Certificate no.:
| EC-TYPE EXAMINATION | MEDB00008MR |
CERTIFICATE (MODULE B)
that the Penetrations through “A” class divisions: electric cable transits
Roxtec sealing system with multidiameter technology: TB-series (Steel divisions)
issued to
Regulation (EU) 2023/1667,
This Certificate is valid until 2029-06-20.
Issued at Høvik on 2024-06-21
Denmark CMC
Tessa Biever
| Marcin Tobiasz | Notified Body | on behalf of |
| No.: 0575 | ||
| Mydlak-Röder, Christine | ||
| Head of Notified Body |
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 1 of 3 |
| Job ID: | 344.1-012937-1 | ||
| Certificate no.: | MEDB00008MR |
“Roxtec sealing system with multidiameter technology: TB-series (Steel divisions)”
Consisting of a steel sleeve welded into a steel division which is containing Roxtec rubber seals with two half circle
metallic front fitting plates. These are locked into a groove in the sleeve and are fixed with four axial compression bolts.
TB-sealing with multidiameter technology has peelable layers making the center adaptable to single cable.
Approved for use as a single or multiple cable penetration system in class A-0, A-15, A-30 and A-60 steel bulkheads
and decks for approved ship cables.
around the penetration.
Table 1: Approved cable penetration in A-60 steel bulkheads
| Cable | Sleeve | |
| Type | Size | diameter |
| type | position | |
| [mm] | [mm] | [mm] |
| Fully insulated | ||
| TB | 65 - 105 | Marine |
| (S1593516 Rev.A, No. 1) |
Table 2: Approved cable penetration in A-60 steel decks
| Cable | Sleeve | |
| type | position | |
| (S1593516 Rev.A, No. 2) |
Test report No. RS-23/B-105/E dated 23 May 2023 from CTO, Gdansk, Poland
Test report No. RS-23/B-106/E dated 23 May 2023 from CTO, Gdansk, Poland
Test report No. RS-22/B-153/E dated 4 May 2022 from CTO, Gdansk, Poland
Drawing No. S1593516 Rev. A dated 14 August 2023 from maker.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 2 of 3 |
Additional application/information for watertightness/gastightness and
vibration (Not part of the Marine Equipment Directive requirement)
Approved for penetration in steel bulkheads or decks limited to a pressure of 11 bar watertightness (tested pressure
16.5 bar) and 2 bar gastightness (tested pressure 3 bar).
Penetration systems are generally not to be used for penetrating boundaries of tanks. When a penetration system is
requested for penetrating tanks, an approval may be given on a case-by-case basis.
Each product is to be installed with its manual for installation and use.
Statement No N141Z9F4 dated 2020-04-29 from DNV Sweden
Statement No N141ZEM3 dated 2020-05-15 from DNV Sweden
Pressure tests with water and helium according to Class Programme DNV-CP-0165.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 3 of 3 |
