Certificate number: 46204/B0 BV
File number: ACI4010/030/004
Product code: 5301H
A-0/A-60 Roxtec sealing system: Sleev-it in steel divisions
(certified products, sleeve position and achieved performance - see §1)
SOLAS 74, as amended, Regulations II-2/9.3.1
IMO Resolution MSC.307(88) (2010 FTP Code)
IMO Resolution MSC.61(67)-(FTP Code) with IMO Resolution MSC.307(88) (2010 FTP Code) article 8
IMO MSC/Circ.1120
This certificate will expire on: 07 Feb 2029
At BV GOTHENBURG, on 07 Feb 2024,
Hans-erik ERICSSON
signature
| BV Mod. Ad.E 530 June 2017 | This certificate consists of 7 page(s) |
1. PRODUCT DESCRIPTION:
Consist of a steel collar casing lined with intumescent material on the inside and a flange.
It is available in FC MAR (fire penetration seal) and WT MAR (Fire/Watertight penetration seal) versions depending on
application.
The Sleev-it is installed onto a steel division by welding (FC/WT MAR) or bolting (FC MAR) depending on version.
Marine graded sealant is applied during the installation to achieve a cold smoke seal.
Additional insulation on penetrations and/or pipes:
- should be approved as having the same level of performance as the penetrated division and expected classification of
penetration,
- is to be fitted as shown in the referred Manufacturer’s drawings (see §2) and also according to Manufacturer’s insulation
guidelines.
1.1 - A-60 Bulkhead
| Pipe material | Pipe diameter | Sleeve position | Insulation drawing |
| (OD) [mm] | |||
| 16-225 | Exposed | S1598000 rev. A dated 31/10/2023 ID 1 | |
| ABS | 16 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 5 |
| 114 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 2 | |
| Beverage | 100 | Exposed | S1598000 rev. A dated 31/10/2023 ID 1 |
| multipipe | 100 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 2 |
| 16-160 | Exposed | S1598000 rev. A dated 31/10/2023 ID 1 | |
| PB | 16-225 | Exposed | S1598000 rev. A dated 31/10/2023 ID 3 |
| 16-160 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 2 | |
| 16-225 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 4 | |
| 16 | Exposed | S1598000 rev. A dated 31/10/2023 ID 3 | |
| PE / HDPE | 200-225 | Exposed | S1598000 rev. A dated 31/10/2023 ID 1 |
| 16-225 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 2 | |
| 315 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 9 | |
| 16 | Exposed | S1598000 rev. A dated 31/10/2023 ID 1 | |
| PE / ALU / PE | 16-63 | Exposed | S1598000 rev. A dated 31/10/2023 ID 7 |
| 16-63 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 8 | |
| PP / PPR / PPML | 32-200 | Exposed | S1598000 rev. A dated 31/10/2023 ID 1 |
| / PPFR | 16-110 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 6 |
| 40-200 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 2 | |
| Pre-insulated pipe | 75-315 | Exposed | S1598000 rev. A dated 31/10/2023 ID 7 |
| 16-225 | Exposed | S1598000 rev. A dated 31/10/2023 ID 3 | |
| 16-322 | Exposed | S1598000 rev. A dated 31/10/2023 ID 1 | |
| PVC | 16-200 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 2 |
| 271-322 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 5 | |
| PVDF | 169 | Exposed | S1598000 rev. A dated 31/10/2023 ID 1 |
| 169 | Unexposed | S1598000 rev. A dated 31/10/2023 ID 2 |
Following on next page
1.2 - A-60 Deck
| (OD) [mm] | |||
| 16-219 | Exposed | S1598002 rev. B dated 13/12/2023 ID 1 | |
