15027_D4 BV-optimized
Certificate number: 15027/D4 BV
File number: ACI4000/032/007
Product code: 5302H
CABLE PENETRATIONS IN FIRE DIVISIONS
H-0 / H-30 / H-60 / H-120 Class Cable Penetrations
Cable sealing system with multidiameterTM technology,
S-series, R-series and RS-seals
(certified products, frame position and achieved performance - see §1)
Bureau Veritas Rules for the Classification of Offshore Units - Part C, Chapter 4
IMO Res. MSC.307(88) (2010 FTP Code) IMO Res. MSC.307(88) (2010 FTP Code) with Hydrocarbon Fire Temperature Curve
IMO Res. MSC.61(67)-(FTP Code) with IMO Res MSC.307(88) (2010 FTP Code) article 8 with Hydrocarbon Fire Temperature
Curve
This certificate will expire on: 04 May 2026
At BV GOTHENBURG, on 16 Jan 2024,
Hans-erik ERICSSON
signature
BV Mod. Ad.E 530 June 2017 This certificate consists of 7 page(s)
1. PRODUCT DESCRIPTION:
H-Class ROXTEC cable sealing systems with multidiameter™ technology
1.1 - Roxtec sealing system with multidiameter™ technology, S-series (steel divisions)
Consists of Roxtec S-Series frames with a depth of 60 mm (S, S Ex, SF, SFHM, SO, SFO, SFOH, SR/T, SR/S, SRC r20,
SRC r40, SRC r60) in height 1-8 and width 60-120, and combinations thereof, welded to the steel sections.
Also included in the S- series are the subgroup of SK-series frames with a single barrier with a depth of more than 60 mm
(SK, SK Ex, SFK, SFOK, SFOHK, SRCK r20, SRCK r40, SRCK r60) and the subgroup SBTB-Series frames with two
barriers (SBTB, SBTB Ex, SFBTB, SRBTB, SRCBTB r20, SRCBTB r40, SRCBTB r60).
The S-series (including subgroups) is filled with Roxtec halogen free RM modules[1].
Assembled with Roxtec Wedge, Roxtec ES Wedge, Roxtec Ex Wedge or Roxtec ES Ex Wedge and corresponding stayplates.
[1] Standard RM, RM Ex, RM ES, RM ES B, RM PE, RM PE B, RM BG, RM BG B, RM ES Ex, RM ES B Ex, RM PE Ex, RM ES
B Ex, RM BG Ex, RM BG B Ex
Additional insulation on penetrations and/or cables:
  • should be approved as having the same level of performance as the penetrated division and expected classification of
penetration,
  • is to be fitted as shown in the referred Manufacturer’s drawings (see tables below) and also according to Manufacturer’s
insulation guidelines.
1.1.1 – H-60 Bulkhead
Frame Max. cable Frame depth Frame Max. filling Insulation arrangement
diameter [mm] position ratio
[mm]
S-Series 90 60 Any 44% S1596160 Rev B dated 21/11/2023 ID 1
8x1
S-Series 90 60 Any 46% S1596160 Rev B dated 21/11/2023 ID 2-3
1x1 up to 8+8x5
S-Series 96 60 Any 39% S1596160 Rev B dated 21/11/2023 ID 4-5*
1x1 up to 8+8x3
S-Series 49 60 Unexposed 21% S1596160 Rev B dated 21/11/2023 ID 6-7*
1x1 up to 8+8x3
SK-Series 103 200 Any 38% S1596172 Rev B dated 27/11/2023 ID 1
8x2
SK-Series 103 200 Any 38% S1596172 Rev B dated 27/11/2023 ID 2
8+8x2
SBTB-Series 90 200 Any 49% S1596172 Rev B dated 27/11/2023 ID 3
1x1 up to 8x4
SBTB-Series 21 200 Unexposed 14% S1596172 Rev B dated 27/11/2023 ID 4*
