12509_E0 BV-optimized
Certificate number: 12509/E0 BV
File number: ACI4000/032/005 and 008
Product code: 5300H
PIPE, CABLE, DUCT PENETRATIONS IN FIRE DIVISIONS
A-0/A-60 Class Roxtec Sealing System with Multidiameter™ Technology:
RS-Series, RS PPS and RS PPS/S seals for steel divisions
(certified products, sleeve position and achieved performance - see §1)
SOLAS 74, as amended, Regulations II-2/9
IMO Res. MSC.61(67)-(FTP Code) with IMO Res MSC.307(88) (2010 FTP Code) article 8
IMO Res. MSC.307(88) (2010 FTP Code)
IMO MSC.1/Circ. 1488
IMO MSC.1/Circ. 1276
This certificate will expire on: 30 Nov 2028
At BV GOTHENBURG, on 30 Nov 2023,
Hans-erik ERICSSON
signature
BV Mod. Ad.E 530 June 2017 This certificate consists of 12 page(s)
1. PRODUCT DESCRIPTION:
Roxtec sealing system with MultidiameterTM: RS-series in steel divisions
The Roxtec RS cable and pipe penetration seal consists of two halves with removable layers, making it adaptable to a single
cable or pipe of different sizes. It is available in different versions, RS, RS OMD, RS PE, RS ES, RS BG, or RS EX,
depending on application.
The RS-seal is installed into a steel sleeve that is either welded, bolted, attached through expansion (SLFRS X) or attached
with a nut (SLA) onto the steel division.
Roxtec sealing system with MultidiameterTM: RS PPS/S in steel divisions
The Roxtec RS PPS/S penetration seal consists of two halves with integrated intumescent and removable layers, making it
adaptable to a single pipe of different size.
The RS PPS/S-seal is installed into a steel sleeve that is either welded or bolted onto the steel division.
Roxtec sealing system with MultidiameterTM: RS PPS in steel divisions
The Roxtec RS PPS is a back-to-back solution, consisting of two seals and intumescent sealing strip. Each seal consists of two
halves with removable layers, making it adaptable to single pipe of different size.
The RS PPS-sealing kit is installed into a steel sleeve that is either welded or bolted onto the steel division.
Additional insulation on penetrations and/or cables/pipes:
  • should be approved as having the same level of performance as the penetrated division and expected classification of
penetration,
  • is to be fitted as shown in the referred Manufacturer’s drawings (see §2) and also according to Manufacturer’s insulation
guidelines.
1.1 – Metal pipes and GRE pipes
1.1.1 – A-60 bulkhead
RS-Seals Sleeve type Pipe Pipe Sleeve Sleeve Sleeve Insulation drawing
size material diameter length thickness position
(mm) (mm) (mm)
23 - 400 SLRS-Series (1) Steel 6 – 330 35 - 65 4-7 Any S1587909 Rev. B dated 20/11/23
ID 1-4
