52630_B0 BV-optimized
Certificate number: 52630/B0 BV
File number: ACI 4010/030/006
Product code: 5301H
Roxtec sealing system: Roxtec SPM seal series in Aluminium divisions
SOLAS 74, as amended, Regulations II-2/9.3.1
IMO Res MSC.307(88) (2010 FTP Code)
This certificate will expire on: 19 Oct 2028
At BV COPENHAGEN, on 19 Oct 2023,
Hans-erik ERICSSON
signature
BV Mod. Ad.E 530 June 2017 This certificate consists of 3 page(s)
1. PRODUCT DESCRIPTION :
“Roxtec sealing system, Roxtec SPM seal series (Aluminium divisions)”
Consisting of Roxtec SPM rubber seal, attached through expansion to aluminium divisions.
Additional insulation on penetrations:
  • should be approved as having the same level of performance as the penetrated division and expected classification of
penetration,
  • is to be fitted as shown in the referred Manufacturer’s drawings and also according to Manufacturer’s insulation guidelines.
1.1 - A-60 bulkhead
Seal Size Pipe Pipe service Sleeve Insulation drawing
material diameter (mm) position
SPM 39-279 Steel / 8-222 Any S1592852 Rev. A dated 15/06/2023
Titanium ID 1-4
SPM 39-157 Copper / 8-110 Any S1592853 Rev. A dated 15/06/2023
Cu/Ni ID 1-3
1.2 - A-60 deck
SPM 39-279 Steel / 8-222 Any S1592854 Rev. A dated 16/06/2023
Titanium ID1-4
SPM 39-157 Copper / 8-110 Any S1592855 Rev. A dated 15/06/2023
Cu/Ni ID 1-2
  1. DOCUMENTS AND DRAWINGS :
As per the Manufacturer’s insulation drawings quoted in tables in §1.
3. TEST REPORTS :
3.1- A-60 bulkhead
Test report N° Dated Laboratory
RS-17/B-209/E June 2, 2017 CTO, Poland
| RS-18/B-180/E | June 25, 2018 | CTO, Poland |
| PGA11370A | February 20, 2019 | DBI, Denmark |
3.2- A-60 deck
RS-17/B-210/E June 2, 2017 CTO, Poland
| RS-18/B-179/E | June 25, 2018 | CTO, Poland |
| PGA11371A | February 20, 2019 | DBI, Denmark |
All test reports being as per IMO FTP Code 2010, Annex 1, Part 3.
4. APPLICATION / LIMITATION :
4.1 - The fitting aboard to be the same as used for the test.
4.2 - Approved for use as steel or copper pipe penetrations:
  • in A-15, A-30, A-60 class aluminium divisions, with fire insulation as described in §1,
  • in A-0 class aluminium divisions, with local fire insulation arrangement (on the penetration itself as described in §1 and
200 mm around).
5.1 - The SPM seals are to be supplied by Roxtec International AB in compliance with the type described in this certificate.
  1. 2 -This type of product is within the category HBV of Bureau Veritas Rule Note NR320 and as such does not require a BV
5.3 - Roxtec International AB has to make the necessary arrangements to have its office and production site(s) recognised by
Bureau Veritas in compliance with the requirements of NR320 for HBV products.
The product or packing is to be marked with manufacturer name, type designation and fire technical rating.
7. OTHERS :
7.1 - It is Roxtec International AB’s responsibility to inform shipbuilders or their sub-contractors of the proper methods of
7.2 - This Certificate supersedes the Type Approval Certificate N°52630/A0 BV issued on 24/09/2018 by the Society.
7.3 - Watertightness and Gastightness for SPM seals: Inspection report N° N1419WS4, dated June 21, 2016 and N° N141805A,
dated December 20, 2016, both from DNV-GL:
• Tested watertightness : 1,5 bar during 60 min.
• Tested gastightness : 1 bar during 30 min.
