12509_D1 BV-optimized
Certificate number: 12509/D1 BV
File number: ACI4000/032/005 and 008
Product code: 5300H
PIPE, CABLE, DUCT PENETRATIONS IN FIRE DIVISIONS
RS series seals cable and pipe penetrations in A-Class Divisions
SOLAS 74, as amended, Regulations II-2/9.7.1.2
IMO Res MSC.307(88) (2010 FTP Code)
IMO Res. MSC.61(67)-(FTP Code) with IMO Res MSC.307(88) (2010 FTP Code) article 8
This certificate will expire on: 26 Feb 2023
At BV GOTHENBURG, on 29 Jan 2020,
Magne MOLLER
BV Mod. Ad.E 530 June 2017 This certificate consists of 5 page(s)
1. PRODUCT DESCRIPTION:
“Roxtec cable and pipe sealing system with multidiameter technology, RS, RS OMD, RS OC, RS PPS and RS PPS/S series” are
composed of steel sleeves with RS, RS OMD, RS OC, RS PPS or RS PPS/S type (Ex and EMC, PE, ES, BG, BGB versions
include) halogen free rubber sealing, welded, bolted (incl. SL A) or attached through expansion (RS X) onto the steel deck or
steel bulkhead.
1.1 - RS and RS OMD sealing systems with welded or bolted sleeves (SL, SLF and SLFO/RI) are approved for the
following services:
Outer diameter Seal size range A-60 class A-0 class
Service
(mm) (mm) (details of insulation) (details of insulation)
Deck: up to 82 Deck: 23-150
Cable S1526991 rev B (deck & bulkhead) S1527437 rev B (deck & bulkhead)
Bulkhead: up to 102 Bulkhead: 23-150
Deck: up to 558 Deck: 23-644
Steel pipe S1527114 rev A (deck & bulkhead) S1527448 rev B (deck & bulkhead)
Bulkhead: up to 558 Bulkhead: 23-644
Deck: up to 270 Deck: 25-350 S1527380 rev A (deck) S1527373 rev A (deck)
CuNi 90: 10 pipe
Bulkhead: up to 270 Bulkhead: 25-350 S1527374 rev A (bulkhead) S1527383 rev A (bulkhead)
Deck: up to 225 Deck: 23-300
Copper Pipe S1527108 rev A (deck & bulkhead) S1527070 rev A (deck & bulkhead)
Bulkhead: up to 108 Bulkhead: 23-150
FGC pipe Deck: up to 360 Deck: 68-450
S1527082 rev A (deck & bulkhead) S1527446 rev A (deck & bulkhead)
(GRE/GRP) Bulkhead: up to 89 Bulkhead: 68-125
Deck: up to 375 Deck: 100-450
GRE FR pipe S1527370 rev A (bulkhead) S1527371 rev A (deck & bulkhead)
Bulkhead: up to 375 Bulkhead: 100-450
Deck: up to 50 Deck: 31-100
Bundle pipes S1527051 rev A (deck & bulkhead) S1527436 rev A (deck & bulkhead)
Bulkhead: up to 50 Bulkhead: 31-100
1.2 - RS OC (Off Centre) with welded or bolted sleeves (SL, SLF and SLFO/RI) is approved for the following services:
Service
Deck: up to 273 Deck: 75-400
Steel pipe S1527542 rev A (deck & bulkhead) S1527549 rev A (deck & bulkhead)
Bulkhead: up to 10 Bulkhead: 75
1.3 - RS SLA sleeve is approved for the following services:
Service
Deck: up to 32 Deck: 25-75
Cable S1527399 rev A (deck & bulkhead) S1527400 rev A (deck & bulkhead)
Bulkhead: up to 32 Bulkhead: 25-75
Deck: up to 34 Deck: 25-75
Steel pipe S1527405 rev A (deck) S1527406 rev A (deck)
Bulkhead: - Bulkhead: -
Copper/ CuNi pipe S1527424 rev A (deck) S1527425 rev A (deck)
1.4 - RS X (RS with SLX sleeve) is approved for the following services:
Service
Deck: up to 168 Deck: 25-200
Cable S1527454 rev A (deck & bulkhead) S1527457 rev A (deck & bulkhead)
Bulkhead: up to 168 Bulkhead: 25-200
Steel pipe S1527435 rev A (deck & bulkhead) S1527452 rev A (deck & bulkhead)
1.5 - RS PPS/S sealing system with welded or bolted sleeves (SL, SLF and SLFO/RI) is approved for the following
service:
Service
Deck: up to 110 Deck: 31-150
Thermoplastic pipes S1527045 rev A (deck & bulkhead) S1527462 rev B (deck & bulkhead)
Bulkhead: up to 110 Bulkhead: 31-150
Deck: up to 63 Deck: 31-100
PE/ALU/PE pipes S1527619 rev A (deck & bulkhead) S1527623 rev A (deck & bulkhead)
Bulkhead: up to 63 Bulkhead: 31-100
1.6 - RS PPS sealing system with welded or bolted sleeves (SLPPS, SLFPPS) is approved for the following service:
Service
Deck: up to 315 Deck: 31-400
Thermoplastic pipes S1527468 rev A (deck & bulkhead) S1527469 rev A (deck & bulkhead)
Bulkhead: up to 315 Bulkhead: 31-400
PE/ALU/PE pipes S1527534 rev A (deck & bulkhead) S1527539 rev A (deck & bulkhead)
2. DOCUMENTS AND DRAWINGS:
As per the Manufacturer’s drawings:
2.1 - Insulation drawings N°:
- S1526991 rev B - S1527373 rev A - S1527425 rev A - S1527462 rev B
- S1527045 rev A - S1527374 rev A - S1527435 rev A - S1527468 rev A