23 - 644 SLRS-Series (1) Steel 6 - 558 35 - 65 4–7 Unexposed S1587909 Rev. B dated 20/11/23
ID 5
23 - 300 SLRS-Series (1) Copper 6 - 222 35 - 65 4-7 Any S1587909 Rev. B dated 20/11/23
ID 6-9
25 - 500 SLRS-Series (1) CuNi 10 - 420 35 - 65 4-7 Any S1587909 Rev. B dated 20/11/23
ID 10-13
50 - 125 SLRS-Series (1) GRE 25 - 1040 35 - 65 4-7 Any S1587909 Rev. B dated 20/11/23
ID 14-15
25 - 100 SLRS-Series (1) Bundle 8 - 50 35 - 65 4-7 Any S1587909 Rev. B dated 20/11/23
pipe ID 16
(steel)
23 - 150 SLRS-Series (2) Steel 6 - 114 Up to 4-7 Any S1587906 Rev. B dated 20/11/23
400 ID 1-3
23 - 150 SLRS-Series (2) Copper 6 - 108 Up to 4-7 Any S1587906 Rev. B dated 20/11/23
400 ID 4-6
25 - 150 SLRS-Series (2) CuNi 10 - 108 Up to 4-7 Any S1587906 Rev. B dated 20/11/23
400 ID 7-8
50 - 125 SLRS-Series (2) GRE 25 -90 Up to 4-7 Any S1587906 Rev. B dated 20/11/23
400 ID 9
25 - 100 SLRS-Series (2) Bundle 8 - 50 Up to 4-7 Any S1587906 Rev. B dated 20/11/23
pipe 400 ID 10
(steel)
25 - 75 SLA Steel 6 - 30 47 - 86 4-6 Any S1587910 Rev. A dated 29/05/23
ID 1
25 - 75 SLA Copper 6 - 34 47 - 86 4-6 Any S1587910 Rev. A dated 29/05/23
ID 2-4
25 - 75 SLA CuNi 6 - 34 47 - 86 4-6 Any S1587910 Rev. A dated 29/05/23
ID 5-7
25 - 200 SLFRS X Steel 6 - 168 65 4-7 Unexposed S1587913 Rev. A dated 26/05/23
ID 1-2
(mm) (mm) (mm)
25 - 150 SLFRS X Copper 6 - 108 65 4-7 Unexposed S1587913 Rev. A dated 26/05/23
ID 3-4
25 - 150 SLFRS X CuNi 6 - 108 65 4-7 Unexposed S1587913 Rev. A dated 26/05/23
ID 5-6
(1) SLRS-series includes the following sleeve types: SLRS, SLRS Ex or sleeves equal to dimensions specified in drawing S1586454 Rev A
(2) SL-series are longer versions of the sleeves in SLRS-series
1.1.2 – A-60 deck
(mm) (mm) (mm)
23 - 400 SLRS-Series (1) Steel 6 - 323 35 - 65 4-7 Any S1587914 Rev. A dated 26/05/23
ID 1-3
23 - 644 SLRS-Series (1) Steel 6 - 558 35 - 65 4-7 Unexposed S1587914 Rev. A dated 26/05/23
ID 4
23 - 150 SLRS-Series (1) Copper 6 - 108 35 - 65 4-7 Any S1587914 Rev. A dated 26/05/23
ID 5-7
25 - 300 SLRS-Series (1) Copper 6 - 225 35 - 65 4-7 Any S1587914 Rev. A dated 26/05/23
ID 8
25 - 500 SLRS-Series (1) CuNi 10 - 420 35 - 65 4-7 Any S1587914 Rev. A dated 26/05/23
ID 9-13
50 - 1125 SLRS-Series (1) GRE 25 - 1040 35 - 65 4-7 Any S1587914 Rev. A dated 26/05/23
ID 14-16
25 - 100 SLRS-Series (1) Bundle 8 - 50 35 - 65 4-7 Any S1587914 Rev. A dated 26/05/23
pipe ID 17
(steel)
23 - 150 SLRS-Series (2) Steel 6 - 114 Up to 4-7 Any S1587915 Rev. A dated 25/01/23
400 ID 1-2
23 - 150 SLRS-Series (2) Copper 6 - 108 Up to 4-7 Any S1587915 Rev. A dated 25/01/23
400 ID 3-5
25 - 150 SLRS-Series (2) CuNi 10 - 108 Up to 4-7 Any S1587915 Rev. A dated 25/01/23
400 ID 6-8
