TAF00001NG
That the Class H Penetration
ROXTEC SEALING SYSTEM WITH MULTIDIAMETER TECHNOLOGY: RS-SERIES (PIPE)
DNV offshore standards
Approved as pipe penetration in class H-120 and H-60 steel decks and bulkheads.
Issued at Høvik on 2022-02-02
| This Certificate is valid until 2027-02-01. | Digitally Signed By: David-Andersen, Helene |
| DNV local station: Sweden CMC | Location: DNV Høvik, Norway |
Approval Engineer: Kristin Grønnæss
Helene David-Andersen
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 1 of 3 |
| Job Id: | 262.1-001101-20 | ||
| Certificate No: | TAF00001NG |
“Roxtec sealing system with multidiameter technology: RS-series”
consisting of steel sleeve, welded or bolted (openable versions included) to steel decks and steel bulkheads. The sleeve
is filled with Roxtec RS (standard or EMC) halogen free rubber sealing.
Approved as pipe penetration in class H-120 and H-60 in steel deck and bulkhead as specified in the tables below.
General application: Fire against either side*
- In areas with requirements to maximum steel temperature in load bearing constructions, the bulkhead is approved for
restricted application: Fire against insulated side
Table 1: Approved pipe penetration in H-120 steel bulkhead.
| Pipe | Sleeve | Sleeve |
| Pipe | Sleeve | |
| Type | Size | diameter |
| material | position | |
| (OD) [mm] | [mm] | [mm] |
| RS | 23 – 50 | Steel |
| RS | 23 – 150 | Steel |
| RS | 23 | Titanium |
| RS | 68 – 125 | GRE / GRP |
- Bolted sleeves are approved for restricted application only.
Table 2: Approved pipe penetration in H-60 steel bulkhead.
| Pipe | Sleeve | |
| RS | 23 – 400 | Steel |
| RS | 23 – 50 | Titanium |
Table 3: Approved pipe penetration in H-120 steel deck.
| Pipe | Sleeve | |
Table 4: Approved pipe penetration in H-60 steel deck.
| Pipe | Sleeve | |
Approved for steel pipe penetration in deck and bulkheads limited to a pressure of 4.00 bar water tightness and 2.67 bar
gas tightness.
Approved for GRP pipe penetration in deck and bulkheads limited to a pressure of 4.00 bar water tightness and 2 bar
gas tightness.
For bolted versions with gasket and self-tapping screws, the pressure is limited to 3.33 bar water tightness and 1.67 bar
gas tightness.
Pipe penetrations with plastic or composite pipes are not approved for use in watertight bulkheads on passenger ships
and special purpose vessels (SPS).
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 2 of 3 |
Each product is to be supplied with its manual for installation/application and maintenance.
Test report No. P601739 dated 28 June 2006 from SP, Borås, Sweden
Test report No. P601740 dated 28 June 2006 from SP, Borås, Sweden
Test report No. P703775 dated 7 December 2007 from SP, Borås, Sweden
Test report No. RS-19/B-036/E dated 21 March 2019 from CTO, Gdansk, Poland.
Test report No. RS-19/B-037/E dated 21 March 2019 from CTO, Gdansk, Poland.
Test report No. 21/22654-1652 dated 29 September 2021 from APPLUS, Barcelona, Spain.
Water tightness/gas tightness:
Inspection report MLM 010247 dated 21 August 2001 from DNV, Malmö, Sweden.
Inspection report MLM 010247 dated 28 September 2001 from DNV, Malmö, Sweden.
Inspection report MLM 030473-1 dated 27 January 2003 from DNV, Malmö, Sweden.
Survey report SKM-04-4088 dated 16 June 2004 from DNV, Stockholm, Sweden.
Inspection report MLM 060561 dated 1 December 2006 from DNV, Malmö, Sweden.
Drawing No. S1573488 Rev. A dated 12 November 2021 from manufacturer.
Drawing No. S1573419 Rev. B dated 18 January 2022 from manufacturer.
Drawing No. S1573480 Rev. B dated 18 January 2022 from manufacturer.
Drawing No. S1573457 Rev. B dated 18 January 2022 from manufacturer.
Drawing No. S1573390 Rev. B dated 26 January 2022 from manufacturer.
Tested according to IMO FTP Code Part 3 (IMO Res. A.754(18)) and with the hydrocarbon time-temperature curve
specified in ISO 834-3.
CP-0338 Section 4.
| Form code: TA 251 | Revision: 2021-03 | www.dnv.com | Page 3 of 3 |
