MEDB00006JA-revision2-optimized
EC-TYPE EXAMINATION MEDB00006JA
CERTIFICATE (MODULE B) 2
Roxtec sealing system with multidiameter technology: S-series (steel)
Regulation (EU) 2023/1667,
IMO MSC.1/1488
This Certificate is valid until 2029-05-15.
Issued at Høvik on 2024-05-16
Tessa Biever
Helge Bjørnarå Notified Body on behalf of
No.: 0575
Mydlak-Röder, Christine
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 5
Job Id: 344.1-000153-116
Certificate No: MEDB00006JA
Revision No: 2
“Roxtec sealing system with multidiameter technology: S-series (steel)”
consisting of Roxtec S-series steel frame (S, S EX, SF, SO, SFO, SR/T, SR/S, SRC r20, SRC r40, and SRC r60) in
height 1-8 and width 60-120, and combinations thereof, welded to the steel divisions.
The steel frame is filled with Roxtec halogen free RM modules*. Assembled with Roxtec wedge (standard, Ex or ES)
and corresponding stay plates.
SK-series is an extra deep steel frame with single barrier (SK, SK Ex, SFK, SFOK, SFOHK, SRCK r20, SRCK r40,
SRCK r60) welded or bolted to the steel divisions.
The steel frame is fitted at one end with Roxtec halogen free RM modules*. Assembled with Roxtec Wedge (standard,
Ex, ES or ES Ex) and corresponding stay plates.
SBTB-series is an extra deep steel frame with two barriers (SBTB, SBTB Ex, SFBTB, SRBTB, SRCBTB r20, SRCBTB
r40, SRCBTB r60) welded to the steel divisions.
The steel frame is fitted at both ends with Roxtec halogen free RM modules*. Assembled with Roxtec Wedge (standard,
  • RM modules comes in the following versions: RM, RM Ex, RM FOC, RM ES, RM ES B, RM PE, RM PE B, RM BG, RM BG B, RM ES
Ex, RM ES B Ex, RM PE Ex, RM ES B Ex, RM BG Ex, RM BG B Ex
For more details, see drawings listed under Type Examination documentation below.
Approved for use as a single or multiple pipe penetration system in class A-0 and A-60 steel divisions. Other
applications are subject to case-by case approval.
For A-15 and A-30 applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A-60
insulation for a minimum distance of 200 mm around the penetration.
Table 1: Approved pipe penetration in A-60 steel bulkhead.
Pipe Frame Frame
Frame Pipe Frame
Size diameter length
type Material position
Fully insulated + 300 mm along
Steel,
S-series 1x1 – 8x1 6 – 53 60 10 Symmetric pipes on one side.
Titanium
(S1597940, 3)
Fully insulated* + 500 mm
Steel,
S-series 1x1 – 8+8x5 6 – 54 60 10 Symmetric along pipes on one side.
Titanium
(S1597940, 4)
Bundle
S-series 1x1 – 8x1 8 – 50 60 10 Symmetric along pipes on one side.
(Steel)
(S1597927, 3)
Bundle
S-series 1x1 – 8+8x5 8 – 50 60 10 Symmetric along pipes on one side.
(Steel)
(S1597927, 4)
Fully insulated + 600 mm along
Copper,
S-series 1x1 – 8x1 6 – 54 60 10 Symmetric pipes on one side.
CuNi
(S1597962, 1)
* No insulation between pipes.
Table 2: Approved pipe penetration in A-60 steel deck.
Pipe Frame Frame
Frame Pipe Frame
Partially insulated on the
Top side
S-series 1x1 – 8x1 Steel
Symmetric
(S1597940, 1)
Fully insulated* + 350 mm
Steel, Top side along the pipes on the
S-series 1x1 – 8+8x5 6 – 50
Titanium Symmetric underside.
(S1597940, 2)
Fully* insulated + 350 mm
Bundle Top side
(Steel) Symmetric
(S1597927, 1)
Bundle Top side
(Steel) Symmetric
(S1597927, 2)
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 5
Revision No: 2
Fully insulated + 650 mm along
Copper, Top side
S-series 1x1 – 8x1
CuNi Symmetric
(S1597962, 2)
Steel,
SK-series 1x1 – 8x1 6 – 54 100 – 400 10 Any along pipes on the underside.
Titanium
(S1597969, 1)
Fully insulated on the
Steel,
SK-series 1x1 – 8x1 6 – 30 100 – 200 10 Top side underside.
Titanium
(S1597969, 2)
Bundle
SK-series 1x1 – 8x1 8 – 50 100 – 400 10 Any along pipes on the underside.
(Steel)
(S1597980, 1)
Table 3: Approved pipe penetration in A-0 steel bulkhead.
