19-1900390-1-PDA-optimized
Model(s): Roxtec RS / RS OMD Seals in Steel Divisions
Product Design Assessment (PDA) 19-1900390-1-PDA 29-JUN-2023 18-SEP-2024
Single pipe penetration in Class A0, A15, A30 and A60 bulkhead and decks for marine and offshore
application. Please see service restrictions for types of pipes, pipes sizes, and the tested and approved
insulation arrangements used with the Roxtec RS / RS OMD Seals in Steel Divisions. Singe pipe
penetration of watertight and gastight steel bulkheads and decks up to the specified pressure. Please
see Ratings sections for approved pressures.
Roxtec sealing system with multidiameterTM technology: RS-series (steel division)
The RS pipe penetration seal consist of two halves with removable layers making it adaptable to a single
pipe of different diameters. It is available in different versions, RS, RS OMD, RS EMC or RS EX,
depending on application.
The RS-seal is installed into an steel sleeve that is either welded, bolted, attached through expansion
(SLFRS X) or attached with a nut (SLA) onto the steel division.
Fire Ratings: A0, A15, A30 and A60 Bulkheads and decks. Please see service restriction section.
Watertight (WT) and Gastight (GT) Ratings:
Welded RS Sleeve:
Steel pipe - 4 bar WT and 2 bar GT - 6mm pipe in RS 23 frame to 558mm pipe in RS 644 frame
02/12/2024 9:09:54 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 8
Certificate Number: 19-1900390-1-PDA
Copper Pipe and Cu-Ni Pipes - 4 bar WT and 2 bar GT - 6mm pipe in RS 23 frame to 420mm pipe in RS
500 frame
Fiberglass Pipes - 4 bar WT and 2 bar GT - 32mm pipe in RS 68 frame to 1040mm pipe in RS 1125
frame
Bolted RS SLA Sleeve:
Steel pipe - 2.67 bar and 1 bar - 6mm pipe in RS 25 frame to 34mm pipe in RS 75 frame
Copper pipe - 2.67 bar and 1 bar - 6mm pipe in RS 25 frame to 34mm pipe in RS 75 frame
Expansion RS SLFRSX:
Steel pipe - 4 bar WT and 2 bar GT- 6mm pipe in RS 25 frame to 168mm pipe in RS 200 frame
Copper pipe - 4 bar WT and 2 bar GT- 6mm pipe in RS 25 frame to 168mm pipe in RS 200 frame
A) Steel Pipe: Outside diameter 6 to 558 mm through A-Class bulkhead and deck using RS Series
sealing system size from 23 to 644 with welded SLRS sleeve.
Steel Pipe: Outside diameter 6 to 30 mm through A-Class bulkhead and deck using RS Series sealing
system size 25 to 75 with bolted with SLA sleeve.
Steel Pipe: Outside diameter 6 to 168 mm through A-Class bulkhead and deck using RS Series sealing
system size 25 to 200 with expansion sleeve (SLFRS X).
For A-60 bulkhead sleeve and insulation arrangements see drawings S1577746, S1579079, S1579138
For A-60 deck and sleeve and insulation arrangements see drawings S1578992, S1579233, S1579138,
S1579079
For A-0 bulkhead sleeve and insulation arrangements see drawing S1579018, S1580043
For A-0 deck sleeve and insulation arrangements see drawing S1579016, S1580043
B) Cu-Ni: Pipe: Outside diameter 6 to 420mm through A-Class bulkhead and deck using RS Series
sealing system size 23 to 500 with welded SLRS sleeve.
For A-60 bulkhead sleeve and insulation arrangements see drawing S1579192
For A-60 deck and sleeve and insulation arrangements see drawing S1579206
For A-0 bulkhead sleeve and insulation arrangements see refer to drawing S1580068
For A-0 deck sleeve and insulation arrangements see refer to drawing S1580065
C) Copper Pipe: Outside diameter 6 to 222 mm through A-Class bulkhead and deck with RS Series
sealing system in size 23 to 300 with welded SLRS sleeve.
Copper Pipe: Outside diameter 6 to 34 mm through A-Class bulkhead and deck with RS Series sealing
system in size 25 to 75 with SLA sleeve.
