and extended SL R sleeves:
| - “R-frames with cables - A-60 steel deck/blkhd”: | N° S1585348 Rev.A dated 07/11/2022 |
| - “R-frames with cables - A-15 & A-30 steel deck/blkhd”: | N° S1552370 Rev.A dated 13/02/2020 |
| - “R-frames with cables - A-0 steel deck/blkhd”: | N° S1585555 Rev.A dated 07/11/2022 |
| - “R-frames with cables and extended sleeves - A-60 steel deck”: | N° S1586603 Rev.A dated 02/12/2022 |
| - “R-frames with cables and extended sleeves - A-0 steel deck”: | N° S1586604 Rev.A dated02/12/2022 |
| 2.1.2 - SL A sleeves: | |
| - “SL A sleeve with R-frames and cables - A-60 steel blkh/deck”: | N° S1582396 Rev.A dated 22/08/2022 |
| - “SL A sleeve with R-frames and cables - A-15 & A-30 steel blkh/deck”: | N° S1523902 Rev.A dated 15/06/2017 |
| - “SL A sleeve with R-frames and cables - A-0 steel blkh/deck”: | N° S1582399 Rev.A dated 22/08/2022 |
| 2.1.3 - SL X sleeves (R X kit): |
- “RX, R-frames with SLX sleeves and cables - A-60 steel deck/blkhd”: N° S1552146 Rev.A dated 13/02/2020
- "RX, R-frames with SLX sleeves and cables - A-15 & A-30 steel N° S1552154 Rev.A dated 13/02/2020
deck/blkhd":
| - “RX, R-frames with SLX sleeves and cables - A-0 steel deck/blkhd”: | N° S1552147 Rev.A dated 13/02/2020 |
2.2 - A-Class Single-Pipe and Multi-Pipe Sealing System
2.2.1 - Standard SL R/SLF R and extended SL R sleeves:
| - “R-frames with steel pipes - A-60 steel deck/blkhd”: | N° S1582060 Rev.A dated 22/08/2022 |
| - “R-frames with steel pipes - A-0 steel blkhd”: | N° S1582064 Rev.A dated 06/02/2023 |
| - “R-frames with steel pipes - A-0 steel deck”: | N° S1582061 Rev.A dated 09/08/2022 |
| - “R-frames with steel pipes and extended sleeves - A-0 steel deck”: | N° S1582067 Rev.A dated 09/08/2022 |
| - “R-frames with steel pipes and extended sleeves - A-60 steel deck”: | N° S1582065 Rev.A dated 09/08/2022 |
| - “R-frames with copper pipes - A-0 steel deck/blkhd”: | N° S1582063 Rev.A dated 09/08/2022 |
| - “R-frames with copper pipes - A-60 steel deck/blkhd”: | N° S1582062 Rev.A dated 09/08/2022 |
2.2.2 - SL X sleeve (R X kit):
| - “RX, R-frames with steel pipes and SLX sleeves - A-60 steel deck/blkhd”: | N° S1582059 Rev.A dated 28/10/2022 |
| - “RX, R-frames with steel pipes and SLX sleeves - A-0 steel deck/blkhd”: | N° S1582066 Rev.A dated 28/10/2022 |
3. TEST REPORTS:
3.1 - A-Class Single-Cable and Multi-Cable Sealing System
3.1.1 - Standard and extended length (400 mm)* SL R sleeves
| Laboratory | Test report | Date | Division | Fire rating | Test standard |
| CTO, Poland | N° RS-18/B-485/E 10/12/2018 | Bulkhead | A-60 | ||
| CTO, Poland | N° RS-22/B-336/E 28/10/2022 | Bulkhead | A-60 | ||
| CTO, Poland | N° RS-22/B-338/E 28/10/2022 | Bulkhead | A-60 | ||
| RISE, Sweden N° 8P07094 rev 1 16/01/2020 | Bulkhead | A-0 | |||
| DBI, Denmark | N° PGA10724A | 05/02/2016 | Bulkhead | A-0 | IMO 2010 FTP Code, Annex 1, Part 3 |
| CTO, Poland | N° RS-22/B-153/E 04/05/2022 | Deck | A-60 | ||
| DBI, Denmark | N° PGB10172A | 17/06/2022 | Deck | A-60 | |
| DBI, Denmark N° PGB10174A* 13/07/2022 | Deck | A-60 | |||
| DBI, Denmark | N° PGA10723A | 04/02/2016 | Deck | A-0 |
3.1.2 - SLF R sleeves
| DBI, Denmark | N° PGB10177A | 04/11/2022 | Deck | A-60 | IMO 2010 FTP Code, Annex 1, Part 3 |
3.1.3 - SL A sleeves
| CTO, Poland | N° RS-21/B-518/E | 15/12/2021 | Bulkhead | A-60 | |
