MEDB000017T-revision1-optimized
MEDB000017T
Roxtec sealing system with multidiameter technology: R-series (Al)
Regulation (EU) 2021/1158,
IMO MSC.1/1488
This Certificate is valid until 2024-12-07.
Issued at Høvik on 2021-12-08
DNV local station: Digitally Signed By: Øyvind Hoff
Sweden CMC Location: DNV Høvik, Norway
on behalf of
Kristin Grønnæss Notified Body Sverre Olav Bergli
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 1 of 3
Job Id: 344.1-003179-3
Certificate No: MEDB000017T
Revision No: 1
“Roxtec sealing system with multidiameter technology: R-series (Al)”
consisting of an aluminium sleeve bolted or welded to an aluminium section. Sleeve is fitted with a Roxtec R frame
(standard or EMC) in sizes 50-200. The R-frame is filled with Roxtec (standard or EMC) halogen free RM modules.
Approved for use as a single or multiple pipe penetration system in class A-60 aluminium bulkheads and decks for steel
and copper pipes according to below tables. Other applications are subject to case-by-case approval.
For class A-0, A-15 and A-30 applications, the penetration shall be insulated as A-60 and in addition the division is to be
insulated at least 200 mm around the penetration.
Table 1: Approved pipe penetration in A-60 aluminium bulkhead
material position insulation
R 50 – 200 Steel
R 50 – 200 Copper
Table 2: Approved pipe penetration in A-60 aluminium deck
R 50 – 100 Steel
R 70 – 200 Steel
R 50 – 200 Copper
Test report No. P603001 dated 23 January 2007 from SP, Borås, Sweden.
Test report No. PG11955 Serial No. 11979 dated 17 April 2009 from DIFT, Denmark.
Test report No. PGB10016A dated 3 June 2020 from DBI, Hvidovre, Denmark.
Test report No. PGB10077A dated 10 December 2020 from DBI, Hvidovre, Denmark.
Test report No. RS-20/B-408/E dated 17 December 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-410/E dated 17 December 2020 from CTO, Gdansk, Poland.
Drawing No. S1566985 Rev.A dated 14 May 2021 from maker.
Drawing No. S1566997 Rev.A dated 14 May 2021 from maker.
Tested according to IMO FTPC Part 3 (IMO Res. A.754(18)) and in compliance with IMO 2010 FTP Code Ch. 8, and in
accordance with IMO 2010 FTP Code part 3.
MED Mark of Conformity and USCG approval number if applicable (see front page).
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 2 of 3
Revision No: 1
(standard or EMC) in sizes 70-200. The R-frame is filled with Roxtec (standard or EMC) halogen free RM modules.
Approved for penetration in aluminium bulkheads or decks for steel and copper pipes limited to a pressure of 4.00 bar
watertightness and 2.67 bar gastightness.
Test report No. MLM 010247 dated 29 August 2001 from DNV Malmö.
Test report No. MLM 030473 dated 27 January 2003 from DNV Malmö.
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 3 of 3
