MERB0000452-Rev-0-optimized
MERB0000452
Roxtec sealing system with multidiameter technology: SE PPS S-series (steel)
item No. UK/3.26b. SOLAS 74 as amended, Regulation II-2/9, IMO MSC.1/Circ.1276 and IMO 2010 FTP Code
This Certificate is valid until 2023-06-13.
Gothenburg
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 3
Certificate No: MERB0000452
“Roxtec sealing system with multidiameter technology: SE PPS S-series (steel)”
consisting of Roxtec S-series steel frames (S, SO, SF, SFO, SR, SK, SRC r20 and SRC r40) in sizes 2-6, and
combinations thereof up to x4, to be used together with SE PPS extension frames, bolted or welded to the steel
sections. The extension frame is equipped with intumescent material strips. The S frame is filled with Roxtec (standard
or EMC) halogen free RM modules. Assembled with Roxtec Wedge kit or Roxtec EMC Wedge kit.
Approved for use as a penetration system in class A-0, A-15, A-30 and A-60 steel bulkheads and decks for approved
pipes and cables as follows:
Type of Pipe Dia. pipe [mm] S-series size Deck/Bulkhead
Thermoplastic (PP, PVC, PB, ABS, HDPE, PVDF) 16-99 2-6 Deck/Bulkhead
PE/Alu flexi pipe 16-99 2-6 Deck/Bulkhead
Copper and steel pipes 10-54 2-6 Deck
Approved ships cables Up to 60 1-6 Deck/Bulkhead
Deck or bulkhead to be insulated with approved insulation according to classification covering the edge of the steel
frame. See insulation drawing specified in the Type Examination Documentation.
Mark of Conformity.
Test Reports Nos.:
- 103070.27A (A-60 bulkhead) and 103070.27B (A-60 deck) both dated 4 July 2003 from SINTEF, Norway
- P701755 dated 12 June 2007 from SP, Sweden
- 09-344E dated 2011-12-09 (A-60 bulkhead, Reference test for SRC-frame; Transit D) from RIME, Japan
Assessment No.103201.33 dated 11 September 2003 from SINTEF, Norway.
Drawing No. S1015479 dated 3 November 2008 from Roxtec International AB.
Tested according to IMO FTP Code Part 3 and in accordance with IMO 2010 FTP Code Ch. 8.
and the Mark of Conformity (see page 1).
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 2 of 3
combinations thereof up to x4, to be used together with PPSE extension frames, bolted or welded to the steel sections.
The extension frame is equipped with intumescent material strips. The S frame is filled with Roxtec (standard or EMC)
Approved for penetration of plastic pipes and cables in steel bulkheads or decks and for copper and steel pipes in steel
deck limited to a pressure of 4 bar watertightness and 2.67 bar gastightness.
For bolted versions with gasket and self-tapping screws, the pressure is limited to 3.3 bar watertightness and 1.7 bar
When requested to be used in watertight bulkheads on passenger ships and Special Purpose Ships (SPS), the
penetration system has to comply with the requirements given in SOLAS Ch. II-1 Reg. 13.2.3 (2009 issue). Penetrations
passing through watertight bulkheads are subject for separate examination and approval (water tightness after a
standard fire test). This product has not been tested according to Reg. 13.2.3.
Test reports No. MLM 020401 dated 25 March 2002 from DNV Malmö (screws), MLM020133 dated 26 February 2002
(steel pipes), MLM0504010 dated 20 May 2005 (Copper pipes) from DNV Malmø and No. SKM-04-4088 dated 16 June
2004 from DNV Stockholm.
Inspection report No. MLM 020408 dated 3 June 2002 from DNV Malmö.
Pressure test with water and Helium according to DNV Type Approval Programme 8.471.19-1.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 3 of 3
