No. LAB167420CS/003
| Description | Devices for the passage of pipes through A or B Class |
| divisions | |
| Type | Roxtec Sleeve it Marine Fire Collar B |
| ROMBVAGEN 2, BOX 540 | |
| SE-37123 Karlskrona |
| Place of manufacture | ROMBVAGEN 2, BOX 540 |
| Reference standards | IMO Res. MSC.307(88)-(2010 FTP Code) |
Issued in Genoa on September 15, 2020. This Certificate is valid until September 15, 2025
No. LAB167420CS/003
Enclosure - Page 1 of 2
Roxtec S leeve it Marine Fire Collar B
Devices for the passage of plastic pipes, steel ducts and electric cables through B Class bulkhead as described in the
following tables; the devices consist of a tubular or square casing fixed to the bulkhead by means of pigtail screws or
bolts. The casings are provided with a break in order to permit the insertion of pipe and intumescing material and have a
toggle clip arrangement located at the break used to secure the casings around the pipes.
Plastic pipes having diameter ranging from 16 up to 125 mm
| DIAM ETER / | TYPE OF CASING | EXPOSED SIDE / | INTUM ESCING | CLASS |
| DIAM ETER RANGE | UNEXPOSED SIDE | M ATERIAL TYPE AND | ||
| (mm) | THICKNESS - NO. OF | |||
| LAYERS OF INT. | ||||
| M ATERIAL | ||||
| 16 | Stainless steel - 60 mm | Exposed side or | INTUM EX L – 2.5 mm - | B-15 |
| long | unexposed side | No. 2 layers | ||
| 20 up to 32 | Stainless steel - 60 mm | Exposed side or | INTUM EX L – 2.5 mm - | B-15 |
| long | unexposed side | No. 3 layers | ||
| 125 | Stainless steel | Exposed side or | INTUM EX L – 2.5 mm - | B-15 |
| 60 mm long | unexposed side - When | No. 5 layers | ||
| fitted on the exposed side | ||||
| the fixing to the bulkhead | ||||
| is to be carried out by | ||||
| means of four 5 x 30 mm | ||||
| long steel threaded bolts | ||||
| with hexagon nut instead | ||||
| of four pigtail screws |
Steel ducts having diameter of 100 and 250 mm
| DIAM ETER / | TYPE OF CASING | INSTALLATION | INTUM ESCING | CLASS |
| DIAM ETER RANGE | M ATERIAL TYPE AND | |||
| M ATERIAL | ||||
| 100 | mild steel - 60 mm long to Flange in the middle of the INTUM EX L – 2.5 mm - | B-15 | ||
| each bulkhead side | casing fitted on either side | No. 4 layers | ||
| of the bulkhead | ||||
| 250 | mild steel - 120 mm long | Flange in the middle of the INTUM EX L – 2.5 mm - | B-15 | |
| to each bulkhead side | casing fitted on either side | No. 8 layers | ||
| of the bulkhead |
No. LAB167420CS /003
Enclosure - Page 2 of 2
Electric cables having diameter ranging from 9 mm up to 22 mm
| DIAM ETER / | TYPE OF CASING - | INSTALLATION | INTUM ESCING | CLASS |
| DIM ENSIONS (mm) | FILLING M ATERIAL | M ATERIAL TYPE AND | ||
| THICKNESS - NO. OF | ||||
| M ATERIAL | ||||
| 75 | stainless steel - 60 mm | Flange fitted on the | INTUM EX L – 2.5 mm - | B-15 |
| long | unexposed side - casing | No. 4 layers | ||
| M allowrap M oulding | fitted through the | |||
| Compound 1190 (beige | bulkhead | |||
| mastic) | ||||
| 100 x 100 | mild steel - 60 mm long to Flange in the middle of the INTUM EX L – 2.5 mm - | B-15 | ||
| M allowrap M oulding | of the bulkhead | |||
| Compound 1190 (beige | ||||
| mastic) | ||||
| 16 | plastic - 30 mm long | Flange fitted on the | Sleev-it intumescent putty | B-15 |
| unexposed side - casing | (red) | |||
| fitted through the | ||||
| bulkhead | ||||
| 32 | plastic - 35 mm long | Flange fitted on the | Sleev-it intumescent putty | B-15 |
| bulkhead | ||||
| Field of application | ||||
| Fire resistant B Class plastic pipe / steel duct penetration and B Class cable transit through B-15 Class bulkhead type | ||||
| shown in VTT test report No. VTT-S-5026-10 dated on 13 September 2010. | ||||
| Reference documents | ||||
| SLEEV-IT drawings as included on VTT test report No. VTT-S-5026-10 dated 13 September 2010 and on VTT |
Statement No. VTT-S-65599-10 dated 27 August 2010.
Tests as per VTT Report No. VTT-S-5026-10 issued on 13 September 2010 according to IMO Resolution A.754(18)
and as per VTT Statement No. VTT-S-65599-10 dated 27 August 2010.
This certificate annuls and replaces the certificate No. LAB174915CS/003 dated 15/9/2015 due to renewal.