Pipe Frame Frame
Frame Pipe Frame
type material position
Fully insulated** + 200 mm
Steel,
S-series 1x1 – 8x1 6 – 54 60 10 Symmetric along pipes on one side.
Titanium
(S1597959, 3)
Steel,
Titanium
(S1597959, 4)
Bundle
(Steel)
(S1597936, 3)
Bundle
(Steel)
(S1597936, 4)
Copper,
CuNi
(S1597976, 1)
SBTB- None.
1x1 – 8x1 Steel 6 – 30 200+ 10 Symmetric
series (S1597993, 1)
  • No insulation between pipes.
    ** No insulation between pipes. Sleeve is insulated, but no additional insulation along division.
Table 4: Approved pipe penetration in A-0 steel deck.
Pipe Frame Frame
Frame Pipe Frame
Top side
Symmetric
(S1597959, 1)
(S1597959, 2)
Bundle Top side
(Steel) Symmetric
(S1597936, 1)
Bundle Top side
(Steel) Symmetric
(S1597936, 2)
Copper, Top side
CuNi Symmetric
(S1597976, 2)
Steel,
Titanium
(S1597973, 1)
Fully insulated along pipes on
Steel,
SK-series 1x1 – 8x1 6 – 30 100 – 200 10 Top side the underside.
Titanium
(S1597973, 2)
Bundle
(Steel)
(S1597981, 1)
Conformity
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 5
Revision No: 2
Test report No. 6P02249 dated 17 June 2016 from SP, Borås, Sweden.
Test report No. RS-17/B-395/E dated 30 October 2017 from CTO, Gdansk, Poland.
Test report No. RS-18/B-484/E dated 10 December 2018 from CTO, Gdansk, Poland.
Test report No. RS-18/B-485/E dated 10 December 2018 from CTO, Gdansk, Poland.
Test report No. 9P02428 dated 13 September 2019 from SP, Borås, Sweden.
Test report No. PGB10174A dated 13 July 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-22/B-336/E dated 28 October 2022 from CTO, Gdansk, Poland.
Test report No. RS-22/B-337/E dated 28 October 2022 from CTO, Gdansk, Poland.
Test report No. PGB10233A dated 20 December 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-23/B-104/E dated 25 April 2023 from CTO, Gdansk, Poland.
Test report No. PGB10220A dated 8 May 2023 from DBI, Hvidovre, Denmark.
Test report No. PGB10222A dated 25 October 2023 from DBI, Hvidovre, Denmark.
Test report No. RS-23/B-339/E dated 3 November 2023 from CTO, Gdansk, Poland.
Test report No. PGB10221A dated 24 November 2023 from DBI, Hvidovre, Denmark.
Drawing No. S1597927 Rev. B dated 13 May 2024 from maker.
Drawing No. S1597936 Rev. C dated 13 May 2024 from maker.
Drawing No. S1597940 Rev. A dated 26 October 2023 from maker.
Drawing No. S1597959 Rev. C dated 13 May 2024 from maker.
Drawing No. S1597962 Rev. B dated 13 May 2024 from maker.
Drawing No. S1597969 Rev. A dated 26 October 2023 from maker.
Drawing No. S1597973 Rev. A dated 26 October 2023 from maker.
Drawing No. S1597976 Rev. C dated 13 May 2024 from maker.
Drawing No. S1597980 Rev. A dated 25 October 2023 from maker.
Drawing No. S1597981 Rev. A dated 25 October 2023 from maker.
Drawing No. S1597993 Rev. B dated 13 May 2024 from maker.
2010 FTP Code part 3.
MED Mark of Conformity and/or USCG approval number if applicable (see first page).
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 4 of 5
Revision No: 2
height 1-8 and width 60-120, and combinations thereof, welded to a steel section.
SRCK r60) welded or bolted to the steel section.
r40, SRCBTB r60) welded to the steel section.
Ex, RM ES B Ex, RM PE Ex, RM ES B Ex , RM BG Ex, RM BG B Ex
Approved for penetration in steel bulkheads or decks limited to a pressure of 4.0 bar watertightness and 2.67 bar
gastightness for steel, titanium, copper and CuNi pipes.
Approved for penetration in steel bulkheads or decks limited to a pressure of 4.0 bar watertightness and 2.0 bar
gastightness for bundle pipes.
For SFOHK versions, the pressure is limited to 2.67 bar watertightness.
Test report No. MLM 020400 dated 25 March 2002 from DNV Malmö.
Test report No. MLM 060561 dated 1 December 2006 from DNV Malmö.
Test report No. N141CR4U, Rev.1 dated 23 March 2017 from maker witnessed by DNV GL.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 5 of 5
