No. LAB484722CS/003
This is to certify that the product identified below satisfies the requirements of the
standard quoted under “Reference standard”
| Description | Devices for the passage of electric cables through A or B |
| Class divisions | |
| Type | ROXTEC R-Series - SLFR X type |
| ROMBVAGEN 2, BOX 540 | |
| SE-37123 Karlskrona |
| Place of manufacture | ROMBVAGEN 2 |
| 37165 LYCKEBY |
| Reference standards | IMO Res. MSC.307(88)-(2010 FTP Code) - Part. 3 |
Issued in Genoa on June 13, 2023. This Certificate is valid until June 12, 2028
No. LAB484722CS/003
Enclosure - Page 1 of 2
ROXTEC R-S eries - S LFR X type
Devices for the passage of electric cables having maximum diameter of 83 mm through A Class bulkheads and decks.
The devices are composed of rubber designated Roxylon inserted in a circular steel frame (SLFR X), 6 mm thick, and
fitted inside with RM Modules. The transits are insulated as follows:
Decks - one layer of mineral wool (certified non-combustible according to the IMO FTP Code) having minimum
thickness of 50 mm and minimum density of 100 kg/m3 fitted on the lower side.
Bulkheads - two layers of mineral wool (certified non-combustible according to the IMO FTP Code) having, each,
minimum thickness of 45 mm thick and minimum density of 90 kg/m3 fitted on the non-fire hazard side.
On decks and bulkheads the mineral wool covers the transits and is applied all around the transits for a minimum width
of 250 mm.
The transits may be fitted with additional insulation as described in the following table:
BULKHEAD
| Transit type | Fill | Cables - | TRANSIT FIXING AND NOTES |
| % | Maximum | ||
| diameter |
(mm)
| R70 | 8.20 | 10 | The penetration is fixed on the unexposed side; additional insulation |
| composed of two layers of the same mineral wool, having width of 200 | |||
| mm, is to be fitted around the cables | |||
| R200 | 13 | 67 | The penetration is fixed on the unexposed side; additional insulation |
DECK
| % | Maximum | ||
| diameter |
(mm)
| R75 | 3.6 | 10 | The penetration may be fixed on the exposed and unexposed side; |
| additional insulation composed of the deck insulation, having width of | |||
| 150 mm, is to be fitted around the cables | |||
| R200 | 17.2 | 83 | The penetration may be fixed on the exposed and unexposed side; |
No. LAB484722CS /003
Enclosure - Page 2 of 2
Fire resistant A-60 Class cable transits through A Class bulkheads; fire risk on the uninsulated side.
Fire resistant A-60 Class cable transits through A Class decks.
Roxtec drawings enclosed in CTO Test Reports No. RS-18/B/-485/E dated 10 December 2018 and No. RS-19/B-255/E
dated 20 August 2019 and SP Test Report No. 7P02167 dated 7 August 2017.
Tests as per CTO Test Reports No. RS-18/B/-485/E dated 10 December 2018 and No. RS-19/B-255/E dated 20 August
2019 and SP Test Report No. 7P02167 dated 7 August 2017 issued according to 2010 FTP Code.