25 - 100 SLRS-Series (2) Bundle 8 - 50 Up to 4-7 Any S1587915 Rev. A dated 25/01/23
pipe 400 ID 9
(steel)
25 - 75 SLA Steel 6 - 30 47 - 86 4-6 Unexposed S1587929 Rev. A dated 14/06/23
ID 1
25 - 75 SLA Copper 6 - 34 47 - 86 4-6 Unexposed S1587929 Rev. A dated 14/06/23
ID 2-3
25 - 75 SLA CuNi 6 - 34 47 - 86 4-6 Unexposed S1587929 Rev. A dated 14/06/23
ID 4-5
25 - 200 SLFRS X Steel 6 - 168 65 4-7 Any S1587931 Rev. A dated 29/05/23
ID 1-2
25 - 150 SLFRS X Copper 6 - 108 65 4-7 Any S1587931 Rev. A dated 29/05/23
ID 3-4
25 - 150 SLFRS X CuNi 6 - 108 65 4-7 Any S1587931 Rev. A dated 29/05/23
ID 5-6
** Following on next page**
1.1.3 – A-0 bulkhead
(mm) (mm) (mm)
23 - 400 SLRS-Series (1) Steel 6 - 323 35 - 65 4-7 Any S1587933 Rev. B dated 16/11/23
ID 1-3
23 - 644 SLRS-Series (1) Steel 6 - 558 35 – 65 4–7 Unexposed S1587933 Rev. B dated 16/11/23
ID 4
23 - 300 SLRS-Series (1) Copper 6 - 222 35 - 65 4-7 Any S1587933 Rev. B dated 16/11/23
ID 5-7
25 - 500 SLRS-Series (1) CuNi 10 - 420 35 - 65 4-7 Any S1587933 Rev. B dated 16/11/23
ID 8-11
50 - 1125 SLRS-Series (1) GRE 25 - 1040 35 - 65 4-7 Any S1587933 Rev. B dated 16/11/23
ID 12-13
25 - 100 SLRS-Series (1) Bundle 8 - 50 35 - 65 4-7 Any S1587933 Rev. B dated 16/11/23
pipe ID 14
(steel)
23 - 150 SLRS-Series (2) Steel 6 - 114 Up to 4-7 Any S1587935 Rev. B dated 16/11/23
400 ID 1-3
23 - 150 SLRS-Series (2) Copper 6 - 108 Up to 4-7 Any S1587935 Rev. B dated 16/11/23
400 ID 4-6
25 - 150 SLRS-Series (2) CuNi 10 - 108 Up to 4-7 Any S1587935 Rev. B dated 16/11/23
400 ID 7-8
50 - 125 SLRS-Series (2) GRE 25 -90 Up to 4-7 Any S1587935 Rev. B dated 16/11/23
400 ID 9
25 - 100 SLRS-Series (2) Bundle 8 - 50 Up to 4-7 Any S1587935 Rev. B dated 16/11/23
pipe 400 ID 10
(steel)
25 - 75 SLA Steel 6 - 30 47 - 86 4-6 Any S1587938 Rev. A dated 29/05/23
ID 1
25 - 75 SLA Copper 6 - 34 47 - 86 4-6 Any S1587938 Rev. A dated 29/05/23
ID 2-4
25 - 75 SLA CuNi 6 - 34 47 - 86 4-6 Any S1587938 Rev. A dated 29/05/23
ID 5-7
25 - 200 SLFRS X Steel 6 - 168 65 4-7 Unexposed S1587940 Rev. A dated 29/05/23
ID 1-2
25 - 150 SLFRS X Copper 6 - 108 65 4-7 Unexposed S1587940 Rev. A dated 29/05/23
ID 3-4
25 - 150 SLFRS X CuNi 6 - 108 65 4-7 Unexposed S1587940 Rev. A dated 29/05/23
ID 5-6
1.1.4 – A-0 deck
(mm) (mm) (mm)
23 - 400 SLRS-Series (1) Steel 6 - 323 35 - 67 4-7 Any S1587941 Rev. B dated 16/11/23
ID 1-4
23 - 644 SLRS-Series (1) Steel 6 - 558 35 – 65 4–7 Unexposed S1587941 Rev. B dated 16/11/23
ID 5
23 - 300 SLRS-Series (1) Copper 6 - 225 35 - 65 4-7 Any S1587941 Rev. B dated 16/11/23
ID 6-9
25 - 500 SLRS-Series (1) CuNi 10 - 420 35 - 65 4-7 Any S1587941 Rev. B dated 16/11/23
ID 10-14
