LR2387043MB-optimized
Certificate No: LR2387043MB
Issue Date: 01/03/2023
Expiry Date: 29/02/2028
Notified Body authorised by
BSH 0800-S23/4822: 013
EC Type Examination (Module B) Certificate
USCG-EU MRA
This is to certify that:
LLOYD’S REGISTER Marine Deutschland GmbH (LRMD), designated as a “notified body” based on the notification of the Federal
Maritime and Hydrographic Agency of Germany, did undertake the relevant type approval procedures for the type of equipment
identified below which was found to be in compliance with the requirements of Marine Equipment Directive (MED) 2014/90/EU
and the valid Commission Implementing Regulation (EU) in force indicating design, construction and performance requirements
and testing standards for marine equipment, subject to the conditions below and the attached Schedule which also forms part of
this Certificate.
Address Box 540, S-37123 Karlskrona, Sweden
| Reference | Marine Equipment Directive (MED) 2014/90/EU, Regulation (EU) 2022/1157 |
Regulation Item (No. & MED/3.26a Penetrations Through ‘A’ Class Divisions: Electric Cable Transits
Item Designation) MED/3.26b Penetrations Through ‘A’ Class Divisions - Pipe, Duct, Trunk Etc.
Penetrations
MED/3.37a Penetrations Through Fire Resisting Divisions on High Speed Craft -
electric cable transits
MED/3.37b Penetrations Through Fire Resisting Divisions on High Speed Craft -
Pipe, Duct, Trunk Etc. Penetrations
Product Type CABLE and PIPE PENETRATION
| Product Description | Multi Cable and Pipe Penetration Types: “S, R, RS, and RS PPS/S” for use in |
fibre reinforced composite bulkheads and decks
Specified Standard IMO Res. MSC.307(88) (2010 FTP Code) Annex 1 Part 3
IMO Res. MSC.307(88) (2010 FTP Code) Annex 1 Part 11.
IMO/MSC/Circ. 1488
Trade Name “S, R, RS and RS PPS/S ”
Lloyd’s Register Marine Deutschland
Keith Taylor
GmbH, Überseeallee 10, D-20457
Hamburg, Germany. Team Lead Fire & Safety
A member of the Lloyd’s Register group For and on behalf of Lloyd’s Register Marine
Deutschland GmbH (2923)
Lloyd’s Register Group Limited, its affiliates and subsidiaries and their respective officers, employees or agents are, individually and collectively,
referred to in this clause as ‘Lloyd’s Register’. Lloyd’s Register assumes no responsibility and shall not be liable to any person for any loss, damage or
expense caused by reliance on the information or advice in this document or howsoever provided, unless that person has signed a contract with the
relevant Lloyd’s Register entity for the provision of this information or advice and in that case any responsibility or liability is exclusively on the terms
and conditions set out in that contract.
TA145 2.0
The attached Design Appraisal Document (schedule) forms part of this certificate. This certificate remains valid unless suspended, expired or
withdrawn, provided the conditions in the attached schedule are complied with and the equipment remains satisfactory in service.
This certificate will not be valid if the manufacturer makes any changes or modifications to the approved type of equipment, which have not
been notified to and agreed with the notified body named on this certificate. The manufacturer should notify LRMD of any modification or
changes to the equipment in order to obtain a valid Certificate.
This equipment is covered by the scope of the “Agreement between the European Community and the United States of America on Mutual
Recognition of Certificates of Conformity for Marine Equipment” signed on 27 February 2004 and amended by Decision No.1/2018 dated 18
February 2019 according to U.S. Coast Guard approval category USCG Module B number:
164.138/EC2923
A U.S. Coast Guard approval number will be assigned to the equipment when the production module has been completed and will appear on the
production Module certificate (Module D, E or F).
Should the specified regulations or standards be amended during the period of validity of this certificate, the product is to be re-approved prior
being placed on the market and on board vessels to which the amended regulations or standards apply.
The Mark of Conformity may only be affixed to the above type approved equipment and a Manufacturer’s Declaration of Conformity issued when
the production-control phase module (D, E, or F) of ANNEX II of the Directive is fully complied with and controlled by a written inspection
agreement with a notified body.
Hamburg, Germany.
TA145 2.0
Page: 3 of 5
Reference: UKITSO/FIRE/TA/BM/KT/WP45611213/PRJ11100353791
ATTACHMENT TO EC TYPE EXAMINATION (MODULE B) CERTIFICATE No. LR2387043MB
The undernoted documents have been appraised for compliance with the relevant requirements of International Conventions and
European Union legislation for the EC Type Examination of Marine Equipment for use on Merchant Ships Registered in the European
Economic Area.
This Design Appraisal Document (schedule) forms part of the Certificate.
Test Reports
Marine Advanced Research Centre, Gdansk, Poland Test reports RS-20_B_253_E dated 9 July 2020, RS-20_B_254_E dated 4 August 2020, RS-
20_B_341_E dated 22 October 2020, RS-20_B_417_E dated 19 January 2021 and RS-20_B_426_E dated 23 November 2020.