Copper Pipe: Outside diameter 6 to 108 mm for copper pipes for bulkhead and deck with RS Series
sealing system in size 25 to 150 with expansion sleeve (SLFRS X)
For A-60 bulkhead sleeve and insulation arrangements see drawings S1577860, S1579117, S1579120
02/12/2024 9:09:54 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 8
For A-60 deck and sleeve and insulation arrangements see drawings S1578982, S1579117, S1579120
For A-0 bulkhead sleeve and insulation arrangements see drawings S1579002, S1580051
For A-0 deck sleeve and insulation arrangements see drawings S1579005, S1580051
D) Sheathed Bundled Pipe (steel cores): Outside diameter 8 to 50 mm through A-Class bulkhead and
deck with RS Series sealing system size 25 to 100 with welded SLRS sleeve.
For A-60 bulkhead and deck sleeve and insulation arrangements see drawing S1579231
For A-0 bulkhead and deck and sleeve and insulation arrangements see drawing S1591613
E) GRE Pipe: Outside diameter 25 to 1040mm through A-Class bulkhead and deck with RS Series
sealing system size 50 to 1125 with welded SLRS sleeve.
For A-60 bulkhead sleeve and insulation arrangements see drawing S1579165
For A-60 deck and sleeve and insulation arrangements see drawing S1579186
For A-0 bulkhead sleeve and insulation arrangements see drawing S1579190
For A-0 deck sleeve and insulation arrangements see drawing S1580064
F) For ROXTEC systems tested solely in A-60 Class Divisions, the system and pipe(s) when installed in
A-0, A-15 or A-30 divisions is to be insulated per the A-60 arrangement for 200 mm around the
penetration transits per 2010 IMO FTP Code Annex1, part 3, A.III 2.2.1
a) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
b) Production items are to be manufactured in accordance with a quality control system which shall be
maintained to ensure that items are of the same standard as per tested/approved prototype.
c) This certificate may not be used for EU and US flagged vessels (MED and/or USCG have their own
specific requirements).
d) Not performed on behalf of any flag Administration.
e) Any component of penetration systems shall not be replaced by materials that have not been tested in
accordance with the IMO FTP Code and/or accepted by the Flag Administration.
f) Individual review to the intended use on specific vessel, MODU or facility is required.
g) The pipe penetrants should be in conjunction with the tested and approved ROXTEC seal types and
installed in accordance with manufacturer’s ABS approved installation drawings.
h) The arrangement of the transit sleeves in the fire rated divisions and the installation of the fire rated
insulation is to be in accordance with manufacturer’s ABS approved drawings.
i) Insulation material is to be A-60 approved type and properly installed to the satisfaction of the
Surveyors.
j) Installation of transits are only permissible where strength and fatigue characteristics are not
diminished or where satisfactory structural compensation has been provided.
k) Not to use in tank boundaries.
02/12/2024 9:09:54 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 8
l) Application for gas tight and water tight bulkhead penetration and hydrostatic test are to be indicated
on the plan for each project by shipyard.
m) During installation of deck and bulkhead watertight and fire-rated pipe penetrations, the attending
Surveyor is to confirm that the installer is familiar with and has access to the manufacturer’s installation
procedures for transit devices.
n) After installation, all watertight and fire-rated pipe penetrations are to be visually examined. Watertight
pipe penetrations are to be tested as required by 3-7-1/Table 1 per ABS Marine Vessel Rules (MVR),
4-8-4/ 29.15.
o) The use of plastic pipes should in accord with the ABS Marine Vessel Rules 4-6-3 and 4-6-3 / Table 1
(Fire Endurance Matrix).
p) In accordance with ABS Marine Vessel Rules 4-6-3 / 7.11(iii) If the bulkhead or deck is also a fire
division and destruction by fire of plastic pipes may cause inflow of liquid from a tank, then a metallic
shut-off valve operable from above the bulkhead deck is to be fitted at the bulkhead or deck. Valves are
to be fitted on both sides of plastic pipe
q) Bundling of tubes / pies are not permitted in watertight divisions, with the exception of the OSNALINE
sheathed tube bundles tested in DNV Report MLM060561 (WT Pressure 4 Bar / GT Pressure 2 bar).
r) When requested to be used in watertight bulkheads on passenger ships or special purpose ships, the
penetration system has to comply with the requirements given in SOLAS Ch. II -1 Reg. 13.2.3. This
approval of penetrations passing through watertight bulkhead is not to be construed as a substitute for
flag Administration’s approval for the purpose of SOLAS 1974 as amended.
s) Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
t) Continued compliance with the statutory requirements requires maintenance of full Type Approval
(PDA and MA). The scope of Type Approval is to comply with MSC.1/Circ. 1221 dated 11 December
2006.