50 - 1125 SLRS-Series (1) GRE 35 - 1040 35 - 65 4-7 Any S1587941 Rev. B dated 16/11/23
ID 15-17
25 - 100 SLRS-Series (1) Bundle 8 - 50 35 - 65 4-7 Any S1587941 Rev. B dated 16/11/23
pipe ID 18
(steel)
23 - 150 SLRS-Series (2) Steel 6 - 114 Up to 4-7 Any S1588591 Rev. A dated 29/05/23
400 ID 1-2
23 - 150 SLRS-Series (2) Copper 6 - 108 Up to 4-7 Any S1588591 Rev. A dated 29/05/23
400 ID 3-5
25 - 150 SLRS-Series (2) CuNi 10 - 108 Up to 4-7 Any S1588591 Rev. A dated 29/05/23
400 ID 6-8
25 - 100 SLRS-Series (2) Bundle 8 - 50 Up to 4-7 Any S1588591 Rev. A dated 29/05/23
pipe 400 ID 9
(steel)
25 - 75 SLA Steel 6 - 30 47 - 86 4-6 Unexposed S1588541 Rev. A dated 14/06/23
ID 1
25 – 75 SLA Copper 6 – 34 47 – 86 4–6 Unexposed S1588541 Rev. A dated 14/06/23
ID 2-3
25 – 75 SLA CuNi 6 – 34 47 – 86 4–6 Unexposed S1588541 Rev. A dated 14/06/23
ID 4-5
25 – 200 SLFRS X Steel 6 – 168 65 4–7 Any S1588592 Rev. A dated 29/05/23
ID 1-2
25 - 150 SLFRS X Copper 6 - 108 65 4-7 Any S1588592 Rev. A dated 29/05/23
ID 3-4
25 - 150 SLFRS X CuNi 6 - 108 65 4-7 Any S1588592 Rev. A dated 29/05/23
ID 5-6
1.2 – Plastic pipes
1.2.1 – A-60 bulkhead
RS-Seals Sleeve Type Pipe material Pipe diameter Sleeve Insulation drawing
size (mm) position
31 - 450 RS PPS Thermoplastic* 16 – 355 Any S1587873 Rev. A dated 05/06/23
ID 1-2
31 - 150 RS PPS PE/ALU/PE 16 – 110 Any S1587873 Rev. A dated 05/06/23
ID 3-4
125 - 400 RS PPS Pre-insulated 90 - 315 Any S1587873 Rev. A dated 05/06/23
thermoplastic pipe ID 5
31 – 150 RS PPS/S Thermoplastic* 16 – 110 Any S1587875 Rev. A dated 05/06/23
ID 1
31 – 100 RS PPS/S PE/ALU/PE 16 - 63 Any S1587875 Rev. A dated 05/06/23
ID 2
125 – 150 RS PPS/S Pre-insulated 75 - 110 Any S1587875 Rev. A dated 05/06/23
thermoplastic pipe ID 3-4
100 – 125 RS PPS/S Pre-insulated 67 - 96 Any S1587875 Rev. A dated 05/06/23
plastic bundle ID 5
pipe
*PP, PVC, PB, ABS, PE, PVDF
1.2.2 – A-60 deck
size (mm) position
31 – 450 RS PPS Thermoplastic* 16 - 355 Any S1587874 Rev. A dated 07/06/23
ID 1-2
31 -150 RS PPS PE/ALU/PE 16 – 110 Unexposed S1587874 Rev. A dated 07/06/23
ID 3
125 - 400 RS PPS Pre-insulated 90 - 315 Any S1587874 Rev. A dated 07/06/23
thermoplastic ID 4
pipe
100 – 125 RS PPS Pre-insulated 67 - 96 Unexposed S1587874 Rev. A dated 07/06/23
plastic bundle ID 5
pipe
31 – 150 RS PPS/S Thermoplastic* 16 – 110 Any S1587876 Rev. B dated 16/11/23
ID 1
31 – 125 RS PPS/S PE/ALU/PE 16 - 75 Any S1587876 Rev. B dated 16/11/23
ID 2-3
31 – 75 RS PPS/S PE/ALU/PE with 16 - 50 Any S1587876 Rev. B dated 16/11/23
armaflex ID 4
68 – 100 RS PPS/S Plastic bundle 36 – 60 Any S1587876 Rev. B dated 16/11/23
pipe ID 5
100 – 125 RS PPS/S Pre-insulated 67 – 96 Any S1587876 Rev. B dated 16/11/23
