20-1952251-1-PDA-optimized
Product: Watertight and Fire Resistant Penetration Device
Model(s): Roxtec R Series Frames in aluminum divisions
Product Design Assessment (PDA) 20-1952251-1-PDA 25-SEP-2020 05-MAR-2025
Multi and single cable and pipe penetrations in Class A0, A15, A30 and A60 bulkheads and decks.
Penetrations of watertight and gastight aluminium bulkheads and decks up to the specified pressure for
marine and offshore applications.
Roxtec cable and pipe sealing system with multidiameter technology composed of aluminium sleeves
(welded or bolted), sleeves of SLX-R type or SL A type with with R type (EMC versions included)
halogen free rubber frames in size 70-200 (50 - 100 with SL A Sleeve), and filled with Roxtec insert
modules, mounted in aluminium decks or bulkheads. RX Kit consists of SLX R type sleeves including an
R Frame.
R-frame seal in welded or in SLX type sleeves:
R-frame seal in SL A Type sleeves:
Watertight test pressure 4 bar
Gastight test pressure 1.5 bar
02/13/2024 12:46:44 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 4
Certificate Number: 20-1952251-1-PDA
a) Maximum cable size 62 mm (50 mm with SL A) for bulkheads and decks. Type of cable tested:
Marine.
b) Maximum steel pipe outside diameter up to 54 mm for bulkheads and decks. Not applicable for SL A.
c) Maximum copper pipe outside diameter up to 54 mm for bulkheads and 57 mm for decks. Not
d) Maximum frame size tested: Size 200 (Size 100 for SL A)
e) Minimum frame size tested: Size 50
f) Not for use in tank boundaries
g) Insulation material is to be A-60 approved type and installed in accordance with the attached drawings
to the satisfaction of the Surveyor.
h) Unit Certification is not required for this product. If the manufacturer or purchaser request an ABS
a) Watertight or fire rated bulkheads or decks for cable penetrations are to be examined and tested as
b) When requested to be used in watertight bulkheads on passenger ships or special purpose ships, the
penetration system has to comply with the requirements given in SOLAS Ch. II -1 Reg. 13.2.3 (2020
Consolidated Edition). This approval of penetrations passing through watertight bulkhead is not to be
construed as a substitute for flag Administration’s approval for the purpose of SOLAS (Consolidated
Edition 2014), as amended.
c) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
d) All seal types should be installed with the manufacturer’s instructions in accordance with approved
drawings S1554368 for R frames with cables, S1019810 for R Series frames with steel/cooper pipes,
and S1554370 for SL A type sleeve with R-frames with cables.
Test Report number P603001 dated 23 January 2007 / SP Technical Research Institute of Sweden,
Boras
Test Report number P11898 dated 10 September 2008 / Danish Institute of Fire and Security
Technology, Hvidovre
Test Report number P11955 dated 11 September 2008 / Danish Institute of Fire and Security
Test Report number RS-19/B-224/E dated 01 Ago 2019 / CTO - Centrum Techniki Okretowej S.A.,
Gdansk, Poland
Test Report number PGA11370A dated 20 February 2019 / Danish Institute of Fire and Security
Test Report number PGA11371A dated 20 February 2019 / Danish Institute of Fire and Security
Test Report number RS-17/B-210/E dated 02 June 2020 / CTO - Centrum Techniki Okretowej S.A.,
Gdansk, Poland
02/13/2024 12:46:44 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 4
Test Report number RS-18/B-179/E dated 25 June 2020 / CTO - Centrum Techniki Okretowej S.A.,
Gdansk, Poland
Test Report number RS-20/B-082/E dated 21 April 2020 / CTO - Centrum Techniki Okretowej S.A.,
Gdansk, Poland
DNV Third Party Inspection Report number MLM010238, dated 30 Sep 2001
DNV Third Party Inspection, Witness of Pressure Testing - ROXTEC SLA Sleeve, Report number
N141EX8Z, Revision 2, dated 10 Aug 2017
Drawings:
Drawing No. S1019810, R-Frames W St/CU Pipes A-Class Alu. Deck/Bulkhead, Sheet 1 of 1, Revision -
, dated 1 March 2010
Drawing No. S1554368, R-Frames W Cables A-60 Class Alu. Deck/Bulkhead, Sheet 1 of 1, Revision A,
dated 25 June 2020
Drawing No. S1554370, SL A Sleeve with R-Frame and Cable A-60 Class Steel Deck/Blkhd, Sheet 1 of
1, Revision A , dated 08 April 2020
This Product Design Assessment (PDA) Certificate remains valid until 05/Mar/2025 or until the Rules
2020 Rules for Conditions of Classification: 1-1-4/7.7, 1-1-A3 and A4, which covers the following:
2020 Rules for Building and Classing Marine Vessels: 4-6-2/9.7, 4-8-2/7.7, 4-8-4/21.13.1, 4-8-4/29.15
2020 Rules for Conditions of Classification – Offshore Units and Structures: 1-1-4/9.7, 1-1-A2 and A3,
2020 Rules for Building and Classing Mobile Offshore Units: 4-2-1/11.15, 4-3-3/5.13.1
SOLAS (Consolidated edition 2020) Chapter II-2, Reg. 9.3.1
IMO FTP Code 2010, Annex I: Part 3 and Part 11. 2012 Edition.
This PDA conforms to Transport of Canada requirements as per TC Letter A8710-1 RDIMS-#7077969
dated 19-Oct-2011.
02/13/2024 12:46:44 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 4
Print Date and Time: 13-Feb-2024 12:46
02/13/2024 12:46:44 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 4
