LAB180318CS-002-optimized
No. LAB180318CS/002
Description Devices for the passage of electric cables through A or B
Class divisions
Type Roxtec S Series - Steel Deck
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Issued in Genoa on December 19, 2018. This Certificate is valid until December 18, 2023
No. LAB180318CS/002
Enclosure - Page 1 of 2
Roxtec S S eries - S teel Deck
Devices for the passage of electric cables having diameter ranging from 10 up to 86 mm through A Class decks. The
transits are composed of a steel frame having thickness of 10 mm fillet welded to the deck plate and filled with EPDM
halogen free material packing system; on the upper part it is installed one module fitted with a screw expander. The
deck is insulated by means of two layers of mineral wool (certified non combustible in compliance to 2010 FTP Code)
50+30 mm thick and having density of 125 kg/m3.
Roxtec drawings enclosed in SP Test Reports No. 6P02249 dated 17 August 2016, No. 6P07563 dated 20 December
2016, No. 6P10022 dated 7 March 2017 and Research Institute of Marine Engineering Test Report No. 09-346 dated 11
December 2009.
Tests as per SP Test Reports No. 6P02249 dated 17 August 2016, No. 6P07563 dated 20 December 2016, No.
December 2009 issued according to IMO 2010 FTP Code and IMO Res. A.754 (18).
No. LAB180318CS /002
Enclosure - Page 2 of 2
Fire resistant A-60 Class cable transits through A Class decks as per following table:
TYPE OF TRANSITS Fill Cable diameter ADDITIONAL TRANSIT FIXING
% INSULATION AND NOTES
SRC r20 8x1 21 from 10 up to 86 mm No additional Penetr. fix. to deck
insulation plate in the middle.
SRC r20 2x1 from 4 up to 18 from 10 up to 86 mm No additional Penetr. fix. to deck
SRC r60 4x1 1 10 mm No additional Penetr. fix. to deck
S 1x1 3 10 mm No additional Penetr. fix. to deck
SRC r40 8x1 31 from 31 up to 53 mm Mineral wool, two Penetr. fix. to deck
layers 30 mm thick plate on exposed side;
each, density of 125 addit. insul. fitted on
kg/m3, width of 100 deck insul. side.
mm all around
S 1x1 26 45 mm Mineral wool, two Penetr. fix. to deck
mm all around
S 8+8x3 28 from 21 up to 53 mm Min. wool, two layers Penetr. fixed to the
30 mm thick each, deck plate on exposed
density of 125 kg/m3, side; the additional
width of 100 mm all insul. is fitted on deck
around and on the insulated side.
modules with a screw
exp.
S 8x1 31 from 21 up to 53 mm Mineral wool, two Penetr. fix. to deck
mm all around
SF 8x1 31 from 21 up to 53 mm Mineral wool, two Penetr. fix. to deck
mm all around
Genoa December 19, 2018