Test Reports:
  1. CTO SA RS-19/B-035/E, A-60 Bulkhead Pipe and Cable Transit Tests date 25 Feb 2019 Gdansk
Poland.
  1. DBI PGA10871A, Rev 2, Cable transits and pipe penetrations in class A-60 steel deck date 31 Oct
2016 Hvidovre Denmark.
  1. CTO SA RS-19/B-355/E, A-60 Steel Bulkhead Cable and Pipe Transit date 16 Oct 2019 Gdansk
Poland.
  1. SP 6P02249, IMO Test Of Pipe Penetration Seals In A60 Steel Deck date 17 Aug 2016 Boras
Sweden.
  1. DBI PGB10118A, Rev. 1, Transits in Class A-60 Steel Deck date 15 Nov 2021 Hvidovre Denmark.
  2. DBI PGB10047A, Rev. 0, Test Report Class A-60 Deck with Penetrations date 30 Nov 2020
Hvidovre Denmark.
  1. CTO SA RS-21/B-519/E, A-60 Steel Bulkhead Cable and Pipe Transit date 15 Dec 2021 Gdansk
Poland.
  1. DBI PGB10020A, Rev. 0, Pipe Penetrations in Class A-60 Steel Bulkhead date 5 May 2020 Hvidovre
Denmark.
  1. CTO SA RS-21/B-241/E, A-60 Steel Bulkhead Cable and Pipe Transit date 30 June 2021 Gdansk
Poland.
02/12/2024 9:09:54 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 8
  1. DBI PGB10111A, Rev. 0, Pipe Penetrations in Class A-60 Steel Deck date 20 Sep 2021 Hvidore
Denmark.
  1. DBI PGB10032A, Rev. 0, Pipe and Drain Penetrations in A-60 Steel Deck date 1 July 2020 Hvidore
Denmark.
  1. SP 5P03457, IMO Test of Cable Penetration Seals in A60 Steel Deck date 12 May 2015 Boras
Sweden.
  1. CTO SA RS-19/B-356/E, A-60 Steel Deck Pipe and Cable Transit Tests date 18 Oct 2019 Gdansk
Poland.
  1. DBI PGA10649, Rev. 0, ROXTEC - Cable Transits and Pipe Penetrations in A Steel Deck date 18
May 2015 Hvidovre Denmark.
  1. DBI PGA10650, Rev. 0, ROXTEC - Pipe Penetrations in A Steel Deck date 18 May 2015 Hvidovre
Denmark.
  1. CTO SA RS-20/B-017/E, A-60 Steel Bulkhead Pipe and Cable Transits date 23 Jan 2020 Gdansk
Poland.
  1. CTO SA RS-20/B-191/E, A-60 Steel Bulkhead Pipe and Cable Transits date 5 June 2020 Gdansk
Poland.
  1. SP 7P02167, IMO Test of Pipe Penetration Seals in A60 Steel Deck date 7 Aug 2017 Boras
Sweden.
  1. DBI PGB10110A, Rev. A, Cable Transits and Pipe Penetrations in Class A-0 Steel Deck date 27 Apr
  1. SP 6P04351, IMO Test of Pipe Penetration Seals in A60 Steel Bulkhead date 28 June 2016 Boras
Sweden.
  1. CTO SA RS-21/B-445/E, A-60 Steel Bulkhead Pipe and Cable Transits date 7 Oct 2021 Gdansk
Poland.
  1. DBI PGA10800A, Rev. 0, Pipe Penetrations and Cable Transits in a Class A-60 Steel Deck date 26
May 2016 Hvidovre Denmark.
  1. DBI PGA11611A, Rev. 0, Cable Transits and Pipe Penetrations in Class A-60 Steel Deck date 11
Jan 2020 Hvidovre Denmark.