Witness reports N142177N dated 1 September 2020, N142846G dated 2 November 2021 and N141XE2C dated 19 February 2020
Conditions of Certification
1. For use in fibre reinforced composite divisions.
2. Sleeve/frame types SFHM, SRC, SL, SLFRS and SLFR composed of aluminium/steel or GRP with penetrations seal type S, R, RM, RS and
RS PPS/S.
3. Tables below give key parameters for installation in A-60 fibre reinforced composite bulkheads and decks.
Fiber Reinforced Composite Bulkheads A-60
Cable/Pipe
Drawing
Sleeve/Frame type Sleeve/Frame material Penetration size Cable/Pipe Outer diameter (OD)
Reference
[mm]
SL GRP R 50 - R 200 Single/Multi- Cable Up to 82 S1559171
SL GRP RS 25 - RS 125 Single Cable Up to 90 S1559244
SL GRP RS 25 - RS 150 Steel/Titanium Pipe 6-114 S1559174
SL GRP RS 25 - RS 150 Copper Pipe 6-108 S1559174
SL GRP RS PPS/S 50 - RS PPS/S 150 Thermoplastic Pipe* 16-110 S1559249
SL GRP RS PPS/S 50 - RS PPS/S 125 PE/ALU/PE Pipe 16-75 S1559249
SRC GRP 4x1 - 6x1 Single/Multi- Cable Up to 90 S1559156
SRC GRP 4x1 - 6x1 Steel/Titanium Pipe 6-30 S1564191
SLFR Aluminium/Steel R 50 - R 200 Single/Multi- Cable Up to 82 S1559126
SLFRS Aluminium/Steel RS 23 - RS 150 Steel Pipe 6-114 S1559205
SLFRS Aluminium/Steel RS 23 - RS 150 Copper Pipe 6-108 S1559205
SLFRS Aluminium/Steel RS PPS/S 31 - RS PPS/S 150 Thermoplastic Pipe* 16 S1559252
SLFRS Aluminium/Steel RS PPS/S 31 - RS PPS/S 125 PE/ALU/PE Pipe 16-75 S1559252
SLFRS Aluminium/Steel RS 50 - RS 450 Fiberglass Composite Pipe 30-360 S1559245
SFHM Aluminium/Steel 1x1 - 8x1 Single/Multi- Cable Up to 82 S1559116
*Thermoplastic pipe types: (PB, PP/PPR/PPML/PPFR, PE/HDPE & PVC/uPVC/cPVC)
or expense caused by reliance on the information or advice in this document or howsoever provided, unless that person has signed a contract with
the relevant Lloyd’s Register entity for the provision of this information or advice and in that case any responsibility or liability is exclusively on the
terms and conditions set out in that contract.
TA144-145 1.0.0 DAD-DAD MRA Rev00
Page: 4 of 5
Fiber Reinforced Composite Decks A-60
Cable/Pipe
Drawing
Sleeve/Frame type Sleeve/Frame material Penetration size Cable/Pipe type Outer diameter (OD)
Reference
[mm]
SRC GRP 4x1 - 6x1 Single/Multi- Cable Up to 82 S1559156
SLFRS Aluminium/Steel RS PPS/S 31 - RS PPS/S 150 Thermoplastic Pipe* 16-110 S1559252
4. Sample penetrations underwent hydrostatic and pneumatic pressure testing as follows;
Pneumatic Pressure
Penetration Hydrostatic Pressure
(Helium gas)
SRC R20 GRP 1.5 bar
R 50 1.5 bar
R 200 1.5 bar
RS 25 1.5 bar
RS 200 1.5 bar
RS PPS/S 50 1.5 bar
RS PPS/S 150 1.5 bar
| 5. | Penetrations are suitable for use in fibre reinforced composite bulkheads and decks with a heat deflection temperature of 78°C or |
above.
6. Production items of the subject equipment are to be manufactured in accordance with either an approved Production
Quality Assurance system (Module D), a Product-Quality assurance system (Module E) or a Product Verification Process
(Module F). The wheelmark cannot be affixed to the product until a conformity assessment module is in place.
7. Each item, batch or lot of the equipment is to be issued with a “Declaration of Conformity” and have the “Mark of
Conformity” affixed after a conformity assessment module is in place.
8. The manufacturer shall keep a copy of the EC type-examination certificate, its annexes and additions together with the
technical documentation at the disposal of the national authorities for at least 10 years after the wheel mark has been
affixed on the last product manufactured and in no case for a period shorter than the expected life of the marine equipment
concerned.
Page: 5 of 5
Place of Production
S-37123 Karlskrona
Keith Taylor
Team Lead, Fire & Safety
Fire & Safety, Statutory Discipline Team
UK&I Technical Support Office, Marine & Offshore
For and on behalf of Lloyd’s Register Marine Deutschland
LRMD EC Distinguishing No. 2923
