TAF00000D8
| TYPE APPROVAL CERTIFICATE | Revision No: |
| 3 |
That the Class H Penetration
ROXTEC SEALING SYSTEM WITH MULTIDIAMETER TECHNOLOGY: RS-SERIES (CABLE)
DNV offshore standards
Approved as cable penetration in class H-120, H-60 and H-0 steel decks and bulkheads.
Issued at Høvik on 2022-11-09
| This Certificate is valid until 2027-02-01. | Digitally Signed By: Permoda, Jowita |
| DNV local unit: Sweden CMC | Signing Date: 09.11.2022 |
Approval Engineer: Timo Linn
Jowita Permoda
| Form code: TA 251 | Revision: 2022-09 | www.dnv.com | Page 1 of 3 |
| Job Id: | 262.1-001101-22 | ||
| Certificate No: | TAF00000D8 | ||
| Revision No: | 3 |
“Roxtec sealing system with multidiameter technology: RS-series”
consisting of steel sleeve, welded or bolted (openable versions included) to steel decks and steel bulkheads. The sleeve
is filled with Roxtec RS (standard or EMC) halogen free rubber sealing.
Additional Place of Production:
Roxtec Sealing System (Shanghai) Co,.Ltd Lingang Branch
Ground Floor A, No.875 QiuXin Road Zhongqilian (Lingang) Global Auto Parts Innovation Center, Shanghai, China.
Approved as cable penetration in class H-120, H-60 and H-0400 in steel decks and bulkheads for approved ship cables
as specified in the tables below.
General application: Fire against either side*
- In areas with requirements to maximum steel temperature in load bearing constructions, the bulkhead is approved for
restricted application: Fire against insulated side
Table 1: Approved cable penetration in H-120 steel bulkhead.
| Type | Size | diameter |
| [mm] | [mm] | [mm] |
| RS | 23 – 125 | 90 |
| RS | 23 – 150 | 96 |
- Bolted sleeves are approved for restricted application only.
Table 2: Approved cable penetration in H-60 steel bulkhead.
Table 3: Approved cable penetration in H-0400 steel bulkhead.
| RS | 23 – 125 | 88 |
- The protective coating is not defined as non-combustible and should not be used in accommodation or in enclosed areas.
Table 4: Approved cable penetration in H-120 steel deck.
Table 5: Approved cable penetration in H-60 steel deck.
Approved for penetration in deck and bulkheads limited to a pressure of 4.00 bar water tightness and 2.67 bar gas
tightness.
For bolted versions with gasket and self-tapping screws, the pressure is limited to 3.33 bar water tightness and 1.67 bar
gas tightness.
| Form code: TA 251 | Revision: 2022-09 | www.dnv.com | Page 2 of 3 |
| Revision No: | 3 |
Each product is to be supplied with its manual for installation/application and maintenance.
Test report No. 22N007.12C dated 16 September 1999 from SINTEF, Trondheim, Norway.
Test report No. PG11087 dated 12 February 2003 from DIFT, Hvidovre, Denmark.
Test report No. PG11088 dated 18 February 2003 from DIFT, Hvidovre, Denmark.
Test report No. P703775 dated 7 December 2007 from SP, Borås, Sweden.
Test report No. RS-19/B-036/E dated 21 March 2019 from CTO, Gdansk, Poland.
Test report No. PBG10120A dated 17 December 2021 from DBI, Hvidovre, Denmark.
Water tightness/gas tightness:
Inspection report MLM 010235 dated 21 August 2001 from DNV, Malmö, Sweden.
Inspection report MLM 020133 dated 26 February 2002 from DNV, Malmö, Sweden.
Drawing No. S1573509 Rev. B dated 18 January 2022 from manufacturer.
Drawing No. S1573516 Rev. A dated 12 November 2021 from manufacturer.
Tested according to IMO FTP Code Part 3 (IMO Res. A.754(18)) and with the hydrocarbon time-temperature curve
specified in ISO 834-3.
CP-0338 Section 4.
| Form code: TA 251 | Revision: 2022-09 | www.dnv.com | Page 3 of 3 |
