MEDB00005J9-optimized
Certificate no.:
EC-TYPE EXAMINATION MEDB00005J9
CERTIFICATE (MODULE B) 1
that the Penetrations through “A” class divisions: pipe, duct, trunk, etc penetrations
Roxtec sealing system with Multidiameter: S-series (aluminum division)
issued to
Regulation (EU) 2024/1975,
IMO MSC.1/1488
This Certificate is valid until 2029-11-19.
Issued at Høvik on 2024-11-20
Denmark CMC
Approval Engineer: Christine Mydlak-Röder
Marcin Tobiasz Notified Body
No.: 0575 Mydlak-Röder, Christine
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 4
Job ID: 344.1-000153-130
Certificate no.: MEDB00005J9
Revision No: 1
“Roxtec sealing system with Multidiameter: S-series (aluminum division)”
consisting of Roxtec S-series aluminum frames (S, S Ex, SF, SR/T, SR/S, SRC r20, SRC r40, SRC r60) in height 1-8
and width 60-120, and combinations thereof, welded to the aluminum sections.
The aluminum frame is filled with Roxtec halogen free RM modules*. Assembled with Roxtec Wedge (standard, Ex, ES,
or ES Ex) and corresponding stay plates.
  • RM modules come in the following versions: RM, RM Ex, RM FOC, RM ES, RM ES B, RM PE, RM PE B, RM BG, RM BG B, RM ES
Ex, RM ES B Ex, RM PE Ex, RM ES B Ex, RM BG Ex, RM BG B Ex
For more details, see drawings listed under Type Examination documentation below.
Approved for use as a single or multiple pipe penetration system in class A-60 aluminum divisions. Other applications
are subject to case-by case approval.
For A-0, A-15 and A-30 applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A-
60 insulation for a minimum distance of 200 mm around the penetration.
Table 1: Approved pipe penetration in A-60 aluminum bulkhead.
Pipe Frame Frame
Frame Pipe Frame
Size diameter length
type Material position
Fully insulated with 250 mm
S-series 1x1 – 8x2 Steel
(S1610072 ID 1)
(S1610072 ID 2)
Fully insulated with 350 mm
S-series 1x1 – 8x2 Copper
(S1610072 ID 3)
(S1610072 ID 4)
Table 2: Approved pipe penetration in A-60 aluminum deck.
Pipe Frame Frame
Frame Pipe Frame
Fully insulated with 450 mm
(S1602200 ID 1)
Fully insulated*) with 350 mm
Symmetric
S-series 1x1 – 8+8x2 Steel
Top side
(S1602200 ID 3)
Fully insulated*) with 800 mm
Symmetric
Top side
(S1602200 ID 2)
Bundle Symmetric
S-series 1x1 – 8+8x2 8 – 50
(Steel) Top side
(S1602200 ID 3)
Symmetric
S-series 1x1 – 8+8x2 Titanium
Top side
(S1602200 ID 3)
*) No insulation between pipes.
Conformity
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 4
Revision No: 1
Test report No. PG 11898 dated 17 April 2009 from DBI,Copenhagen Denmark.
Test report No. PG 11955 dated 17 April 2009 from DBI,Copenhagen Denmark.
Test report No. RS-22/B-426/E dated 2 January 2023 from CTO, Gdańsk, Poland.
Drawing No. S1610072 Rev.A dated 18 October 2024 from maker.
Drawing No. S1602200 Rev.D dated 18 October 2024 from maker.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 4
Revision No: 1
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.0 bar watertightness and 2.67 bar
gastightness for steel, titanium and copper pipes.
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.0 bar watertightness and 2.0 bar
gastightness for bundle pipes.
For SFOHK versions, the pressure is limited to 2.67 bar watertightness.
Test report No. MLM 020400 dated 25 March 2002 from DNV Malmö.
Test report No. MLM050410 dated 20 May 2005 from DNV Malmö.
Test report No. N141CR4U, Rev.1 dated 23 March 2017 from maker witnessed by DNV GL.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 4 of 4
