MEDB00003M3
Roxtec sealing system with multidiameter technology: G-series (steel)
Regulation (EU) 2023/1667,
This Certificate is valid until 2028-12-20.
Issued at Høvik on 2023-12-21
Digitally Signed By: Bukarica,Dalibor
Denmark CMC
on behalf of
| Helge Bjørnarå | Notified Body | Mydlak-Röder, Christine |
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 1 of 4 |
| Job Id: | 344.1-000153-118 | ||
| Certificate No: | MEDB00003M3 | ||
| Revision No: | 1 |
“Roxtec sealing system with multidiameter technology: G-series (steel)”,
consisting of G-series steel frames (G, GHM, GHM BG, GO, GOH, G welded Ex and G bolted Ex) and GKO frame in
sizes 1-8 and combinations thereof, bolted or welded to a steel section. The frame is filled with Roxtec (Standard, EX,
BG or EMC) halogen free RM modules. Assembled with Roxtec Wedge (Standard, EX or ES) and corresponding stay
plates.
Approved for use as a single or multiple cable penetration system in class A-0, A-15, A-30 and A-60 steel bulkheads
and decks for approved ship cables.
the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead.
| Max. cable Sleeve | Sleeve |
| Frame | Cable |
| Size | diameter |
| type | type |
| (OD) [mm] | [mm] |
| Partially insulated* | |
| G-series | 1x1 – 8x1 |
| (S1589743, 4) | |
| Fully insulated. | |
| (S1589743, 5) | |
| G-series | 1x1 – 8+8x2 |
| (S1589743, 6) |
* Restricted application (fire against insulated side).
Table 2: Approved cable penetration in A-60 steel deck.
| Frame | Cable |
| Size | diameter |
| type | type |
| (OD) [mm] | [mm] |
| Partially insulated on the | |
| (S1589743, 1) | |
| Fully insulated + 250 mm along | |
| (S1589743, 2) | |
| GKO | 2x1 – 8x1 |
| (S1589743, 3) |
Table 3: Approved cable penetration in A-0 steel bulkhead.
| Frame | Cable |
| Size | diameter |
| type | type |
| (OD) [mm] | [mm] |
| (S1589784, 4) | |
| (S1589784, 5) | |
| (S1589784, 6) |
Table 4: Approved cable penetration in A-0 steel deck.
| Frame | Cable | Sleeve |
| Size | diameter | length |
| type | type | position |
| (OD) [mm] | [mm] | [mm] |
| Partially insulated on the | ||
| G-series | 1x1 – 8x1 | Marine |
| (S1589784, 1) | ||
| Fully insulated + 250 mm along | ||
| G-series | 1x1 – 8+8x2 | Marine |
| (S1589784, 2) |
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 2 of 4 |
| Revision No: | 1 |
| GKO | 2x1 – 8x1 | Marine | 88 | 100 | 6 | Topside | underside. |
| (S1589784, 3) |
Test report No. 6P10022 dated 7 March 2017 from SP, Borås, Sweden.
Test report No. RS-17/B-395/E dated 30 October 2017 from CTO, Gdansk, Poland.
Test report No. RS-17/B-396/E dated 30 October 2017 from CTO, Gdansk, Poland.
Test report No. RS-18/B-181/E dated 7 May 2018 from CTO, Gdansk, Poland.
Test report No. RS-22/B-394/E dated 28 November 2022 from CTO, Gdansk, Poland.
Drawing No. S1589743, Rev. A dated 13 March 2023 from manufacturer.
Drawing No. S1589784, Rev. B dated 6 November 2023 from manufacturer.
Tested according to IMO 2010 FTP Code part 3 and IMO FTP Code part 3 (IMO Res.A.754(18)) and in compliance with
IMO 2010 FTP Code Ch. 8.
MED Mark of Conformity and/or USCG approval number (see page 1).
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 3 of 4 |
| Revision No: | 1 |
plates.
Approved for penetration in steel bulkheads or decks limited to a pressure of 4.0 bar watertightness and 2.7 bar
Test report No. MLM 020106 dated 19 December 2001 from DNV Malmö.
Pressure tests with water and helium according to Class Programme DNV-CP-0165.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 4 of 4 |