| ABS | 225 | Exposed | S1598002 rev. B dated 13/12/2023 ID 3 |
| 16 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 2 | |
| Beverage | 100 | Exposed | S1598002 rev. B dated 13/12/2023 ID 1 |
| multipipe | 75-100 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 2 |
| PB | 16-225 | Exposed | S1598002 rev. B dated 13/12/2023 ID 1 |
| 16-225 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 2 | |
| 16 | Exposed | S1598002 rev. B dated 13/12/2023 ID 3 | |
| PE / HDPE | 16 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 4 |
| 125-225 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 2 | |
| PE / ALU / PE | 16-63 | Exposed | S1598002 rev. B dated 13/12/2023 ID 1 |
| 16-63 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 2 | |
| PP / PPR / PPML | 16-320 | Exposed | S1598002 rev. B dated 13/12/2023 ID 1 |
| / PPFR | 16-110 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 2 |
| Pre-insulated pipe | 75-315 | Exposed | S1598002 rev. B dated 13/12/2023 ID 5 |
| 16-225 | Exposed | S1598002 rev. B dated 13/12/2023 ID 1 | |
| PVC | 315-321 | Exposed | S1598002 rev. B dated 13/12/2023 ID 6 |
| 16-160 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 2 | |
| 271-321 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 7 | |
| PVDF | 48-166 | Exposed | S1598002 rev. B dated 13/12/2023 ID 1 |
| 48-166 | Unexposed | S1598002 rev. B dated 13/12/2023 ID 2 |
1.3 - A-0 Bulkhead
| (OD) [mm] | |||
| 16-225 | Exposed | S1598001 rev. A dated 31/10/2023 ID 3 | |
| ABS | 16 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 7 |
| 114 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 4 | |
| Beverage | 100 | Exposed | S1598001 rev. A dated 31/10/2023 ID 3 |
| multipipe | 100 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 4 |
| 16-160 | Exposed | S1598001 rev. A dated 31/10/2023 ID 3 | |
| PB | 16-225 | Exposed | S1598001 rev. A dated 31/10/2023 ID 5 |
| 16-160 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 4 | |
| 16-225 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 6 | |
| 16 | Exposed | S1598001 rev. A dated 31/10/2023 ID 5 | |
| PE / HDPE | 200-225 | Exposed | S1598001 rev. A dated 31/10/2023 ID 3 |
| 16-225 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 4 | |
| 315 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 10 | |
| PE / ALU / PE | 16-63 | Exposed | S1598001 rev. A dated 31/10/2023 ID 1 |
| 16-63 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 2 | |
| 20-169 | Exposed | S1598001 rev. A dated 31/10/2023 ID 1 | |
| PP / PPR / PPML | 32-200 | Exposed | S1598001 rev. A dated 31/10/2023 ID 3 |
| / PPFR | 20-169 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 1 |
| 16-110 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 8 | |
| 40-200 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 4 | |
| Pre-insulated pipe | 75-315 | Exposed | S1598001 rev. A dated 31/10/2023 ID 9 |
| (OD) [mm] | |||
| 16-160 | Exposed | S1598001 rev. A dated 31/10/2023 ID 1 | |
| 16-322 | Exposed | S1598001 rev. A dated 31/10/2023 ID 3 | |
| PVC | 16-160 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 2 |
| 16-200 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 4 | |
| 271-322 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 7 | |
| PVDF | 169 | Exposed | S1598001 rev. A dated 31/10/2023 ID 3 |
