LAB498522CS-002-optimized
No. LAB498522CS/002
divisions
Type Roxtec SLEEV-IT FC MAR ALU on aluminium decks
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2,
37165 LYCKEBY
Issued in Genoa on June 5, 2023. This Certificate is valid until May 9, 2028
No. LAB498522CS/002
Enclosure - Page 1 of 2
Roxtec S LEEV-IT FC MAR ALU on aluminium decks
Device for the passage of plastic pipes (not reinforced and multilayer) through A Class aluminium decks composed of a
stainless steel tubular casing fitted with aluminium flange welded to the deck plate. The casings are provided of a break
in order to permit the insertion of pipe and intumescing material and have a toggle clip arrangement located at the break
in order to secure the casings around the pipes. Decks insulated on the side exposed to the fire by means of two layers
of mineral wool (certified non combustible according to the IMO FTP CODE), having minimum thickness of 30 mm
and minimum density of 130 kg/m3. The deck insulation covers also the transits, when installed on the exposed side,
and is applied all around the same for a minimum width of 250 mm.
Fire resistant A-60 Class plastic pipe penetrations through aluminium decks as per following tables:
TYPE OF TRANSITS - PIPE DIAMETER ADDITIONAL TRANSIT FIXING AND NOTES
INSULATION
Transit SLEEV-IT FC-MAR16M ALU - pipe No additional Seal fitted on the exposed or unexposed side.
diameter 16 mm insulation Transits fitted with or without Roxtec Fire Sealant
Transits from SLEEV-IT FC-MAR16M ALU up No additional Seal fitted on the unexposed side.
to SLEEV-IT FC-MAR225M ALU insulation
pipe diameter from 16 mm up to 225 mm
Transits from SLEEV-IT FC-MAR16M ALU up No additional Seal fitted on the exposed side. Transits fitted with
to SLEEV-IT FC-MAR225M ALU insulation Roxtec Fire Sealant
pipe diameter from 16 mm up to 225mm
No. LAB498522CS /002
Enclosure - Page 2 of 2
Roxtec drawings included in DBI Report No. PGA10802A dated 29 August 2016 and in CTO Report No. RS-17/B-
210/E dated 2 June 2017.
Tests as per DBI Report No. PGA10802A dated 29 August 2016 and CTO Report No. RS-17/B-210/E dated 2 June
2017 issued according to IMO 2010 FTP Code - Annex 1 - Part 3.
Genoa 5/06/2023
