23-2372499-PDA-optimized
Model(s): Roxtec Sleev-it Fire penetration seal/ Roxtec Sleev-it Waterproof penetration seal in
Aluminium divisions.
Product Design Assessment (PDA) 23-2372499-PDA 03-MAY-2023 02-MAY-2028
Single pipe penetration in Class A0, A15, A30 and A60 Aluminium bulkheads and decks for plastic pipes
in Marine and Offshore Application. Penetrations of watertight and gastight aluminium decks up to
specified pressure.
Roxtec Sleev-it Fire Penetration Seal consists of an intumescent strip material inserted in an openable
stainless steel casing, equipped with an openable flange, intended for bolted or spot welded installation
onto Aluminium divisions.
Roxtec Sleev-it Waterproof penetration seal consists of an intumescent strip material inserted in a closed
stainless steel casing, equipped with a closed flange with an EDPM rubber grommet, intended for fully
welded installation onto Aluminium divisions.
Fire Rating : A0, A15, A30 and A60 Bulkheads and Decks.
Waterproof penetration seal: Watertightness tested upto 1.5 bar and gas tightness tested upto 1 bar.
a) Maximum and Minimum tested plastic pipes (Poly Propylene & Poly Butylene Pipes) 225 mm and 16
mm.
b) Roxtec Sleev-it Fire penetration: Outside diameter 16 to 225 mm for plastic pipes for bulkhead and
decks, in size 16-225 mm.
02/12/2024 9:23:29 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 4
Certificate Number: 23-2372499-PDA
c) Roxtec Sleev-it Waterproof penetration : Outside diameter 16 to 225 mm for plastic pipes for Deck, in
size 16-225 mm.
d) Maximum and Minimum size of Transits: Size 225 mm and Size 16 mm
e) Not for use in tank boundaries and collision bulkhead.
f) Transits are to be insulated as per the approved ABS drawings for all fire division ratings.
g) For fire class A-0, A-15 and A-30, sleeves are to be insulated as for class A-60 and in addition the
division is to be insulated at least 200 mm around the penetration.
h) Maximum service temperature of the sealant is +70 Degree C.
i) Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
a) All seal types should be installed as per manufacturer’s instructions in accordance with ABS approved
installation drawings.
b) Insulation material is to be A-60 approved type and properly installed to the satisfaction of the
Surveyors.
c) Watertight bulkheads or decks are to be tested as per ABS Steel Vessels Rules 3-7-1/Table 1.
d) When requested to be used in watertight bulkheads on passenger ships and Special Purpose Ships
(SPS), the penetration system has to comply with the requirements given in SOLAS Ch.II-1 Reg. 13.2.3
Consolidated Edition 2020.
e) This approval of penetrations passing through watertight bulkhead is not to be construed as a
substitute for flag Administration’s approval for the purpose of SOLAS Consolidated Edition 2020.
f) The product or packing is to be marked with name of manufacturer, type designation and fire rating.
g) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
Document No. PGA10801A, Fire Test Report, A- Class Aluminium Bulkhead by DBI, Denmark dated 29
August 2016
Document No. PGA10802A, Fire Test Report, A- Class Deck by DBI, Denmark dated 29 August 2016
Document No. RS-17/B-209/E, Fire Test Report, A- Class Aluminium Bulkhead by Centrum Techniki
Okretowej SA, Poland dated 02 June 2017
Document No. RS-17/B-210/E, Fire Test Report, A- Class Deck by Centrum Techniki Okretowej SA,
Document No. RS-17B-555E, Fire Test Report, A- Class Aluminium Bulkhead by Centrum Techniki
Okretowej SA, Poland dated 15 January 2018
Document No. N141EX90, Survey Report, Witness of Pressure Testing- Roxtec Sleev-It WT ALU, by
DNV dated 30 June 2017.
Drawing No. S1507771, Revision: B, Sleev-It FC ALU FC 16-225 ALU, Information Drawing
Drawing No. S1507772,Revision: D, Sleev-It FC ALU FC 16-225 ALU, Information Drawing,
Drawing No. S1589161, ROXTEC SLEEV-IT FC A-60 CLASS ALUMINIUM BULHEAD/DECK, Revision:
02/12/2024 9:23:29 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 4
A, Pages: 1
Drawing No. S1589166, ROXTEC SLEEV-IT WT A-60 CLASS ALUMINIUM DECK, Revision: A, Pages:
Document No. 151408 DOC-001370 A , Roxtec Sleev it Alu Fire penetration seal- Installation
Instructions , Revision: A
Document No. 151406 DOC-001371 A, Roxtec Sleev it Alu Waterproof penetration seal- Installation
This Product Design Assessment (PDA) Certificate remains valid until 02/May/2028 or until the Rules
The ABS Rules for Conditions of Classification, 2023 Marine Vessels 1-1-4/7.7, 1-1-A3, 1-1-A4, which
covers the following:
2023 Rules for Building and Classing Marine Vessels: 4-6-3/7.11
The Rules for Conditions of Classification, Offshore Units and Structures, 2023 Mobile Offshore Units
1-1-4/9.7, 1-1-A2, 1-1-A3, which covers the following:
2023 Rules for Building and Classing Mobile Offshore Units: 4-2-2/ 7.7.4
Regulation II-2/ 9.3.1 of SOLAS Consolidated Edition 2020
IMO Resolution MSC. 307 (88) - ( 2010 FTP Code - Edition 2012), Annex I: Part 3, Adopted 3 December
2010
A8706-1 RDIMS#1961446
02/12/2024 9:23:29 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 4
Print Date and Time: 12-Feb-2024 9:23
02/12/2024 9:23:29 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 4
