MERB00003M3-Rev-0-optimized
MERB00003M3
Roxtec sealing system with multidiameter technology: G-series (steel)
item No. UK/3.26a. SOLAS 74 as amended, Regulation II-2/9 and IMO 2010 FTP Code
This Certificate is valid until 2023-07-01.
Malmö
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 3
Certificate No: MERB00003M3
“Roxtec sealing system with multidiameter technology: G-series (steel)”
consisting of Roxtec G-series steel frames (G, GO and GHM) in sizes 1-8 and combinations thereof, bolted or welded to
a steel section. The G frame is filled with Roxtec (standard or Ex, EMC of type PE, ES and BG, BGB) halogen free RM
modules. Assembled with Roxtec wedge kit or Roxtec EMC wedge kit.
Approved for use as a single or multiple cable penetration system in class A-0, A-15, A-30 and A-60 steel bulkheads
and decks for approved ship cables.
Deck penetrations are to be partially insulated while bulkhead penetrations are to be fully insulated. For more details,
please see insulation drawing specified in the Type Examination documentation. For fire class A-0, A-15 and A-30, the
sleeve and cables are to be insulated as for class A-60.
Mark of Conformity.
Test Report No. PGA10024 dated 21 December 2011 from DBI, Hvidovre, Denmark (RM BG and BGB).
Test Report No. PGA10025 dated 22 December 2011 DBI, Hvidovre, Denmark (RM BG and BGB).
Test Report No. 6P10022 dated 2017-03-07 from SP, Borås, Sweden.
Test Report No. RS-17/B-396/E dated 2017-10-30 from CTO S.A., Gdansk, Poland.
Drawing No. S1528176, Rev. B, dated 2 July 2018 from Roxtec International AB.
Tested according to IMO 2010 FTP Code Part 3; IMO FTP Code Part 3 (IMO Res.A.754(18)) and in compliance with
IMO 2010 FTP Code Ch. 8.
and the Mark of Conformity (see page 1).
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 2 of 3
a steel section. The G frame is filled with Roxtec (standard or EMC of type PE, ES) halogen free RM modules.
Approved for penetration in steel bulkheads or decks limited to a pressure of 4.0 bar watertightness and 2.7 bar
For bolted versions with gasket and self tapping screws, the pressure is limited to 3.3 bar watertightness and 1.7 bar
Test reports Nos.:
- MLM 020106 dated 19 December 2001,
- MLM 020133 dated 26 February 2002,
- MLM 020401 dated 25 March 2002,
from DNV Malmö.
Pressure tests with water and Helium according to Class Programme DNVGL-CP-0165.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 3 of 3
