LAB115218CS-003-optimized
No. LAB115218CS/003
This is to certify that the product identified below is in compliance with the
regulations herewith specified.
Description Devices for the passage of pipes through A or B
Class divisions
Type Roxtec SLEEV-IT WT MAR ALU on aluminium decks
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Reference standardsIMO Res. MSC.307(88)-(2010 FTP Code)
Issued in Genoa on May 10, 2018. This Certificate is valid until May 9, 2023
No. LAB115218CS/003
Enclosure - Page 1 of 1
Device for the passage of plastic pipes (not reinforced and multilayer) through A Class
aluminium decks composed of a stainless steel tubular casing fitted with aluminium flange
welded to the deck plate. Decks insulated on the side exposed to the fire by means of two
layers of mineral wool 30 mm thick each and having density of 130 kg/m3. The deck
insulation covers also the transits.
Fire resistant A-60 Class plastic pipe penetrations through aluminium decks as per following
tables:
TYPE OF TRANSITS - PIPE DIAMETER ADDITIONAL TRANSIT FIXING
INSULATION AND NOTES
Transits from SLEEV-IT WT-MAR16M ALU up No additional Seal fitted on the
to SLEEV-IT WT-MAR225M ALU insulation exposed side.
pipe diameter from 16 mm up to 225 mm
Roxtec drawings included in DBI Report No. PGA10802A dated 29 August 2016 and in CTO
Report No. RS-17/B-210/E dated 2 June 2017.
Tests as per DBI Report No. PGA10802A dated 29 August 2016 and CTO Report No. RS-
17/B-210/E dated 2 June 2017 issued according to IMO 2010 FTP Code - Annex 1 - Part 3.
Note: Transits SLEEV-IT WT-MAR16M and SLEEV-IT WT-MAR225M were subjected to
hydrostatic test (water - 1.5 bar) for 60 minutes and gas-tightness test (helium - 1 bar) for 30
minutes without any leakage - Tests as per DNV-GL Survey Report No. N141EX90 dated 30
June 2017.
b) Any changes to the initial conditions are to be promptly communicated to RINA, which reserves the right to
repeat the relevant assessment
c) This certificate will no be valid if the manufacturer makes any changes or modifications to the approved
equipment, which have not been notified to, and agreed with RINA
f) Should the specified regulations or standards be amended during the validity of this certificate, the product is to be
reapproved prior to it being placed on board vessels to which the amended regulations or standards apply.
Genoa 10/05/2018