  1. DBI PGB10020A, Rev. 0, Pipe Penetrations in Class A-60 Steel Bulkheads date 05 May 2020
Hvidovre Denmark.
  1. CTO SA RS-22/B-336/E, A-60 Steel Bulkhead Pipe and Cable Transits date 28 Oct 2022 Gdansk
Poland.
  1. CTO SA RS-22/B-337/E, A-60 Steel Deck Pipe and Cable Transits date 28 Oct 2022 Gdansk
Poland.
  1. CTO SA RS-18/B-023/E, A-60 Steel Deck Pipe and Cable Transits date 29 Jan 2018 Gdansk
Poland.
  1. CTO SA RS-20/B-081/E, A-60 Steel Bulkhead Pipe and Cable Transits date 31 Mar 2020 Gdansk
Poland.
  1. CTO SA RS-21/B-517/E, A-60 Steel Bulkhead Pipe and Cable Transits date 15 Dec 2021 Gdansk
Poland.
  1. DBI PGA11610A, Rev. 0, Cable Transits and Pipe Penetrations in Class A-0 Steel Deck date 10 Jan
  1. DBI PGA10119A, Rev. 1, Transits in Class A-0 Steel Deck date 15 Nov 2021 Hvidovre Denmark.
02/12/2024 9:09:54 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 5 of 8
  1. DBI PGA10112A, Rev. 1, Cable Transits and Pipe Penetrations in Class A-60 Steel Deck date 20
Sep 2020 Hvidovre Denmark.
  1. SP 4P08662, IMO Test of Penetration Seals in A60 Steel Bulkhead date 8 June 2015 Boras
Sweden.
  1. SP 4P06068, IMO Test of Penetration Seals in A60 Steel Bulkhead date 17 Jan 2015 Boras
Sweden.
  1. SP 4P07023, IMO test of cable penetration seals in A60 steel deck date 4 Feb 2015 Boras Sweden.
Roxtec Drawings:
S1577746, Rev. A, RS with Steel Pipe SLRS/SLFRS A-60 Steel BHD.
S1577860, Rev. A, RS with Copper Pipes SLRS/SLFRS A-60 Steel BHD.
S1578982, Rev. A, RS with Copper Pipes SLRS/SLFRS A-60 Steel Deck.
S1578992, Rev. A, RS with Steel Pipe SLRS/SLFRS A-60 Steel Deck.
S1579002, Rev. A, RS with Copper Pipes SLRS/SLFRS A-0 Class Steel BHD.
S1579005, Rev. A, RS with Copper Pipes SLRS/SLFRS A-0 Class Steel Deck.
S1579016, Rev. A, RS with Copper Pipes SLRS/SLFRS A-0 Class Steel Deck.
S1579018, Rev. A, RS with Copper Pipes SLRS/SLFRS A-0 Class Steel BHD.
S1579079, Rev. A, RS with Steel Pipe SLA A-60 Class Steel BHD/Deck.
S1579117, Rev. A, RS with Copper Pipe SLA A-60 Class Steel BHD/Deck.
S1579120, Rev. A, RS with Copper Pipe SLFRS X A-60 Class Steel BHD/Deck.
S1579138, Rev. B, RS with Steel Pipe SLFRS X A-60 Class Steel BHD/Deck.
S1579165, Rev. A, RS with GRE Pipes SLRS/SLFRS A-60 Class Steel Deck.
S1579186, Rev. A, RS with GRE Pipes SLRS/SLFRS A-60 Class Steel BHD.
S1579190, Rev. A, RS with GRE Pipes SLRS/SLFRS A-0 Class Steel Deck.
S1579192, Rev. A, RS with CuNI Pipes SLRS/SLFRS A-60 Class Steel BHD.
S1579206, Rev. A, RS with CuNI Pipes SLRS/SLFRS A-60 Class Steel Deck.
S1579231, Rev. B, RS with Bundle Pipes SLRS/SLFRS A-60 Class Steel Deck/Bulkhead.
S1591613, Rev. A, RS with Bundle Pipes SLRS/SLFRS A-0 Class Steel Deck/Bulkhead.
S1579233, Rev. A, RS OC with Steel Pipe SLRS/SLFRS A-60 Class Steel Deck.