plastic bundle ID 6
pipe
125 – 150 RS PPS/S Pre-insulated 75 – 110 Any S1587876 Rev. B dated 16/11/23
thermoplastic ID 7
pipe
1.2.3 – A-0 bulkhead
size (mm) position
31 - 450 RS PPS Thermoplastic* 16 - 355 Any S1587877 Rev. A dated 07/06/23
ID 1-2
31 - 150 RS PPS PE/ALU/PE 16 – 110 Any S1587877 Rev. A dated 07/06/23
ID 3-4
125 - 400 RS PPS Pre-insulated 90 - 315 Any S1587877 Rev. A dated 07/06/23
thermoplastic ID 5
pipe
31 – 150 RS PPS/S Thermoplastic* 16 – 110 Any S1587879 Rev. A dated 15/06/23
ID 1-2
31 – 100 RS PPS/S PE/ALU/PE 16 - 63 Any S1587879 Rev. A dated 15/06/23
ID 3
125 –150 RS PPS/S Pre-insulated 75 – 110 Any S1587879 Rev. A dated 15/06/23
thermoplastic ID 4-5
pipe
100 – 125 RS PPS/S Pre-insulated 67 - 96 Any S1587879 Rev. A dated 15/06/23
plastic bundle ID 6
pipe
1.2.4 – A-0 deck
size (mm) position
31 – 450 RS PPS Thermoplastic* 16 - 355 Any S1587878 Rev. A dated 07/06/23
ID 1-2
31 – 150 RS PPS PE/ALU/PE 16 - 32 Any S1587878 Rev. A dated 07/06/23
ID 3-4
125 – 400 RS PPS Pre-insulated 90 - 315 Any S1587878 Rev. A dated 07/06/23
thermoplastic ID 5
pipes
100 - 125 RS PPS Pre-insulated 67 - 96 Unexposed S1587878 I Rev. A dated 07/06/23
plastic bundle ID 6
pipe
31 - 150 RS PPS/S Thermoplastic* 16 - 110 Any S1587080 Rev. A dated 07/06/23
ID 1
31 - 125 RS PPS/S PE/ALU/PE 16 - 75 Any S1587080 Rev. A dated 07/06/23
ID 2-3
31 – 125 RS PPS/S PE/ALU/PE with 16 - 75 Any S1587080 Rev. A dated 07/06/23
armaflex ID 4
68-100 RS PPS/S Plastic bundle 36 - 60 Any S1587080 Rev. A dated 07/06/23
pipes ID 5
100-125 RS PPS/S Pre-insulated 67 - 96 Any S1587080 Rev. A dated 07/06/23
plastic bundle ID 6
pipe
125-150 RS PPS/S Pre-insulated 75 - 110 Any S1587080 Rev. A dated 07/06/23
thermoplastic pipe ID 7
1.3 – Cables
1.3.1 – A-60 bulkhead
RS-Seals Sleeve type Cable Cable Sleeve Sleeve Sleeve Insulation drawing
size diameter length thickness position
(mm) (mm) (mm)
23 - 150 SLRS-Series (1) Marine Up to 100 47 - 86 4-7 Any S1587074 Rev. A dated 30/05/23
Cable ID 1-2
25 - 75 SLA Marine Up to 32 47 - 86 4-6 Any S1587072 Rev. A dated 30/05/23
Cable ID 1-3
23 – 125 SLFRS-X Marine Up to 86 65 4-7 Unexposed S1587076 Rev. A dated 30/05/23
Cable ID 1
25 - 125 SLRS-Series (2) Marine Up to 90 Up to 400 4-7 Any S1587078 Rev. A dated 30/05/23
Cable ID 1
1.3.2 – A-60 deck
(mm) (mm) (mm)
23 – 150 SLRS-Series (1) Marine Up to 100 47 - 86 4-7 Any S1587074 Rev. A dated 30/05/23
Cable ID 3
25 – 75 SLA Marine Up to 32 47 - 86 4-6 Any S1587072 Rev. A dated 30/05/23
Cable ID 4-6
25 – 125 SLFRS-X Marine Up to 90 65 4-7 Exposed S1587076 Rev. A dated 30/05/23
Cable ID 2
Cable ID 2
1.3.3 – A-0 bulkhead
(mm) (mm) (mm)
