LAB115218CS-001-002-optimized
No. LAB115218CS/001
This is to certify that the product identified below is in compliance with the
regulations herewith specified.
Description Devices for the passage of pipes through A or B
Class divisions
Type Roxtec SLEEV-IT FC MAR ALU on aluminium
bulkheads
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Reference standardsIMO Res. MSC.307(88)-(2010 FTP Code)
Issued in Genoa on May 10, 2018. This Certificate is valid until May 9, 2023
No. LAB115218CS/001
Enclosure - Page 1 of 2
Roxtec SLEEV-IT FC MAR ALU on aluminium bulkheads
Device for the passage of plastic pipes (not reinforced and multilayer) through A Class
aluminium bulkheads composed of a stainless steel tubular casing fitted with aluminium flange
tack welded to the bulkhead plate. The castings are provided of a break in order to permit the
insertion of pipe and intumescing material and have a toggle clip arrangement located at the
break in order to secure the casings around the pipes. The division insulation covers also the
transits that may be fitted with additional insulation, laid upon the bulkhead insulation on the
side not exposed to the fire.
Fire resistant A-60 Class plastic pipe penetrations through aluminium bulkheads as per
following tables:
Bulkheads insulated on both sides by means of two layers of mineral wool 30 mm thick each
and having density of 130 kg/m3.
TYPE OF TRANSITS - PIPE DIAMETER ADDITIONAL TRANSIT
INSULATION FIXING AND
NOTES
Transits from SLEEV-IT FC-MAR16M ALU up to No Seal fitted on the
SLEEV-IT FC-MAR110M ALU additional exposed or
pipe diameter from 16 mm up to 110 mm insulation unexposed side.
Transits greater than SLEEV-IT FC-MAR110M ALU up to No Seal fitted on the
SLEEV-IT FC-MAR225M ALU - pipe diameter greater additional exposed side
than 110 mm up to 225mm insulation
Bulkheads insulated on both sides by means of two layers of mineral wool 40 mm thick each
and having density of 100 kg/m3.
TYPE OF TRANSITS - PIPE ADDITIONAL INSULATION TRANSIT FIXING
DIAMETER AND NOTES
Transits from SLEEV-IT FC- Two layers of mineral wool 40 mm Seal fitted on the
MAR160M ALU up to SLEEV-IT thick each and having density of 100 exposed or
FC-MAR200M ALU kg/m3 and width of 100 mm around unexposed side.
pipe diameter from 160 mm up to the pipe in case of seal fitted on the Transits fitted with
200 mm unexposed side
Transits greater than SLEEV-IT Two layers of mineral wool 40 mm Seal fitted on the
FC-MAR200M ALU up to thick each and having density of 100 unexposed side.
SLEEV-IT FC-MAR225M ALU - kg/m3 and width of 100 mm around Transits fitted with
pipe diameter greater than 200 the pipe
mm up to 225mm
No. LAB115218CS/001
Enclosure - Page 2 of 2
Roxtec drawings included in DBI Report No. PGA10801A dated 29 August 2016 and in CTO
Report No. RS-17/B-555/E dated 15 January 2018.
Tests as per DBI Report No. PGA10801A dated 29 August 2016 and CTO Report No. RS-
17/B-555/E dated 15 January 2018 issued according to IMO 2010 FTP Code - Annex 1 - Part
3.
b) Any changes to the initial conditions are to be promptly communicated to RINA, which reserves the right to
repeat the relevant assessment
c) This certificate will no be valid if the manufacturer makes any changes or modifications to the approved
equipment, which have not been notified to, and agreed with RINA
f) Should the specified regulations or standards be amended during the validity of this certificate, the product is to be
reapproved prior to it being placed on board vessels to which the amended regulations or standards apply.
Genoa 10/05/2018
No. LAB115218CS/002
Class divisions
Type Roxtec SLEEV-IT FC MAR ALU on aluminium decks
SE-37123 KARLSKRONA
SE-37123 KARLSKRONA
No. LAB115218CS/002
aluminium decks composed of a stainless steel tubular casing fitted with aluminium flange
welded to the deck plate. The casings are provided of a break in order to permit the insertion
of pipe and intumescing material and have a toggle clip arrangement located at the break in
order to secure the casings around the pipes. Decks insulated on the side exposed to the fire
by means of two layers of mineral wool 30 mm thick each and having density of 130 kg/m3.
The division insulation covers also the transits when installed on the exposed side.
Fire resistant A-60 Class plastic pipe penetrations through aluminium decks as per following
tables:
TYPE OF TRANSITS - PIPE ADDITIONAL TRANSIT FIXING AND NOTES
DIAMETER INSULATION
Transit SLEEV-IT FC-MAR16M No additional Seal fitted on the exposed or
ALU - pipe diameter 16 mm insulation
without Roxtec Fire Sealant
Transits from SLEEV-IT FC- No additional
MAR16M ALU up to SLEEV-IT insulation
FC-MAR225M ALU
225 mm
Transits from SLEEV-IT FC- No additional Seal fitted on the exposed side.
MAR16M ALU up to SLEEV-IT insulation Transits fitted with Roxtec Fire Sealant
FC-MAR225M ALU
225mm
No. LAB115218CS/002
Roxtec drawings included in DBI Report No. PGA10802A dated 29 August 2016 and in CTO
Report No. RS-17/B-210/E dated 2 June 2017.
Tests as per DBI Report No. PGA10802A dated 29 August 2016 and CTO Report No. RS-
17/B-210/E dated 2 June 2017 issued according to IMO 2010 FTP Code - Annex 1 - Part 3.
Genoa 10/05/2018
