MERB00002SA-Rev-0-optimized
MERB00002SA
Roxtec sealing system with multidiameter technology: RS-series (steel)
Regulation MSN 1874 Amendment 7,
This Certificate is valid until 2027-12-20.
Issued at London on 2023-03-30
Karolina Kusmider Christine Mydlak-Röder
Form code: MER 201.GBR Revision: 2022-12 www.dnv.com Page 1 of 5
Job Id: AA002B54
Certificate No: MERB00002SA
Roxtec sealing system with multidiameter technology: RS-series (steel division)
The RS cable penetration seal consist of two halves with removable layers making it adaptable to cables of different
diameters. It is available in different versions, RS, RS OMD, RS EMC or RS EX, depending on application.
The RS-seal is installed into a steel sleeve that is either welded, bolted, attached through expansion (SLFRS X),
attached with a nut (SLA) or by threads (SL 25/M24x1.5 and SL 31/M30x2) onto the steel division.
Approved for use as a single cable penetration system in class A-0 and A-60 steel bulkheads and decks for approved
ship cables. Other applications are subject to case-by-case approval.
the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead
Max. cable Sleeve Sleeve
RS-series Sleeve Sleeve
diameter length thickness
size type position
[mm] [mm] [mm]
23 - 150 SLRS-series 1) 100
23 - 125 SLFRS X 86
25 - 75 SLA 32
Threaded
31 13 68
sleeve
  1. SLRS-series includes the following sleeve types: SLRS, SLRS Ex or sleeves equal to Roxtec dimensions specified in drawing S1586454.
Table 2: Approved cable penetration in A-60 steel deck
size type position
[mm] [mm] [mm]
23 - 150 SLRS-series 1) 96
25 - 125 SL-series 90 Up to 400 4-7 Any S1579166
25 - 150 SLFRS X 90 65 4-7 Underside S1574993; No. 2
25 - 75 SLA 32 47 - 86 4-5 Top side S1575003; No. 4-6
Threaded
25 - 31 13 63 - 68 2.3 Top side S1575852; No. 2
sleeve
S1586454.
2) SL-series are longer versions of sleeves in SLRS-series
Table 3: Approved cable penetration in A-0 steel bulkhead
size type position
[mm] [mm] [mm]
23 – 150 SLRS-series 1) 100
23 - 150 SLFRS X 86
25 - 75 SLA 32
Threaded
31 13 68
sleeve
S1586454.
Form code: MER 201.GBR Revision: 2022-12 www.dnv.com Page 2 of 5
Job Id: AA002B54
Table 4: Approved cable penetration in A-0 steel deck
size type position
[mm] [mm] [mm]
23 - 150 SLRS-series 1) 93
25 - 125 SL-series 90 Up to 400 4-7 Any S1582116
25 - 125 SLFRS X 90 65 4-7 Underside S1582114; No. 2
25 - 75 SLA 32 47 - 86 4-5 Top side S1575008; No. 5-7
Threaded
31 13 68 2.3 Top side S1575011; No. 2
sleeve
The insulation materials used have to be approved according to the UK Marine Equipment Regulation and bear the UK
Mark of Conformity.
Please note Installation instruction for SLFRS X attached through expansion: Aperture irregularities are acceptable
within min and max diameters (Max Ø = Min Ø + 2 mm).
Test report No. PGA10652 dated 3 July 2015 from DBI, Hvidovre, Denmark.
Test report No. PGA10800A dated 26 May 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10870A dated 1 November 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10871A dated 31 October 2016 from DBI, Hvidovre, Denmark.
Test report No. 6P10024 dated 7 March 2017 from SP, Borås, Sweden.
Test report No. RS-17//B-395/E dated 30 October 2017 from CTO, Gdansk, Poland.
Test report No. RS-18/B-022/E dated 29 January 2018 from CTO, Gdansk, Poland.
Test report No. 8P07092 dated 27 September 2019 from SP, Borås, Sweden.
Test report No. PGA11610A dated 1 January 2020 from DBI, Hvidovre, Denmark.
Test report No. PGA11611A dated 11 January 2020 from DBI, Hvidovre, Denmark.
Test report No. 8P07094 dated 16 January 2020 from SP, Borås, Sweden.
Test report No. RS-20/B-017/E dated 23 January 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-081/E dated 31 March 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-083/E dated 20 April 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-191/E dated 5 June 2020 from CTO, Gdansk, Poland.
Test report No. PGB10110A dated 27 April 2021 from DBI, Hvidovre, Denmark.
Test report No. PGB10118A dated 15 November 2021 from DBI, Hvidovre, Denmark.
Test report No. RS-21/B-517/E dated 15 December 2021 from CTO, Gdansk, Poland.
Test report No. RS-21/B-518/E dated 15 December 2021 from CTO, Gdansk, Poland.
Test report No. PGB10169A dated 18 March 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-22/B-153/E dated 8 April 2022 from CTO, Gdansk, Poland.
Test report No. 7P02024 dated 8 June 2022 from SP, Borås, Sweden.
Test report No. PGB10172A dated 17 June 2022 from DBI, Hvidovre, Denmark.
Drawing No. S1574993 Rev. A dated 28 December 2021 from maker.
Drawing No. S1574995 Rev. B dated 8 August 2022 from maker.
Drawing No. S1574998 Rev. B dated 8 August 2022 from maker.
Drawing No. S1575003 Rev. A dated 28 December 2021 from maker.
Drawing No. S1575008 Rev. B dated 28 December 2021 from maker.
Drawing No. S1575011 Rev. A dated 29 December 2021 from maker.
Drawing No. S1575852 Rev. A dated 31 January 2022 from maker.
Drawing No. S1579166 Rev. A dated 3 May 2022 from maker.
Drawing No. S1582114 Rev. A dated 9 August 2022 from maker.
Drawing No. S1582116 Rev. A dated 9 August 2022 from maker.
Drawing No. S1586454 Rev. A dated 30 November 2022 from maker.
Form code: MER 201.GBR Revision: 2022-12 www.dnv.com Page 3 of 5
Job Id: AA002B54
Tested according to IMO 2010 FTP Code Part 3.
The product or packing is to be marked with name and address of manufacturer, type designation, UK Mark of
Conformity (see first page).
Form code: MER 201.GBR Revision: 2022-12 www.dnv.com Page 4 of 5
Job Id: AA002B54
The RS-seal is installed into a steel sleeve that is either welded, bolted, attached through expansion (SLFRS X) or
attached with a nut (SLA) onto the steel division.
For SLA sleeves the pressure is limited to 2.67 bar watertightness and 1.00 bar gastightness.
For longer versions of sleeves in SLRS-series the pressure is limited to 2.00 bar watertightness and 1.00 bar
Test report No. MLM 010235 dated 21 August 2001 from DNV Malmö.
Test report No. MLM 010133 dated 26 February 2002 from DNV Malmö.
Test report No. N141EX8Z Rev. 2 dated 10 August 2017 from DNV GL Malmö.
Test report No. DOC-004793 Rev. A dated 20 June 2022 from maker.
Pressure tests with water and helium according to DNV Type Approval Programme 8.471.19-1 and DNV-CP-0165.
Form code: MER 201.GBR Revision: 2022-12 www.dnv.com Page 5 of 5
