MEDB0000369
Application of: Directive 2014/90/EU of 23 July 2014 on marine equipment (MED), issued as “Forskrift
om Skipsutstyr” by the Norwegian Maritime Authority. This Certificate is issued by DNV GL AS under the
authority of the Government of Norway.
Roxtec Sealing System with Multidiameter Technology, Group Penetration - Bulkhead
KARLSKRONA, Sweden
Regulation (EU) 2017/306,
item No. MED/3.26b. SOLAS 74 as amended, Regulation II-2/9, IMO MSC.1/Circ.1276 and
IMO 2010 FTP Code
This Certificate is valid until 2022-11-29.
Issued at Høvik on 2017-11-30
for DNV GL AS
| DNV GL local station: | Digitally Signed By: Øyvind Hoff |
| Malmö | Location: DNV GL Høvik, Norway |
| on behalf of |
Vidar Dolonen
| Marius Mørner | Notified Body |
A U.S. Coast Guard approval number will be assigned to the equipment when the production module has been completed and will appear on the
production module certificate (module D, E or F), as allowed by the “Agreement between the United States of America and the EEA EFTA states
on the mutual recognition of Certificates of Conformity for Marine Equipment” signed 17 October 2005.
The mark of conformity may only be affixed to the above type approved equipment and a Manufacturer’s Declaration of Conformity
issued when the production-surveillance module (D, E or F) of Annex B of the MED is fully complied with and controlled by a written
inspection agreement with a Notified Body. The product liability rests with the manufacturer or his representative in accordance with
Directive 2014/90/EU.
This certificate is valid for equipment, which is conform to the approved type. The manufacturer shall inform DNV GL AS of any
changes to the approved equipment. This certificate remains valid unless suspended, withdrawn, recalled or cancelled.
Should the specified regulations or standards be amended during the validity of this certificate, the product is to be re-approved
before being placed on board a vessel to which the amended regulations or standards apply.
| Form code: MED 201.NOR | Revision: 2017-07 | www.dnvgl.com | Page 1 of 2 |
© DNV GL 2014. DNV GL and the Horizon Graphic are trademarks of DNV GL AS.
| Job Id: | 344.1-000153-73 |
| Certificate No: MEDB0000369 |
“Roxtec Sealing System with Multidiameter Technology, Group Penetration”
consisting of Roxtec S-series steel frame, bolted or welded to a steel section, with an extended depth (-K)
supported with a flange, (-F), in total generating a SKF- frame in sizes up to a modular RM packing
space of maximum 280 mm height, with integrated intumescent material.
The frame is filled with Roxtec (standard or EMC) halogen free RM modules. Assembled with Roxtec
Wedge kit or Roxtec EMC Wedge kit.
Approved for use as a single or multiple pipe and cable penetration system in class A-60 classed steel
bulkheads, with a mix of plastic pipes (polyethylene) up to OD=90 mm in combination with copper pipes
and/or steel pipes up to OD=76 mm and cables up to OD=28 mm.
Class A-0, A-15 and A-30 shall be insulated as for A-60 and the division is to be fitted with A-60
insulation for a minimum distance of 200 mm around the penetration. For detail information about
insulation please see drawings specified in the Type Examination Documentation.
Watertightness and gastightness is not covered in this certificate.
The insulation materials used have to be approved according to the Marine Equipment Directive and bear
the Mark of Conformity.
Test report No. P602999 dated 23 January 2007 from SP, Sweden.
Drawing no. S1009653 Rev. A, dated 30 August 2006 from Roxtec International AB.
Drawing no. S1011662 Rev. 0 dated 18 June 2007 from Roxtec International AB.
Tested according to IMO FTPC Part 3 (IMO Res. A.754(18)) and in compliance with IMO 2010 FTP Code
Ch. 8.
The product or packing is to be marked with name and address of manufacturer, type designation, fire-
technical rating, MED Mark of Conformity and USCG approval number if applicable (see first page).
| Form code: MED 201.NOR | Revision: 2017-07 | www.dnvgl.com | Page 2 of 2 |
