TAF000016B-revision3-optimized
Certificate no.:
TAF000016B
TYPE APPROVAL CERTIFICATE Revision No:
3
that the Class A and B Penetration
Roxtec RS and RS PPS/S sealing systems for pipes (Back-to-Back Arrangement).
issued to
DNV statutory interpretations DNV-SI-0364 – SOLAS interpretations, Edition July 2021
Application:
The system is approved for watertightness after 60 minutes A-class fire test.
Penetration systems acceptable for use in watertight bulkhead divisions on passenger ships and SPS vessels
in accordance with SOLAS Ch. II-1 Reg. 13.2.3 (2014 issue) and IMO MSC/Circ. 736 Paragraph 2.1. For
Application/Limitation see page 2.
Issued at Høvik on 2024-04-24
This Certificate is valid until 2029-04-23.
DNV local unit: Sweden Fleet In Service
Jowita Permoda
Approval Engineer: Marcin Tobiasz
Form code: TA 281 Revision: 2023-09 www.dnv.com Page 1 of 3
Job ID: 262.1-032183-3
Certificate no.: TAF000016B
Revision No: 3
“Roxtec RS and Roxtec RS PPS/S sealing systems for pipes (Back-to-Back Arrangement)”
RS and RS PPS/S sealing systems consist of two seals installed, one in each side of an extended sleeve (minimum 600
mm) generating a “back-to-back arrangement”. The sleeve shall have a centred position in the bulkhead or deck and be
welded watertight to it.
The Back-to-Back Arrangement in bulkhead is partly insulated on both sides with additional cookie of A-60 insulation
(OD 250 mm) on exposed side. In addition, Roxtec RS system requires 650 mm A-60 insulation along pipe on both
sides.
The Back-to-Back Arrangement in deck is partly insulated on exposed (from below) side only.
Tightness test pressure is applied to the same side of the division which is exposed to the fire test. The following results
have been achieved:
Table 1 Approved watertight penetration system in bulkhead
Pipe system size Pipe outer Type of pipes Approved Insulation
diameter pressure drawing
[mm] [bar]
RS PPS/S (BTB) 43 -150 16 – 110 Thermoplastic pipes ABS, PP, PVC, PVDF 1.33 S1026802 Rev.C
RS PPS/S (BTB) 43 -150 16 – 110 Thermoplastic pipes PB 1.33 S1026802 Rev.C
RS PPS/S (BTB) 43 -150 20 – 110 Thermoplastic pipes PE 1.33 S1026802 Rev.C
RS PPS/S (BTB) 43 -100 16 – 63 Multilayer plastic pipes PE/ALU/PE 1.33 S1026802 Rev.C
RS-seal (BTB) 125 - 600 90 – 500 GRE / GRP 0.67 S1590482 Rev.A
Table 2 Approved watertight penetration system in deck
[mm] [bar]
This certificate for back-to-back arrangements does not cover fire rating, hence shall be accompanied by separate valid
type approval certificate for this.
Class A-0, A-15 and A-30 shall be insulated as class A-60.
For penetration systems acceptable for use in watertight bulkheads and deck divisions, only type approved
thermoplastic and multilayer plastic piping shall be used. The pipes shall have a nominal external pressure rating of at
least 1.0 bar.
Fire resistance and Water tightness Survey and Test Reports:
Test report DOC-002562 dated 31 October 2018 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-002621 dated 23 January 2019 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-002676 dated 5 March 2019 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-002700 dated 6 March 2019 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-002718 dated 13 March 2019 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-002719 dated 13 March 2019 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-002736 dated 15 March 2019 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-003037 dated 9 September 2019 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-003037 dated 18 February 2020 from Roxtec, Sweden and witnessed by DNV.
Test report DOC-002962 dated 7 August 2019 from Roxtec, Sweden and witnessed by DNV.
Form code: TA 281 Revision: 2023-09 www.dnv.com Page 2 of 3
Revision No: 3
Survey Report No. N141NBR5 dated 5 November 2018 from DNV Malmö.
Survey Report No. N141RA6Z dated 24 January 2019 from DNV Malmö.
Survey Report No. N141S7E5 dated 10 March 2019 from DNV Malmö.
Survey Report No. N141SGZW dated 10 March 2019 from DNV Malmö.
Survey Report No. N141SMF7 dated 15 March 2019 from DNV Malmö.
Survey Report No. N141SMF8 dated 15 March 2019 from DNV Malmö.
Survey Report No. N141SRGA dated 15 March 2019 from DNV Malmö.
Survey Report No. N141W15W dated 30 September 2019 from DNV Malmö.
Survey Report No. N141Y94A dated 20 February 2020 from DNV Malmö.
Survey Report No. N141Y94C dated 24 February 2019 from DNV Malmö.
Survey Report No. N141UBRY dated 7 August 2019 from DNV Malmö.
Survey Report No. N142G51K dated 11 November 2022 from DNV Malmö.
Survey Report No. N142K9GN dated 23 March 2023 from DNV Malmö.
Drawing No. S1026802 Rev.C dated 17 June 2020 from Roxtec.
Drawing No. S1590482 Rev.A dated 28 March 2023 from Roxtec.
The systems have been pressure tested with water up to 2 bars (RS PPS/S) / 1 bar (RS) immediately after an A-60
class bulkhead fire test. The fire test was based on the principles given in IMO 2010 FTP Code Part 3, except the
furnace size.
The pressure test was based on the test procedures described in resolution MSC.429(98) for compliance with regulation
II-1/13.2.1 and 13.2.3 of SOLAS-74 (2014 issue).
certificate and at least every second year. The arrangement is to be in accordance with procedure described in Class
Programme DNV-CP-0338, Section 4.
Form code: TA 281 Revision: 2023-09 www.dnv.com Page 3 of 3
