23-2372497-PDA-optimized
Model(s): Roxtec SPM seal series in Aluminium divisions.
Product Design Assessment (PDA) 23-2372497-PDA 19-JUN-2023 18-JUN-2028
Single pipe penetration in Class A-0, A15, A30 and A60 bulkheads and decks for Marine and Offshore
Applications. Penetration of watertight and gas-tight aluminium bulkheads and decks up to rated
pressure.
Roxtec sealing system: SPM-Seal (Alu divisions) the SPM seal consist of a highly elastic EPDM rubber
frame and fittings of stainless steel. The SPM seal is installed by expansion onto the aluminium division.
Fire Resistance - A0, A15, A30 and A60 Bulkheads and Decks
Water tightness test pressure: 1.5 bar g.
Gas tightness test pressure : 1.0 bar g.
a) Maximum and Minimum tested Steel Pipes: 222 mm & 8 mm outside diameter.
b) Maximum and Minimum tested Copper Pipes: 110 mm & 8 mm outside diameter.
c) Maximum and Minimum Size of Transit Frame - SPM 279 ( Aperture Diameter 283 mm) & SPM 39 (
Aperture Diameter 39 mm)
d) Not for use in tank boundaries and collision bulkhead.
e) Transits are to be insulated as per the approved ABS drawings for all fire division ratings.
02/12/2024 9:21:17 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 4
Certificate Number: 23-2372497-PDA
f) For fire class A-0, A-15 and A-30, seals are to be insulated as for class A-60 and in addition the
division is to be insulated at least 200 mm around the penetration.
g) Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
a) All seal type should be installed in accordance with the manufacturers instructions and ABS approved
installation drawings.
b) Insulation material is to be A60 approved type and properly installed in accordance with ABS
approved drawings to the satisfaction of the Surveyors.
c) Watertight bulkheads or decks are to be tested as per ABS Marine Vessels Rules 3-7-1/Table 1.
penetration system has to comply with the requirements give in SOLAS Ch. 11-1 Reg. 13.2.3 (2020
Consolidated Edition or latest issue). This approval of penetrations passing through watertight bulkhead
is not to be construed as a substitute for flag Administration’s approval for the purpose of SOLAS 74/78
(2020 Consolidated Edition).
e)The product or packing is to be marked with name of manufacturer, type designation and fire rating.
f) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
Test Reports:
RS-17B-209E, IMO Fire Test of Pipe Penetration Seals in A60 Aluminium Bulkhead , dated 02 June
2017.
RS-17B-210E, IMO Fire Test of Pipe Penetration Seals in A60 Aluminium Deck, dated 02 June 2017
PGA11370A, IMO Fire Test of Pipe Penetration Seals in A60 Aluminium Bulkhead, dated 20 Febr 2019.
PGA11371A, IMO Fire Test of Pipe Penetration Seals in A60 Aluminium Deck, dated 20 Febr 2019.
RS-18-B-179-E, IMO Fire Test of Pipe Penetration Seals in A60 Aluminium Deck, dated 25 June 2018.
RS-18-B-180-E, IMO Fire Test of Pipe Penetration Seals in A60 Aluminium Bulkhead, dated 25 June
2018.
N1419WS4, Pressure test report, DNV Survey Report, dated 20 December 2016.
Drawings:
Roxtec SPM Installation instruction, Revision: 1, Pages: 1
S1502970, SPM 39-279 Assembly, Revision: D
S1589045, Roxtec SPM Seal With Pipes A-60 Class Aluminium Bulkhead, Revision: A, Pages: 1
S1589046, Roxtec SPM Seal With Pipes A-60 Class Aluminium Deck, Revision: A, Pages: 1
02/12/2024 9:21:17 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 4
This Product Design Assessment (PDA) Certificate remains valid until 18/Jun/2028 or until the Rules
The ABS Rules for Conditions of Classification, 2023 Marine Vessels 1-1-4/7.7, 1-1-A3, 1-1-A4, which
covers the following:
2023 Rules for Building and Classing Marine Vessels: 4-6-2/9.7
The Rules for Conditions of Classification, Offshore Units and Structures, 2023 Mobile Offshore Units
1-1-4/9.7, 1-1-A2, 1-1-A3, which covers the following:
2023 Rules for Building and Classing Mobile Offshore Units: 4-2-1/11.15
Regulation II-2/ 9.3.1 of SOLAS Consolidated Edition 2020
This PDA conforms to Transport Canada Requirements
Print Date and Time: 12-Feb-2024 9:21
02/12/2024 9:21:17 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 4
02/12/2024 9:21:17 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 4
