MERB000069T-Rev-0-optimized
MERB000069T
Roxtec GK Firestop Sealing Kit, GK FS SK KIT ROUND 89 - 273 and
GK FS SK KIT OVAL 200x150 - 250x170, 350x170, 450x170, 550x170 or 2x(250x170)
This Certificate is valid until 2025-04-07.
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 1 of 4
Certificate No: MERB000069T
“GK FS SK sealing kit“ consisting of a fiberglass cloth with built in heat activated intumescent material to be wrapped
around cable bundles and fitted into circular or oval steel pipe sleeves. Folded back on each side with ends sealed off to
create a cold smoke tight seal and secured by metal cable ties.
“GK FS SK sealing kit“ is intended to be used for bundled cables or as a blank fire stop solution. The installation shall
be made in symmetrically welded or bolted pipe sleeves.
GK FS SK KIT ROUND A-60:
The coaming is welded or bolted symmetrically of the deck/bulkhead.
Installation details according to drawings Roxtec No. S1571487 Rev. A, S1571524 Rev. A
Application Sleeve Sleeve Tested Tested maximum Tested cable
Size Ø (mm) Length (mm) minimum filling rate (%) maximum
filling rate diameter (mm)
Bulkhead 84 - 273 100 - 205 0 68 50
Deck 84 - 273 100 - 205 0 68 50
GK FS SK KIT OVAL A-60:
Application Sleeve Size (mm) Sleeve Tested Tested Tested cable
(Ø x L) Length minimum maximum maximum
(mm) filling rate filling rate diameter (mm)
Bulkhead 200x150 - 250x170 or 100 - 205 0 68 50
2x(250x170)
Deck 200x150 - 250x170 or 100 - 205 0 68 50
2x(250x170)
Bulkhead 350x170, 450x170, 550x170 100 - 205 0 68 90
Deck 350x170, 450x170, 550x170 100 - 205 0 68 90
GK FS SK KIT ROUND A-0:
Installation details according to drawings Roxtec No. S1571522 Rev. A, S1571523 Rev. A
Application Sleeve Size Sleeve Tested Tested maximum Tested cable
(mm) (Ø x L) Length (mm) minimum filling rate (%) maximum
| Form code: MER 201.GBR | Revision: 2022-09 | www.dnv.com | Page 2 of 4 |
GK FS SK KIT OVAL A-0:
2x(250x170)
2x(250x170)
*Definition filling ratio:
Cable filing ratio = (The sum cross section of the cables) / (the inside cross section area of Coaming, including the cloth)
*Cross sectional of the cable=R2 x3.14
*R=Radius of Cable and the Seal.
Water- / Gas- tightness: Not applicable
Approved for use as a blank, single or multiple cables penetration system (combined in one or more cable bundles) in
class A-60 and A-0 steel bulkheads and decks. Other applications are subject to case-by-case approval. Approved for
use in class A-15 and A-30 when the penetration system is insulated as A-60. In addition the division is to be insulated
with A-60 insulation at least 200 mm around the penetration.
of Conformity. Each product is to be supplied with its actual manual for installation and use.
Maximum filling ratio of 68%.
In general approved maximum cable diameter: 50 mm / 90 mm (refer to tables under Product description).
The bolted sleeves shall be installed with screws + spring washer.
Sleeves with lengths L=100 to 205mm with or without intumescent strips can be used.
The systems must not be installed in bulkheads and decks if water- and gas- tightness is required.
Each product is to be supplied with its manual for installation, use and maintenance.
Test Reports A60 Fire Class:
RS-19/B-255/E, dated 2019-08-20; RS-19/B-225/E, dated 2019-08-01; RS-19/B-256/E,
dated 2019-08-20; RS-19/B-355/E, dated 2019-10-16; DMT-DO-53-112, dated 2019-05-22;
RS-21/B-242/E, dated 2021-06-30; PGB10113A, dated 2021-07-23
Test Reports A0 Fire Class:
PGA11387A, dated 2019-07-05; RS-19/B-423/E, dated 2019-11-19; RS-20/B-081/E, dated 2020-03-31; 8P07092, dated
2019-09-27; 8P07094, dated 2019-09-23; PGA11610A, dated 2020-01-10;
RS-21/B-240/E, dated 2021-06-30; PGB10119A, dated 2021-11-15
Test Reports Cold Smoke:
Roxtec No. 29092016-01, dated 2016-09-29; No. 22032017-01, dated 2017-03-22; No. 14122016-01, dated 2016-12-14
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 3 of 4
Installation Drawings:
Roxtec No. S1571487 Rev. A dated 2022-03-23, S1571524 Rev. A dated 2022-03-22, S1571522 Rev. A
dated 2022-03-22, S1571523 Rev. A dated 2022-03-22
General Arrangement Drawings:
Roxtec No. S1543766 Rev. B dated 2019-10-23, S1543765 Rev. B dated 2019-10-22, S1535797 Rev. C
dated 2019-10-22, S1558305 Rev. B dated 2021-05-19
Sleeve Drawings:
Roxtec No. S1535700 Rev. D dated 2021-12-06, S1550433 Rev. A dated 2019-12-17, S1577598 Rev. A
dated 2022-03-31
- IMO Res. MSC.307(88)-(2010 FTP Code), Annex 1: Part 3,
- MSC.1/Circ. 1488
For identification to this type examination certificate the product or packing is to be marked with manufacturer’s name
and address, type designation, fire-technical rating and the Mark of Conformity (see page 1).
Form code: MER 201.GBR Revision: 2022-09 www.dnv.com Page 4 of 4
