Hello,
I have encountered a recurring issue when using the Autoplace by Category feature in Roxtec Transit Designer.
When I use Autoplace by Category, I frequently receive the following error message:
“Autopack could not place all modules. Autopack does not place a module above a row of smaller modules.”
However, when I apply a filter for a specific category, select all modules within that category, and drag and drop them into the frame manually, the modules are inserted in the wrong order.
Based on this behavior, I suspect that the modules may also be processed or sorted in the wrong order when using Autoplace by Category. This could potentially explain why the automatic placement fails, even when the modules should theoretically fit into the available space.
Steps to Reproduce
- Open a frame in Roxtec Transit Designer.
- Use the Autoplace by Category function.
- Observe that the operation frequently fails with the error message mentioned above.
- Alternatively, filter the modules by category.
- Select all modules in the filtered category.
- Drag and drop the selected modules into the frame.
- Observe that the modules are inserted in an incorrect order.
Expected Result
The modules should be sorted and placed in the correct order, both when using Autoplace by Category and when manually inserting multiple modules via drag and drop.
Actual Result
- Autoplace by Category frequently fails with the message that modules cannot be placed above a row of smaller modules.
- When multiple modules are selected and dragged into the frame, they are inserted in the wrong order.
Suspected Cause
I suspect that both issues may be related to an incorrect module sorting or placement sequence. If Autoplace by Category uses the same ordering logic as the drag-and-drop operation, this could cause the automatic placement process to fail.
See the attached screenshot for an example of the module arrangement and the affected areas.
Could you please investigate whether the module sorting or placement sequence is causing this issue?
Thank you for your support.