23 – 150 SLRS-Series (1) Marine Up to 47 - 86 4-7 Any S1587063 Rev. B dated 16/11/23
Cable 100 ID 1
25 - 75 SLA Marine Up to 33 47 - 86 4-6 Any S1587065 Rev. A dated 09/06/23
Cable ID 1-3
23 – 125 SLFRS-X Marine Up to 86 65 4-7 Unexposed S1587079 Rev. A dated 30/05/23
Cable ID 1
25 - 125 SLRS-Series (2) Marine Up to 90 Up to 400 4-7 Any S1588275 Rev. A dated 30/05/23
Cable ID 1
1.3.4 – A-0 deck
(mm) (mm) (mm)
23 - 125 SLRS-Series (1) Marine Up to 86 47 - 86 4-7 Any S1587063 Rev. B dated 16/11/23
Cable ID 2
25 - 75 SLA Marine Up to 32 47 - 86 4-6 Any S1587065 Rev. A dated 09/06/23
Cable ID 4-6
25 – 125 SLFRS-X Marine Up to 90 65 4-7 Exposed S1587079 Rev. A dated 30/05/23
Cable ID 2
Cable ID 2
2. DOCUMENTS AND DRAWINGS:
As per the Manufacturer’s insulation drawings quoted in tables in §1.
3. TEST REPORTS:
3.1 – Metal pipes
3.1.1.1 – A-60 bulkhead
Test report N° Dated Laboratory
| PX05454 | 8th September 2011 | SP, Sweden |
| PGA10650 | 18th May 2015 | DBI, Denmark |
| 4P08662 | 8th June 2015 | SP, Sweden |
| 4P06068 | 17th January 2015 | SP, Sweden |
| 6P04351 | 22nd June 2016 | SP, Sweden |
| RS-18/B-022/E | 29th January 2018 | CTO, Poland |
| RS-18/B-485/E | 10th December 2018 | CTO, Poland |
| RS-19/B-035/E | 25th February 2019 | CTO, Poland |
| RS-19/B-355/E | 16th October 2019 | CTO, Poland |
| RS-20/B-017/E | 23rd January 2020 | CTO, Poland |
| PGB10020A | 5th May 2020 | DBI, Denmark |
| RS-20/B-191/E | 5th June 2020 | CTO, Poland |
| RS-21/B-241/E | 30th June 2021 | CTO, Poland |
| RS-21/B-445/E | 7th October 2021 | CTO, Poland |
| RS-21/B-519/E | 15th December 2021 | CTO, Poland |
| RS-22/B-336/E | 28th October 2022 | CTO, Poland |
| RS-22/B-395/E | 15th November 2022 | CTO, Poland |
| PGB10233A | 12th December 2022 | DBI, Denmark |
All tests as per IMO 2010 FTP Code, Annex 1, part 3
3.1.2 – A-60 deck
09-346E 11th December 2009 * RIME, Japan
4P07023 4th February 2015 SP, Sweden
PGA10649 18th May 2015 DBI, Denmark
PGA10800A 26th May 2016 DBI, Denmark
6P02249 17th August 2016 SP, Sweden
7P02167 7th August 2017 SP, Sweden
PGA10871A 17th November 2017 DBI, Denmark
RS-18/B-023/E 29th January 2018 CTO, Poland
RS-18/B-484/E 10th December 2018 CTO, Poland
RS-19/B-356/E 18 October 2019 CTO, Poland
PGA11611A 11th January 2020 DBI, Denmark
PGB10032A 1st July 2020 DBI, Denmark
PGB10047A 30th November 2020 DBI, Denmark
PGB10111A rev.1 20th September 2021 DBI, Denmark
PGB10118A 15th November 2021 DBI, Denmark
PGB10172A 3rd May 2022 DBI, Denmark
RS-22/B-337/E 28th October 2022 CTO, Poland
All tests as per IMO 2010 FTP Code, Annex 1, part 3, except * as per per IMO FTP Code, Annex 1, part 3 [test standard:IMO
Resolution A.754(18)].
