TAF00001SJ
Roxtec sealing system technology: S-, RS-, and RS PPS/S series
DNV statutory interpretations DNV-SI-0364 – SOLAS interpretations, Edition July 2021
DNV rules for classification – High speed and light craft
Approved for use as pipe penetration system through fire resisting divisions 60 (FRP) on high-speed craft.
This certificate is recognized by Transport Canada.
Issued at Høvik on 2023-09-28
| This Certificate is valid until 2028-09-27. | Digitally Signed By: Permoda, Jowita |
DNV local unit: Sweden CMC
Approval Engineer: Helge Bjørnarå
Jowita Permoda
| Form code: TA 251 | Revision: 2022-12 | www.dnv.com | Page 1 of 3 |
| Job Id: | 262.1-038405-1 | ||
| Certificate No: | TAF00001SJ |
Roxtec sealing system with multidiameter technology: S-, RS-, and RS PPS/S series,
Consisting of a S-series frame bolted (SFHM Alu/Steel) or laminated/glued (SRC GRP) into an FRP section. The S
frame is filled with Roxtec (standard or EMC) halogen free RM modules. Assembled with Roxtec wedge kit (standard or
EMC).
Consisting of a SL sleeve bolted (SLFRS Alu/Steel) or laminated/glued (SL GRP) into an FRP section. The sleeve is
fitted with a Roxtec RS frame consisting of two halves with removable layers making it adaptable to a single cable of
different diameters.
fitted with a Roxtec RS PPS/S frame consisting of two halves with removable layers making it adaptable to a single
cable of different diameters.
Approved for use as pipe penetration system through fire resisting divisions 60 (FRP) on high-speed craft. Other
applications are subject to case-by-case approval.
Table 1: Approved pipe penetration in fire resisting bulkhead 60 (FRP)
| Sleeve/ | Sleeve/ |
| Pipe | Sleeve/ |
| Sleeve/Frame | Pipe |
| Type | Size |
| type | material |
| (OD) [mm] | position |
| [mm] | [mm] |
| Steel, | |
| S | 4-6 |
| Titanium | |
| Steel, | |
| RS | 23 - 150 |
| Titanium | |
| RS | 23 - 150 |
| RS | 50 - 450 |
| Steel, | |
| RS | 25 - 150 |
| Titanium | |
| RS | 25 - 150 |
| RS PPS/S | 31 |
| RS PPS/S | 31 – 12,5 |
| RS PPS/S | 50 - 150 |
| RS PPS/S | 50 - 125 |
Table 2: Approved pipe penetration in fire resisting deck 60 (FRP)
| Sleeve/ | Sleeve/ |
| Pipe | Sleeve/ |
| Type | Size |
| type | material |
| [mm] | [mm] |
| Steel, | |
| RS | 23 - 150 |
| Titanium | |
| RS | 23 - 150 |
| RS | 50 - 450 |
| Steel, | |
| RS | 25 - 150 |
| Titanium | |
| RS | 25 - 150 |
| RS PPS/S | 31 - 150 |
| RS PPS/S | 31 - 125 |
| Form code: TA 251 | Revision: 2022-12 | www.dnv.com | Page 2 of 3 |
Approved for steel and copper pipe in RS frame in SL GRP sleeve in FRP bulkheads or decks limited to a pressure of
2.0 bar watertightness and 1.0 bar gastightness.
Approved for thermoplastic and PE/ALU/PE pipe in RS PPS/S frame in SL GRP sleeve in FRP bulkheads or decks
limited to a pressure of 2.0 bar watertightness and 1.0 bar gastightness.
Approved for steel and copper pipe in SRC GRP sleeve in FRP bulkheads or decks limited to a pressure of 2.0 bar
Each product is to be supplied with manual for installation and maintenance.
Fire test:
Test report No. RS-20/B-253/E dated 9 July 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-254/E dated 4 August 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-341/E dated 22 October 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-426/E dated 23 November 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-417/E dated 19 January 2021 from CTO, Gdansk, Poland.
Assessment report No. 9P02428 dated 13 September 2019 from RISE, Sweden.
Drawing No. S1582682, Rev. A dated 25 August 2022 from maker.
Drawing No. S1582683, Rev. A dated 25 August 2022 from maker.
Drawing No. S1582684, Rev. A dated 25 August 2022 from maker.
Drawing No. S1582687, Rev. A dated 25 August 2022 from maker.
Drawing No. S1582688, Rev. A dated 25 August 2022 from maker.
Drawing No. S1582689, Rev. A dated 25 August 2022 from maker.
Pressure test:
Test report No. N141E2C, Rev.01, dated 19 February 2020 from DNV Sweden CMC.
Test report No. SKM-04-4088 dated 16 April 2004 from DNV Stockholm.
Test report No. MLM 010247 dated 28 September 2001 from DNV Malmö.
Test report No. N142177N dated 1 September 2020 from DNV Sweden CMC.
Test report No. N141ZEM0 dated 15 May 2020 from DNV Sweden CMC.
Test report No. N142846G dated 2 November 2021 from DNV Sweden CMC.
Test report No. MLM 020400 dated 25 March 2002 from DNV Malmö.
Test report No. MLM 050410 dated 20 May 2005 from DNV Malmö.
Tested according to IMO 2010 FTP Code Part 3.
Pressure tests with water and helium according to DNV Type Approval Programme 8.471.19-1 and DNV-CP-0165.
Transport Canada Approval
Based on the procedures laid down in the Transport Canada publication entitled “Procedures for Approval of Life-Saving
Appliances, Fire Safety Systems, Equipment and Products (TP14612)”, DNV confirms that the product/s listed in this
certificate is/are in accordance with Transport Canada’s requirements.
CP-0338, Section 4.
| Form code: TA 251 | Revision: 2022-12 | www.dnv.com | Page 3 of 3 |
