TAF00000H2
That the Class H Penetration
Roxtec Sealing System, H-seals, for copper busway systems
DNV offshore standards
Approved as copper busway penetration systems in class H-60 steel decks and bulkheads.
Restricted application: Fire from insulated side only.
Issued at Høvik on 2021-12-10
| This Certificate is valid until 2026-12-09. | Digitally Signed By: David-Andersen, Helene |
DNV local station: Malmö
Approval Engineer: Kristin Grønnæss
Helene David-Andersen
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 1 of 2 |
| Job Id: | 262.1-001101-18 | ||
| Certificate No: | TAF00000H2 | ||
| Revision No: | 1 |
“Roxtec sealing system, H seals, for copper busways systems”
consisting of Roxtec H-seals made from halogen free rubber compound together with stainless steel fittings, installed in
square steel frames.
For further details see drawing listed under Type Approval documentation.
For H-0 applications, the penetration shall be insulated as for H-60 and the division is to be fitted with H-60 insulation for
a minimum distance of 200 mm around the penetration.
Table 1: Approved busway penetration system in H-60 steel bulkhead
| Frame | Frame |
| Size | Busway |
| Busway type | length |
| [mm] | material |
| [mm] | [mm] |
| Eta-com Betobar-r* | 138 x 80 – 168 x 200 |
| *or similar constructed busbars. |
Table 2: Approved busway penetration system in H-60 steel deck
| Frame | Frame |
| Size | Busway |
| [mm] | material |
| [mm] | [mm] |
Each product is to be supplied with its manual for installation/application and maintenance.
Test report No. P601739 dated 28 June 2006 from SP, Borås, Sweden.
Test report No. P601740 dated 28 June 2006 from SP, Borås, Sweden.
Insulation drawing No. S1014521 dated 12 August 2008 from maker.
Tested according to IMO FTPC Part 3 (IMO Res. A.754(18)) and with the hydrocarbon time-temperature curve specified
in ISO 834-3.
The product or packing is to be marked with name of manufacturer, type designation and fire technical rating.
certificate and at least every second year. The arrangement is to be in accordance with procedure described in Class
Programme DNV-CP-0338, Section 4.
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 2 of 2 |