3.1.3 – A-0 bulkhead
RS-20/B-081/E 31st March 2020 CTO, Poland
RS-21/B-517/E 10th November 2021 CTO, Poland
PGB10178A 4th November 2022 DBI, Denmark
All tests as per IMO 2010 FTP Code, Annex 1, part 3.
3.1.4 – A-0 deck
RS-18/B-292/E 13th September 2018 CTO, Poland
PGA11302A 16th January 2019 CTO, Poland
PGA11610A 10th January 2020 DBI, Denmark
PGB10110A 27th April 2021 DBI, Denmark
PGB10119A 15th November 2021 DBI, Denmark
3.2 – Plastic pipes
3.2.1 – A-60 bulkhead
P902394 25th May 2009 * SP, Sweden
6P10024 7th Mars 2017 SP, Sweden
RS_19_B_355_E 16th October 2019 CTO, Poland
RS_19_B_424_E 27th November 2019 CTO, Poland
8P07094 16th January 2020 SP, Sweden
RS-20_B-083E 20th April 2020 CTO, Poland
PGB10030A 16th July 2020 DBI, Denmark
3.2.2 – A-60 deck
09-346E 27th February 2009 * RIME, Japan
PGA10025 22nd December 2011 * DBI, Denmark
PGA10141 10th July 2012 DBI, Denmark
RS-18_B-023_E 29th January 2018 CTO, Poland
8P04040 16th August 2018 SP, Sweden
RS-18_B-484_E 10th December 2018 CTO, Poland
RS_19_B_256_E 20th August 2019 CTO, Poland
RS_19_B_356_E 18th October 2019 CTO, Poland
PGB10113A 23rd July 2021 DBI, Denmark
PGB10116A 2nd August 2021 DBI, Denmark
PGB10177A 4th November 2022 DBI, Denmark
3.2.3 – A-0 bulkhead
RS-18_B-291_E 20th August 2018 CTO, Poland
RS-18_B-293_E 13th September 2018 CTO, Poland
PGA11301A 22nd November 2018 DBI, Denmark
8P07094 23rd September 2019 DBI, Denmark
RS-21_B-240E 30th June 2021 CTO, Poland
3.2.4 – A-0 deck
RS-18_B-292_E 13th September 2018 CTO, Poland
PGA11302A 16th January 2019 DBI, Denmark
4. APPLICATION / LIMITATION:
4.1 - Approved for use:
  • in A-15, A-30, A-60 class steel divisions, with fire insulation as described in §1,
  • in A-0 class steel divisions, with local fire insulation arrangement (on the penetration itself as described in §1 and
200 mm around) or without fire insulation.
4.2 - The pipe penetration system has only been evaluated with regard to its fire resistance only. For installation in watertight
bulkhead below the bulkhead deck, specific rules may require to subject the pipe penetrations to a prototype test of
watertightness after having undergone the standard fire test for A-class divisions described in IMO 2010 FTP Code Annex 1
Part 3.
5.1 - The “A-Class Single-Cable or Single-Pipe Sealing System with Multidiameter Technology, RS-series seals” are to be
supplied by ROXTEC International AB in compliance with the type described in this certificate.
5.3 - ROXTEC International AB has to make the necessary arrangements to have its works recognized by Bureau Veritas in
The product or packing is to be marked with Manufacturer name, type, designation and fire-technical rating.
