Transit Designer - New version 4.36.3 [2024-03-09]
4.36.3 - 2024-03-09
  • Fixed a bug where menu options in the packaging step would display incorrectly when undo/redo was used
  • Added a new option to Edit opening. There are now separate buttons to fill the opening with either spares or solids
4.36.2 - 2024-03-06
  • Improved the edit opening toolbar
4.36.1 - 2024-03-05
  • Enabled the “Match existing hole” feature for Roxtec users
4.36.0 - 2024-02-29
  • Fixed H6 frames not rendering correctly
  • Added a download drawing option to transits that no longer have certificates associated with them
4.35.0 - 2024-02-26
  • Added a limited tag to certain features to better indicate that these are not available for all users
  • Selected solution name is now shown during the design step
4.34.0 - 2024-02-18
  • Fixed an issue that occurred when swapping between a firestop and grid solution
  • Fixed an issue where the stayplate would place incorrectly in GK modules
  • Improved snapping when placing modules in GK openings
4.33.1 - 2024-02-05
  • Fixed Chinese text not generating correctly on info drawings
4.33.0 - 2024-01-30
  • Added a warning when trying to close / reload the page while there is unsaved data
  • Improved the “Create project from backup” dialogue
  • Added a popup window while the multi import is running to prevent user interaction that could cause issues.
  • Fixed frame sizes in the packing editor so they now align correctly
  • Improved auto packing of GK frames.
4.32.5 - 2024-01-22
  • Fixed an issue where a solution with a cover would create an error message when replaced with a corner solution
  • Removed transition animations when removing a row of cables
  • Fixed an issue that occurred when a large file was used for the multi import.
4.32.4 - 2024-01-19
  • Fixed an issue where GK solutions would incorrectly display the “Transit incomplete” status
  • The WOC (WithOut Core) descriptor was missing on certain CRF modules under module preferences
  • Improved the placement of module IDs on blueprints
  • Added a project setting that allows for scaling of the cable list in blueprints
  • Corrected the size of a table image in the help dialog
4.32.2 - 2023-12-22
  • Set the preference for CRF multidiameter solutions to prefer spare modules instead of solid spares.
  • When dragging a module between solutions, the module will be automatically changed if it does not fit in the solution it is dragged to.
  • Fixed an issue that occurred when adding corner modules on a SPK-S50 solution
  • Updated documentation for the standalone version
  • Fixed an issue where corner modules would display incorrectly in the packing editor.
4.32.1 - 2023-12-13
  • Fixed broken forum feeds on the dashboard
4.32.0 - 2023-12-11
  • Fixed that stayplates did not correctly place for modules with more then 4 corners
  • Improved the visual layout for the packaging editor. Stayplates no longer look like they might be overlapping.
4.31.0 - 2023-12-01
  • Fixed an issue where transits with multiple solutions would generate incorrect drawings
  • Added an option to select custom names for each side of a back to back frame
4.28.7 - 2023-10-20
  • Removed 0/0 as a recommended casting apeture on the Design and Summary steps
  • Available sleeve depth should now update when a new variant is selected in the Design step
  • Changed the display name of items in the Variants list in the Design step. The names should now describe the measurements more accurately.
  • Added a scrollbar to the Accessories dialog instead of using a full page scroll.
  • Fixed a bug where GK transits incorrectly showed as incomplete
  • Fixed a misaligned toolbar