| CTO, Poland | N° RS-22/B-152/E | 04/05/2022 | Bulkhead | A-60 | IMO 2010 FTP Code, Annex 1, Part 3 |
| DBI, Denmark | N° PGA10800A | 26/05/2016 | Deck | A-60 | |
| DBI, Denmark | N° PGA10871A | 17/11/2016 | Deck | A-60 |
3.1.4 - SL X sleeves (RX kit)
| CTO, Poland | N° RS-18/B-485/E | 10/12/2018 | Bulkhead | A-60 | |
| CTO, Poland | N° RS-19/B-255/E | 20/08/2019 | Bulkhead | A-60 | IMO 2010 FTP Code, Annex 1, Part 3 |
| SP, Sweden | N° 7P02167 | 07/08/2017 | Deck | A-60 |
3.2 - A-Class Single-Pipe and Multi-Pipe Sealing System
3.2.1 – Standard and extended length (400 mm)* SL R sleeves – Steel pipes
3.2.2 - Standard SL R sleeves – Copper pipes
| DBI, Denmark | N° PGA10724A | 05/02/2016 | Bulkhead | A-0 | |
| DBI, Denmark | N° PGB10046A | 16/11/2020 | Bulkhead | A-60 | |
| DBI, Denmark | N° PGB10176A | 04/11/2022 | Bulkhead | A-60 | IMO 2010 FTP Code, Annex 1, Part 3 |
| DBI, Denmark | N° PGA10723A | 04/02/2016 | Deck | A-0 | |
| SP, Sweden | N° 6P07563 | 20/12/2016 | Deck | A-60 | |
| DBI, Denmark | N° PBG10118A | 15/11/2021 | Deck | A-60 |
3.2.3 - SLF R sleeves - Copper pipes
| DBI, Denmark | N° PBG10118A | 15/11/2021 | Deck | A-60 | IMO 2010 FTP Code, Annex 1, Part 3 |
3.2.4 - SL X sleeves (R X kit) – Steel pipes
| SP, Sweden | N° 8P04039 | 06/08/2018 | Bulkhead | A-60 | |
| SP, Sweden | N° 8P04040 | 13/08/2018 | Deck | A-60 | IMO 2010 FTP Code, Annex 1, Part 3 |
| CTO, Poland | N° RS-19/B-225/E 01/08/2019 | Deck | A-60 |
3.3 - A-Class Blank Sealing System
| CTO, Poland | N° RS-22/B-338/E | 15/09/2022 | Bulkhead | A-60 | |
| CTO, Poland | N° RS-22/B-153/E | 08/04/2022 | Deck | A-60 | IMO 2010 FTP Code, Annex 1, Part 3 |
| SP, Sweden | N° 6P10022 | 31/01/2017 | Deck | A-60 |
4. APPLICATION / LIMITATION:
4.1 – Cable penetrations : approved for use as a blank, single or multi cable transits in A-0, A-15, A-30 and A-60 class steel
divisions, with limitations contained in §1.
4.2 – For cable penetrations, filling ratio not to exceed the tested one (see §1).
4.3 – Pipe penetrations : approved for use as a blank, single or multiple pipe penetration systems in A-0, A-15, A-30 and A-60
steel divisions, with limitations contained in §1.
5.1 - The A-class single-cable/pipe and multi-cables/pipes sealing systems are to be supplied by ROXTEC International AB
in compliance with the type described in this certificate.
7. OTHERS:
7.2 - This Certificate supersedes the Type Approval Certificate N° 13965/D0 BV issued on 30/03/2020 by the Society.
7.3 - Testing of the penetrations for gastightness and watertightness as per following inspection reports, witnessed by Third
Party surveyor:
- report N° MLM 020408 dated 30/06/2002, from DNV, Sweden.
- report N° MLM 30473-1 dated 27/01/2003, from DNV, Norway.
- report N° DNV40007647-1 dated 13/12/2011, from DNV, Norway.
- report N° N141EX8Z Rev.2 dated 10/08/2017, from DNVGL, Sweden.
- report N° N1429Y4V dated 21/03/2022, from DNVGL, Sweden.
| Watertightness test | Gastightness test |
| (before fire exposure) | (before fire exposure) |
| Welded SL and SLF sleeves (sizes 50-200 / cables only) | 6 bar during 60 min |
| Welded SL (sizes 50-200 / cables&pipes) | 6 bar during 60 min |
| Bolted SLF sleeves (sizes 50-200 / cables only) | 5 bar during 60 min |
| Bolted SLA sleeves (sizes 50-100 / cables only) | 4 bar during 60 min |
