| EC-TYPE EXAMINATION | MEDB00001HW |
| Revision No: | |
| CERTIFICATE (MODULE B) | 1 |
Application of: Directive 2014/90/EU of 23 July 2014 on marine equipment (MED), issued as “Forskrift
om Skipsutstyr” by the Norwegian Maritime Authority. This Certificate is issued by DNV GL AS under the
authority of the Government of Norway.
Roxtec sealing system with multidiameter technology: R-series (steel)
Regulation (EU) 2019/1397,
item No. MED/3.26b. SOLAS 74 as amended, Regulation II-2/9, IMO MSC.1/Circ.1276, IMO
2010 FTP Code and IMO MSC.1/1488
This Certificate is valid until 2020-05-28.
Issued at Høvik on 2019-12-18
for DNV GL AS
| DNV GL local station: | Digitally Signed By: Hoff, Øyvind |
| Sweden CMC | Location: DNV GL Høvik, Norway |
| on behalf of |
Roald Vårheim
| Thorvald Furuseth | Notified Body |
A U.S. Coast Guard approval number will be assigned to the equipment when the production module has been completed and will appear on the
production module certificate (module D, E or F), as allowed by the “Agreement between the United States of America and the EEA EFTA states
on the mutual recognition of Certificates of Conformity for Marine Equipment” signed 17 October 2005, and amended by Decision No 1/2019
dated February 22nd, 2019.
The mark of conformity may only be affixed to the above type approved equipment and a Manufacturer’s Declaration of Conformity
issued when the production-surveillance module (D, E or F) of Annex B of the MED is fully complied with and controlled by a written
inspection agreement with a Notified Body. The product liability rests with the manufacturer or his representative in accordance with
Directive 2014/90/EU.
This certificate is valid for equipment, which is conform to the approved type. The manufacturer shall inform DNV GL AS of any
changes to the approved equipment. This certificate remains valid unless suspended, withdrawn, recalled or cancelled.
Should the specified regulations or standards be amended during the validity of this certificate, the product is to be re-approved
before being placed on board a vessel to which the amended regulations or standards apply.
| Form code: MED 201.NOR | Revision: 2017-07 | www.dnvgl.com | Page 1 of 3 |
© DNV GL 2014. DNV GL and the Horizon Graphic are trademarks of DNV GL AS.
| Job Id: | 344.1-000153-88 |
| Certificate No: MEDB00001HW | |
| Revision No: | 1 |
“Roxtec sealing system with multidiameter technology: R-series (steel)”
consisting of a steel sleeve, bolted, welded or attached through expansion (R X) to a steel section.
Sleeve is fitted with a Roxtec R frame (standard, Ex or EMC) in sizes 50-200. The R frame is filled with
Roxtec (standard, Ex or EMC) halogen free RM modules.
Approved for use as a single or multiple pipe penetration system in class
A-0, A-15, A-30 and A-60 steel bulkheads and decks for steel pipes,
A-15, A-30 and A-60 steel bulkheads and decks for copper pipes with Ø 10 to 54 mm,
A-0 steel decks for copper pipes with Ø 10 to 54 mm.
Deck or bulkhead to be insulated with approved insulation according to classification covering the edge
of the steel frame. See insulation drawings specified in the Type Approval Documentation.
A-15 and A-30 R X penetrations are to be insulated as for class A-60 and in addition the division is to be
insulated at least 200 mm around the penetration.
Cold service piping insulated with Armaflex rubber insulation layer may be used with approved
penetrations but is to be locally interrupted through the penetration system.
The insulation materials used have to be approved according to the Marine Equipment Directive and bear
the Mark of Conformity.
Please note Installation instruction for Roxtec RS X attached through expansion: Aperture irregularities
are acceptable within min and max diameters. (Max Ø = Min Ø + 2mm).
Penetrations through structural divisions should not impair the structural strength of the division. Special
consideration should be given to bulkheads and decks with high stress locations(IMO MSC.1/Circ.1488).
Test report Nos.:
| - | 22N007.18A (A-60 bulkhead) dated 29 May 2000 |
| - | 22N007.18C (A-60 deck) dated 29 May 2000 |
| - | 22N007.18D (A-0 deck) dated 29 May 2000 |
| - | 103070.23A (A-60 bulkhead) dated 11 December 2002 |
| - | 103070.23B (A-60 deck) dated 11 December 2002 from SINTEF, Norway |
| - | P602999 (A-60 bulkhead, Cu pipes) |
| - | P603000 (A-60 deck, Cu pipes) dated 23 January 2007 from SP, Sweden |
| - | 10408 (A-0 deck, Cu pipes) dated 16 February 2006 from Roxtec, Sweden. |
| - | PGA10800A (A-60 steel deck, Pipe penetrations, cable transits) dated 26-05-2016 from DBI, |
| Denmark | |
| - | IECEx Certificate of conformity IECEx NEM 12.0015U dated 2015-05-07. |
Assessment No. 103200.94 (A-60 deck) dated 17 December 2002 from SINTEF, Norway.
Drawing Nos.:
| - | S1006137 Rev.0 (A-0), |
| - | S1509547 rev C (A-class deck with steel pipes), |
| - | S1006138 Rev.A (A-15, A-30 and A-60 bulkhead), |
| - | S1004588 Rev.0 (A-15, A-30 and A-60 (R X)), |
| - | S1010588 Rev.- (A-15, A-30 and A-60 Cu pipes) and |
| - | S1010590 Rev.- (A-0 deck Cu pipes) |
| from Roxtec International AB. |
| Form code: MED 201.NOR | Revision: 2017-07 | www.dnvgl.com | Page 2 of 3 |
| Job Id: | 344.1-000153-88 | ||
| Certificate No: MEDB00001HW | |||
| Revision No: | 1 | ||
Tested according to IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8.
The product or packing is to be marked with name and address of manufacturer, type designation, fire-
technical rating, MED Mark of Conformity and/or USCG approval number (see page 1).
| Form code: MED 201.NOR | Revision: 2017-07 | www.dnvgl.com | Page 3 of 3 |