| 169 | Unexposed | S1598001 rev. A dated 31/10/2023 ID 4 |
1.4 - A-0 Deck
| (OD) [mm] | |||
| 16-219 | Exposed | S1598003 rev. A dated 31/10/2023 ID 3 | |
| ABS | 225 | Exposed | S1598003 rev. A dated 31/10/2023 ID 5 |
| 16 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 4 | |
| Beverage | 100 | Exposed | S1598003 rev. A dated 31/10/2023 ID 3 |
| multipipe | 75-100 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 4 |
| PB | 16-225 | Exposed | S1598003 rev. A dated 31/10/2023 ID 3 |
| 16-225 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 4 | |
| 16 | Exposed | S1598003 rev. A dated 31/10/2023 ID 5 | |
| PE / HDPE | 16 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 6 |
| 125-225 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 4 | |
| 16-63 | Exposed | S1598003 rev. A dated 31/10/2023 ID 1 | |
| PE / ALU / PE | 16-63 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 4 |
| 63 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 2 | |
| PP / PPR / PPML | 16-320 | Exposed | S1598003 rev. A dated 31/10/2023 ID 3 |
| / PPFR | 16-110 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 4 |
| Pre-insulated pipe | 75-315 | Exposed | S1598003 rev. A dated 31/10/2023 ID 7 |
| 16-50 | Exposed | S1598003 rev. A dated 31/10/2023 ID 1 | |
| 16-225 | Exposed | S1598003 rev. A dated 31/10/2023 ID 3 | |
| PVC | 315-321 | Exposed | S1598003 rev. A dated 31/10/2023 ID 8 |
| 50-63 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 2 | |
| 16-160 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 4 | |
| 271-321 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 9 | |
| PVDF | 48-166 | Exposed | S1598003 rev. A dated 31/10/2023 ID 3 |
| 48-166 | Unexposed | S1598003 rev. A dated 31/10/2023 ID 4 |
2. DOCUMENTS AND DRAWINGS:
As per the Manufacturer’s insulation drawings quoted in tables in §1.
3. TEST REPORTS:
3.1 - A-60 Bulkhead
| Test report N° | Dated | Laboratory |
| 313700 | 30th January 2012* | Exova Warringtonfire, UK |
| 314670 | 25th June 2012 | Exova Warringtonfire, UK |
| 316943 | 2012* | Exova Warringtonfire, UK |
| 327509 | 10th July 2013 | Exova Warringtonfire, UK |
| 177105A | 6th January 2009* | Bodycote Warringtonfire, UK |
| 180251A | 26th May 2009* | Bodycote Warringtonfire, UK |
| 183387A | 23rd October 2009* | Bodycote Warringtonfire, UK |
| 198004A | 7th December 2010* | Bodycote Warringtonfire, UK |
| 303585A | 7th April 2011* | Exova Warringtonfire, UK |
| 5P00772 | 10th December 2015 | SP, Sweden |
| 6P10024 | 7th March 2017 | SP, Sweden |
| 7P02024 | 8th June 2017 | SP, Sweden |
| PGA10870A | 13th December 2016 | DBI, Denmark |
| PGB10167A | 18th March 2022 | DBI, Denmark |
| PGB10218A | 10th July 2023 | DBI, Denmark |
| RS-18/B-264/E | 14th September 2018 | CTO, Poland |
| RS-19/B-424/E | 27th November 2019 | CTO, Poland |
| RS-21/B-518/E | 15th December 2021 | CTO, Poland |
| RS-21/B-241/E | 31st June 2021 | CTO, Poland |
| RS-23/B-105/E | 23rd May 2023 | CTO, Poland |
| RS-23/B-106/E | 23rd May 2023 | CTO, Poland |
| RS-23/B-224/E | 2nd October 2023 | CTO, Poland |
| RS-23/B-225/E | 30th August 2023 | CTO, Poland |
| RS-23/B-340/E | 3rd November 2023 | CTO, Poland |
| PGB10030A | 16th July 2020 | DBI, Denmark |
| All tests as per IMO 2010 FTP Code, Annex 1, part 3, except * as per IMO FTP Code, Annex 1, part 3 [test standard: IMO |
Resolution A.754(18)].
