TAF00001SH-optimized
TAF00001SH
Roxtec sealing system technology: S-, RS-, and R-series
DNV statutory interpretations DNV-SI-0364 – SOLAS interpretations, Edition July 2021
DNV rules for classification – High speed and light craft
Approved for use as cable penetration system through fire resisting divisions 60 (FRP) on high-speed craft for
approved ship cables.
This certificate is recognized by Transport Canada.
Issued at Høvik on 2023-09-28
This Certificate is valid until 2028-09-27. Digitally Signed By: Permoda, Jowita
DNV local unit: Sweden CMC
Approval Engineer: Helge Bjørnarå
Jowita Permoda
Form code: TA 251 Revision: 2022-12 www.dnv.com Page 1 of 3
Job Id: 262.1-038405-1
Certificate No: TAF00001SH
Roxtec sealing system with multidiameter technology: S-, RS-, and R-series,
Consisting of a S-series frame bolted (SFHM Alu/Steel) or laminated/glued (SRC GRP) into an FRP section. The S
frame is filled with Roxtec (standard or EMC) halogen free RM modules. Assembled with Roxtec wedge kit (standard or
EMC).
Consisting of a SL sleeve bolted (SLFRS Alu/Steel) or laminated/glued (SL GRP) into an FRP section. The sleeve is
fitted with a Roxtec RS frame consisting of two halves with removable layers making it adaptable to a single cable of
different diameters.
Consisting of a SL sleeve bolted (SLFR Alu/Steel) or laminated/glued (SL GRP) into an FRP section. The sleeve is fitted
with a Roxtec R frame (standard or EMC). The R-frame is filled with Roxtec (standard or EMC) halogen free RM
modules.
Approved for use as cable penetration system through fire resisting divisions 60 (FRP) on high-speed craft for approved
ship cables. Other applications are subject to case-by-case approval.
Table 1: Approved cable penetration in fire resisting bulkhead 60 (FRP)
Max. cable Sleeve/ Sleeve/
Sleeve/Frame Sleeve/Frame Sleeve/Frame
type Length [mm] Thickness [mm]
[mm] position insulation
S 1-8 SFHM Alu/Steel
S 4-6 SRC GRP
R 50 - 200 SLFR Alu/Steel
R 50 - 200 SL GRP
RS 25 - 125 SL GRP
Table 2: Approved cable penetration in fire resisting deck 60 (FRP)
Max. cable Sleeve/
Type Size
type Length [mm]
[mm] insulation
S 1-8
S 4-6
R 50 - 200
R 50 - 200
RS 25 - 125
Approved for marine cables in RS frame in SL GRP sleeve in FRP bulkheads or decks limited to a pressure of 2.0 bar
watertightness and 1.0 bar gastightness.
Approved for marine cables in R frame in SL GRP sleeve in FRP bulkheads or decks limited to a pressure of 2.0 bar
Approved for marine cables in SRC GRP sleeve in FRP bulkheads or decks limited to a pressure of 2.0 bar
Each product is to be supplied with manual for installation and maintenance.
Form code: TA 251 Revision: 2022-12 www.dnv.com Page 2 of 3
Fire test:
Test report No. RS-20/B-253/E dated 9 July 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-254/E dated 4 August 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-341/E dated 22 October 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-417/E dated 19 January 2021 from CTO, Gdansk, Poland.
Drawing No. S1582662, Rev. A dated 24 August 2022 from maker.
Drawing No. S1582665, Rev. A dated 24 August 2022 from maker.
Drawing No. S1582678, Rev. A dated 25 August 2022 from maker.
Drawing No. S1582679, Rev. A dated 25 August 2022 from maker.
Drawing No. S1582680, Rev. A dated 25 August 2022 from maker.
Pressure test
Test report No. N141E2C, Rev.01, dated 19 February 2020 from DNV Sweden CMC.
Test report No. MLM 010238 dated 30 August 2001 from DNV Malmö.
Test report No. MLM 010235 dated 21 August 2001 from DNV Malmö.
Test report No. N142846G dated 2 November 2021 from DNV Sweden CMC.
Test report No. MLM 020400 dated 25 March 2002 from DNV Malmö.
Tested according to IMO 2010 FTP Code Part 3.
Pressure tests with water and helium according to DNV Type Approval Programme 8.471.19-1 and DNV-CP-0165.
Transport Canada Approval
Based on the procedures laid down in the Transport Canada publication entitled “Procedures for Approval of Life-Saving
Appliances, Fire Safety Systems, Equipment and Products (TP14612)”, DNV confirms that the product/s listed in this
certificate is/are in accordance with Transport Canada’s requirements.
CP-0338, Section 4.
Form code: TA 251 Revision: 2022-12 www.dnv.com Page 3 of 3