S1580043, Rev. A, RS with Steel Pipe SLA A-0 Class Steel Deck/BHD.
S1580051, Rev. A, RS with Copper Pipe SLA A-0 Class Steel Deck/BHD.
S1580064, Rev. A, RS with GRE Pipes SLRS/SLFRS A-0 Class Steel BHD.
S1580065, Rev. A, RS with CuNi Pipes SLRS/SLFRS A-0 Class Steel Deck.
S1580068, Rev. A, RS with CuNi Pipes SLRS/SLFRS A-0 Class Steel BHD.
02/12/2024 9:09:54 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 6 of 8
Watertight and GasTight Reports:
DNV Report N1421782 ROXTEC RS 23 - 644 for Metal Pipes 6mm to 558mm (date 1 Sep 2020).
DNV Report N141EX8Z ROXTEC RSA Sleeve 25, 75, 100 (date 10 Aug 2017).
DNV Report N142JK4Z ROXTEC SFHM 1x1 SHHM 8x1 (date 27 Mar 2023).
DNV Report N142JK51 ROXTEC RS 23 and ROXTEC RS 150 Bolted SLRFS w/ Pre-Punched Gasket
(date 27 Feb 2023).
DNV Report N14254FG ROXTEC RS 1125 (GRP Pipe of 1040mm OD) (date 30 Apr 2021).
DNV Report MLM 030473-1 ROXTEC RS-23 and RS-200 Steel Pipe and Cables (date 27 Jan 2003).
DNV Report MLM 060561 (date 1 Dec 2006) for ROXTEC:
  • RS-43 w/ Osnaline sheathed stainless steel bundle pipes 6x6x0.5 OD 22.4mm.
- RS-68 w/ GRP Pipe OD 32mm and 3.7mm thick.
  • RS-100 w/ Osnaline sheathed stainless steel bundle pipes 19x9.8x1.4 OD 54.3mm.
- RS-500 w/ GRP Pipe OD 410mm and 12mm thick.
  • S BTB w/ Osnaline sheathed bundle pipes 6x6x0.5 OD 22mm (stainless steel) and 4x6x1.1 OD mm
(copper).
This Product Design Assessment (PDA) Certificate remains valid until 18/Sep/2024 or until the Rules
2023 Rules for Conditions of Classification, 1-1-4/7.7, 1-1-A3, 1-1-A4, which covers the following:
2023 Rules for Building and Classing Marine Vessels: 3.4-1, 4-6-2/9.7, 4-6-3/7.11.
2023Rules for Conditions of Classification - Offshore Units and Structures 1-1-4/9.7, 1-1-A2, 1-1-A3,
2023 Rules for Building and Classing Mobile Offshore Units: 4-2-1/11.15, 5-1-1/3.19.
2023 Rules for Building and Classing Facilities on Offshore Installations: 3-8/9.13, 4-8/9.13.
IMO Resolution MSC.307(88) adopted 3 December 2010.
IMO FTP Code 2010 (2012 Edition), Annex 1 Part 3, in conjunction with SOLAS (Consolidated Edition
2020), as amended.
02/12/2024 9:09:54 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 7 of 8
This PDA conforms to Transport of Canada requirements:
When produced at a facility with an ABS manufacturing assessment (MA) the product is recognized by
Transport Canada in accordance with TP 14612E-Procedures for Approval of Life-Saving Appliances
and Fire Safety Systems, Equipment and Products.
TP 14612E Transport Canada Procedures for Approval of Life-Saving Appliances and Fire Safety
Systems, Equipment and Products (4th edition 2019): 1.1.2, 1.1.7, 2.1., and 2.3;
SOR/2017-14 Canada Consolidation Vessel Fire Safety Regulations (23 June 2021), Part 2/ Sections
209, 226 and 325;
C.R.C, c. 1431 Canada Consolidation Hull Construction Regulations (23 June 2021), Part 1 / Section
14(7)(b);
SOR/90-264 Canada Consolidation Marine Machinery Regulations (23 June 2021), Schedule IX [14, 15,
16].
DNV-CP-0165 Class Programme Type Approval for Cable and Pipe Penetrations [Section 4 -
Watertightness and Gastightness]
Print Date and Time: 12-Feb-2024 9:09
02/12/2024 9:09:54 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 8 of 8