7. OTHERS:
7.2 - This certificate supersedes the Type Approval Certificate N° 12509/D1 BV issued on 29/01/2020 by the Society.
7.3 - Testing of the penetrations for gastightness and watertightness as per following inspection reports, witnessed by Third
Party surveyor (DNV):
7.3.1 – Metal pipes
Statement N14254FG dated 30/04/2021 issued by DNV Welded sleeves - GRE pipe, RS 1125
Statement N1421782 dated 01/09/2021 issued by DNV Welded sleeves – Steel pipes, RS 23-64
Inspection report MLM060561 dated 01/12/2006 issued by DNV Welded sleeves - GRE pipe, RS 68-500 /
Bundle pipes, RS 43-100
Inspection report MLM 030473-1 dated 27/01/2003 issued by DNV SLFRS X – RS 223-200, test of expansion sleeve function
Inspection report MLM090673 dated 08/10/2009 issued by DNV SLFO/RI sleeve, RS 23-644, test for bolted openable
sleeves
Statement N142G50V dated 11/11/2022 issued by DNV Welded long sleeves - Steel pipes, RS 23-150
Statement N141EX8Z rev.2 dated 10/08/2017 issued by DNV SLA sleeve, RS 25-100
Statement N142JK51 dated 27/02/2023 issued by DNV Bolted sleeves – RS 23-150/SLFRS
7.3.2 – Plastic pipes
Inspection report MLM060511 dated 28/02/2006 issued by DNV Plastic pipes, RS-400
Inspection report MLM070656 dated 18/04/2007 issued by DNV Plastic pipes, RS PPS 31-175
Statement N141ZEM0 dated 15/05/2020 issued by DNV Thermoplastic pipes, RS PPS/S 31–150
Statement N141ZEM1 dated 15/05/2020 issued by DNV Pre-insulated thermoplastic pipes, RS PPS 125–400
Statement N141ZEM2 dated 15/05/2020 issued by DNV Pre-insulated thermoplastic pipes, RS PPS/S 125–150
Statement N142299W rev.1 dated 09/11/2020 issued by DNV Thermoplastic pipes, RS PPS 31–450
Survey report SKM-04-4088 dated 16/06/2004 issued by DNV Plastic pipes, RS PPS 31–150
7.3.3 – Cables
Inspection report MLM010235 dated 21/08/2001 issued by DNV Cables, RS 23–50 and RS 125
Inspection report MLM020133 dated 26/02/2002 issued by DNV Cables,RS 23-150 OMD
Inspection report MLM020406 dated 07/05/2002 issued by DNV Cables, RS 23-125
Inspection report MLM030473 dated 27/01/2003 issued by DNV Cables, SLFRS X, RS 23-200
Statement N142G50V dated 11/11/2022 issued by DNV Long sleeves - Cables, RS 23 -150
Statement N1428HVZ dated 24/11/2021 issued by DNV Cables, RS BG 25–150
Tightness performances:
Sleeve type Mounting option Watertightness Gastightness
SLRS-Series (1) Welded 6 bar 3 bar
SLFRS-Series (2) Bolted 3,75 bar 1.5 bar
SLFO-Series (2) Bolted openable 2 bar 1 bar
SLFRS X Expansion 6 bar 3 bar
SLA Bolted 4.5 bar 1.5 bar
SL-Series (3) Welded 3 bar 1.5 bar
| Sleeve type | Pipe material | Watertightness | Gas tightness |
| SL PPS | Thermoplastic | 6 bar | 3 bar |
| SL PPS/S | Thermoplastic | 6 bar | 3 bar |
| SL PPS | Pre-insulated thermoplastic | 3 bar | 1,5 bar |
| SL PPS/S | Pre-insulated thermoplastic | 3 bar | 1,5 bar |
(1) SLRS-series includes the following sleeve types: SLRS, SLRS Ex or sleeves equal to Roxtec dimensions
(2) Installed with pre-punched gasket
(3) SL-series are longer versions of the sleeves in SLRS-series