- S1527051 rev A - S1527380 rev A - S1527436 rev A - S1527469 rev A
- S1527070 rev A - S1527383 rev A - S1527437 rev B - S1527534 rev A
- S1527082 rev A - S1527399 rev A - S1527446 rev A - S1527539 rev A
- S1527108 rev A - S1527400 rev A - S1527448 rev B - S1527542 rev A
- S1527114 rev A - S1527405 rev A - S1527452 rev A - S1527549 rev A
- S1527370 rev A - S1527406 rev A - S1527454 rev A - S1527619 rev A
- S1527371 rev A - S1527424 rev A - S1527457 rev A - S1527623 rev A
2.2 - Assembly drawings N°:
- S1005507 Rev D - S1005510 Rev E - S1007491 Rev B - S1007536 Rev B
3. TEST REPORTS:
3.1 - Bulkhead:
Laboratory Test report Dated Fire Rating As per
SINTEF, Norway 103070.25A 27/02/2003 A-0
SINTEF, Norway 103070.29A 16/10/2003 A-60
SP, Sweden P502921 20/11/2005 A-60
SP, Sweden P600993 24/03/2006 A-60
SP, Sweden P602999 25/10/2006 A-60 IMO FTP Code Annex 1 Part 3 [test
SP, Sweden P605253 22/01/2007 A-60 standard: IMO Resolution A.754(18)]
RIME, Japan 09-345E 24/02/2009 A-60
SP, Sweden P902394 04/05/2009 A-60
SP, Sweden PX05454 30/09/2010 A-60
SP, Sweden 4P06068 26/11/2014 A-60
DBI, Denmark PGA10650 20/03/2015 A-60
SP, Sweden 4P08662 08/05/2015 A-60
DBI, Denmark PGA10652 15/06/2015 A-0
SP, Sweden 6P04351 15/06/2016 A-60
DBI, Denmark PGA10870A 01/11/2016 A-60 IMO 2010 FTP Code Annex 1 Part 3
SP, Sweden 6P10024 31/01/2017 A-60
SP, Sweden 7P02024 16/05/2017 A-60
CTO, Poland RS-17/B-396/E 31/10/2017 A-60
DBI, Denmark PGA11301A 22/11/2018 A-0
RISE, Sweden 8P07094 rev.1 16/01/2020 A-0
3.2 - Deck:
Laboratory Report Dated Fire Rating As per
SINTEF, Norway 103070.25B 27/02/2003 A-0
SINTEF, Norway 103070.27B 12/06/2003 A-60
SINTEF, Norway 103070.29B 16/10/2003 A-60
SP, Sweden P502922 10/11/2005 A-60 IMO FTP Code Annex 1 Part 3 [test
SP, Sweden P603000 25/10/2006 A-60 standard: IMO Resolution A.754(18)]
SP, Sweden P701755 12/06/2007 A-60
RIME, Japan 09-346E 27/02/2009 A-60
DBI, Denmark PGA10025 24/10/2011 A-60
DBI, Denmark PGA10141 29/06/2012 A-60
SP, Sweden 4P07023 22/01/2015 A-60
DBI, Denmark PGA10649 08/03/2015 A-60
DBI, Denmark PGA10651 15/06/2015 A-0
SP, Sweden 5P03457 15/10/2015 A-60
DBI, Denmark PGA10723A 15/12/2015 A-0
DBI, Denmark PGA10800A 18/04/2016 A-60 IMO 2010 FTP Code Annex 1 Part 3
SP, Sweden 6P02249 17/05/2016 A-60
DBI, Denmark PGA10871A 31/10/2016 A-60
SP, Sweden 7P02167 19/06/2017 A-60
DBI, Denmark PGA11302A rev.1 16/01/2019 A-0
DBI, Denmark PGA11388A 14/08/2019 A-0
RISE, Sweden 8P07092 rev.1 16/01/2020 A-0
4. APPLICATION / LIMITATION:
4.1 - Approval valid for use in A-0, A-15, A-30 and A-60 class divisions.
4.2 - The arrangement of cable and pipe penetrations (with fire insulation, if any) is subject to approval in each case.
4.3 - The insulation material shall comply with the requirements of the relevant Bureau Veritas rules and be type approved:
4.4 - The tests have been carried out with various types of insulation materials; any alternative A-class insulation material,
previously proven and approved, giving at least an equivalent insulation performance, can be used.
4.5 - The fitting aboard to be the same as used for the test.
5.1 - The “RS series seals” are to be supplied by ROXTEC International AB in compliance with the type described in this
certificate.
The product or packing is to be marked with Manufacturer name, type, designation and fire-technical rating.
7. OTHERS:
7.2 - This certificate supersedes the Type Approval Certificate N° 12509/D0 BV issued on 29/06/2018 by the Society.
7.3 - Testing of the penetrations for gastightness and watertightness as per following inspection reports, witnessed by Third
Party surveyor (DNV):
Product Class Report Dated
SL A DNV-GL N141EX8Z 10/08/2017
SLFO/RI DNV MLM090673 08/10/2009
MLM060511, 28/02/2006
RS PPS DNV
MLM070656 18/04/2007
SLX DNV MLM030473-1 27/01/2003
Bolted sleeve DNV MLM020401 25/03/2002
Outcomes of those inspection reports are the following:
Test pressure water Test pressure gas
Product
tightness tightness
RS series seals 6 bar
Welded SL, SLF, SLPPS, SLFPPS
6 bar 3 bar
sleeve
SLX sleeve 6 bar
Bolted SLF, SLFPPS sleeve 5 bar
SL A sleeve 4 bar
SLFO/RI sleeve 2 bar
