MERB0000368
Roxtec sealing system: Roxtec SPM seal series (Aluminium divisions)
Regulation MSN 1874 Amendment 7,
MSC.1/1488
This Certificate is valid until 2027-12-19.
Issued at London on 2023-03-30
| Approval Engineer: | Approved Body No.: 0097 |
| Karolina Kusmider | Christine Mydlak-Röder |
| MER Service Responsible |
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 1 of 3 |
| Job Id: | AA002B54 | ||
| Certificate No: | MERB0000368 | ||
| Revision No: | 0 |
“Roxtec sealing system: Roxtec SPM seal series (Aluminium divisions)”
consisting of Roxtec SPM rubber seals in size 39-279 attached to expansion to Aluminium sections.
Approved for use as a single pipe penetration system in class A-60 Aluminium bulkheads and decks as according to the
tables below. Other applications are subject to case-by-case approval.
For A-0, A-15 and A-30 applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A-
60 insulation for a minimum distance of 200 mm around the penetration. For detail information about insulation please
see drawings specified in the Type Examination Documentation.
Table 1: Approved pipe penetration in A-60 aluminium bulkhead
| Pipe | Sleeve | Sleeve |
| Pipe | Seal | |
| Type | Size | diameter |
| material | position | |
| (OD) [mm] | [mm] | [mm] |
| SPM | 39 – 279 | Steel |
| SPM | 39 – 157 | Copper |
Table 2: Approved pipe penetration in A-60 aluminium deck
| Pipe | Seal | |
All seals shall be installed in accordance with Roxtec’s SPM seal Installation Instructions, including aperture dimensions
and tolerances, tightening torque, etc.
The insulation material used has to be approved according to the UK Marine Equipment Regulations and bear the UK
Mark of Conformity.
Test report No. RS-17/B-209/E dated 2 June 2017 from CTO, Gdansk, Poland.
Test report No. RS-17/B-210/E dated 2 June 2017 from CTO, Gdansk, Poland.
Test report No. RS-18/B-179/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. RS-18/B-180/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. PGA11370A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test report No. PGA11371A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Drawing No. S1581274 Rev. C dated 7 July 2022 from maker.
Drawing No. S1581303 Rev. C dated 7 July 2022 from maker.
Drawing No. S1581308 Rev. B dated 7 July 2022 from maker.
Drawing No. S1581082 Rev. C dated 7 July 2022 from maker.
The product or packing is to be marked with name and address of manufacturer, type designation, UK Mark of
Conformity (see first page).
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 2 of 3 |
| Revision No: | 0 |
(Not part of the UK Marine Equipment Regulations requirement)
Approved for penetration in aluminium bulkheads or decks for steel and copper pipes limited to a pressure of 1 bar
watertightness and 0.67 bar gastightness.
Survey Report no. N1419WS4 dated 22 June 2016 from DNV GL Malmö.
Survey Report no. N141805A dated 20 December 2016 from DNV GL Malmö.
Tested according to Class Programme DNV-CP-0165 Chapter 4, September 2021.
| Form code: MER 201.GBR | Revision: 2022-12 | www.dnv.com | Page 3 of 3 |