3.2 - A-60 Deck
| 314669 | 26th April 2012* | Bodycote Warringtonfire, UK |
| 325332 | 10th July 2013 | Bodycote Warringtonfire, UK |
| 334429 | 13rd August 2013 | Bodycote Warringtonfire, UK |
| 170080B | 30th April 2008* | Bodycote Warringtonfire, UK |
| 175486A | 31st October 2008* Bodycote Warringtonfire, UK | |
| 190890A_2 | 26th May 2010* | Exova Warringtonfire, |
| UK | ||
| 320402A | 29th October 2012 | Exova Warringtonfire, UK |
| 5P00771 | 25th November 2015 | SP, Sweden |
| 6P02249 | 17th August 2017 | SP, Sweden |
| 6P10022 | 7th March 2017 | SP, Sweden |
| 878/07/A/NP/R 102 | 28th March 2007* | DGA, France |
| PGA10871A rev 2 | 16th January 2018 | DBI, Denmark |
| PGA11611A | 11th January 2020 | DBI, Denmark |
| PGB10047A | 30th November 2020 | DBI, Denmark |
| PGB10172A | 17th June 2022 | DBI, Denmark |
| PGB10177A | 4th November 2022 | DBI, Denmark |
| RS-18/B-265/E | 17th September 2018 | CTO, Poland |
| RS-19/B-356/E | 18th October 2019 | CTO, Poland |
| RS-22/B-153/E | 4th May 2022 | CTO, Poland |
| RS-22/B-337/E | 28th October 2022 | CTO, Poland |
| PGB10032A | 1st July 2020 | DBI, Denmark |
3.3 - A-0 Bulkhead
| 337717 | 13rd May 2014 | Exova Warringtonfire, UK |
| 198004A | 7th December 2010* | Exova Warringtonfire, UK |
| 303584A | 7th April 2011* | Exova Warringtonfire, UK |
| 307171A_2 | 17th June 2011* | Exova Warringtonfire, UK |
| 309855A | 23rd December 2011* | Exova Warringtonfire, UK |
| RS-19_B-423E | 19th November 2019 | CTO, Poland |
| RS-20/B-081/E | 31st March 2020 | CTO, Poland |
3.4 - A-0 Deck
| 329449 | 13rd August 2013 | Exova Warringtonfire, UK |
| 309638A | 20th September 2011* | Exova Warringtonfire, UK |
| 8P07092 rev. 1 | 16th January 2020 | RISE, Sweden |
| PGA11388A | 14th August 2019 | DBI, Denmark |
| PGB10110A | 27th April 2021 | DBI, Denmark |
| PGB10169A | 18th March 2022 | DBI, Denmark |
4. APPLICATION / LIMITATION:
4.1 - Approved for use as plastic pipes penetrations:
- in A-60 class steel divisions, with fire insulation as described in §1,
- in A-0, A-15, A-30 class steel divisions, with local fire insulation arrangement (on the penetration itself as described in §1
and 200 mm around).
4.2 - The pipe penetration system has only been evaluated with regard to its fire resistance only. For installation in watertight
bulkhead below the bulkhead deck, specific rules may require to subject the pipe penetrations to a prototype test of
watertightness after having undergone the standard fire test for A-class divisions described in IMO 2010 FTP Code Annex 1
Part 3.
5.1 - The Roxtec sealing system: Sleev-it are to be supplied by ROXTEC International AB in compliance with the type
described in this certificate.
5.4 - For information, ROXTEC International AB has declared to Bureau Veritas the following production site(s):
Rombvägen 2
371 23 KARLSKRONA
The product or packing is to be marked with name of manufacturer, type designation and fire technical rating.
7. OTHERS:
7.2 - Watertightness and Gastightness:
- For FC MAR (sizes 16-160) - Survey report N° LDN-08-045 dated 09/05/2008 from DNV:
- Tested watertightness (before fire exposure) with Marine graded sealant: 1.5 bar during 60 min.
- Tested gastightness (before fire exposure) with Marine graded sealant: 30 mbar during 30 min.
- For WT MAR (sizes 16-110) - Survey report N° SOU 0901586/1 dated 08/01/2010 from LR:
- Tested watertightness (before fire exposure): 3.5 bar during 30 min.
- Tested gastightness (before fire exposure): 1 bar during 30 min.
7.3 - This Certificate supersedes the Type Approval Certificate N° 46204/A2 BV issued on 12/04/2021by the Society.