1x1 up to 8+8x2
*Restricted application – Refer to §4.2 (one fire hazard side on the insulated side of bulkhead)
Following on next pagae
1.1.2 – H-120 Bulkhead
[mm]
S-Series 80 60 Unexposed 22% S15596187 Rev B dated 27/11/2023 ID 1*
1x1 up to 8x1
S-Series 80 60 Unexposed 16% S15596187 Rev B dated 27/11/2023 ID 2*
1x1 up to 6+6x2
SBTB-Series 88 200 Unexposed 28% S15596187 Rev B dated 27/11/2023 ID 3*
4x1 up to 8x4
1.1.3 – H-0 Deck
Frame Max. cable Frame depth Frame position Max. Insulation arrangement
diameter [mm] filling
[mm] ratio
S-Series 90 60 Unexposed 37% S1596202 Rev B dated 09/11/2023 ID 4
1x1 up to 8+8x10
SK-Series 90 600 Unexposed 33% S1596202 Rev B dated 09/11/2023 ID 3
1x1 up to 8x1
SBTB-Series 90 320 Unexposed or 50 mm 37% S1596202 Rev B dated 09/11/2023 ID 2
2x1 up to 6+6x5 exposed side /
150 mm unexposed
side
SBTB-Series 90 200 Unexposed or 15 mm 37% S1596202 Rev B dated 09/11/2023 ID 1
1x1 up to 8+8x3 exposed side /
305 mm unexposed
side
1.1.4 – H-60 Deck
[mm]
S-Series 90 60 Unexposed 37% S1596189 Rev A dated 11/09/2023 ID 1-3
1x1 up to 8+8x10
SK-Series 90 100-400 Any 40% S1596190 Rev A dated 11/09/2023 ID 1-2
1x1 up to 8+8x5
SBTB-Series 90 200-400 Any 40% S1596190 Rev A dated 11/09/2023 ID 3-4
1x1 up to 8+8x3
1.1.5 – H-120 Deck
[mm]
S-Series 90 60 Unexposed 16% S1596191 Rev B dated 27/11/2023 ID 1
2x1 up to 8x1
S-Series 90 60 Unexposed 10% S1596191 Rev B dated 27/11/2023 ID 2
2x1 up to 6x2
S-Series 90 60 Any 5% S1596191 Rev B dated 27/11/2023 ID 3-4
1x1 up to 88x2
SK-Series 90 100-400 Any 40% S1596201 Rev A dated 11/09/2023 ID 1-2
1x1 up ti 8+8x5
SBTB-Series 90 200-400 Any 40% S1596201 Rev A dated 11/09/2023 ID 3-4
1x1 up to 8+8x5
1.2 - Roxtec sealing system with multidiameter™ technology: R-series (steel division)
Consists of a rubber frame filled with Roxtec RM modules of different sizes depending on diameter and configuration of the
cables. It is available in standard, Ex and EMC versions depending on application.
The R-seal is installed into a steel sleeve that is welded or bolted onto the steel division.
penetration,
1.2.1 – H-60
Division Size Max. cable Frame depth Frame Max. filling Insulation arrangement
orientation diameter [mm] position ratio
[mm]
Bulkhead 50-200 90 55 Any 44%
| Bulkhead* | 50-200 | 62 | 55 | Unexposed | 26% | S1596210 Rev B dated 30/10/2023 ID 2 |
| Deck | 50-200 | 88 | Min. 55 | Unexposed | 42% | S1596210 Rev B dated 30/10/2023 ID 1 |
*Restricted application – Refer to §4.3 (one fire hazard side on the insulated side of bulkhead)
1.2.2 – H-120
[mm]
Bulkhead* 50-200 62 55 Unexposed 23%
| Deck | 50-200 | 88 | Min. 55 | Unexposed | 42% | S1596211 Rev B dated 30/10/2023 ID 1 |
1.3 - Roxtec sealing system with multidiameter™ technology: RS-series (steel division)
Consists of two halves with removable layers making it adaptable to a single cable of different diameters. It is available in
different versions, RS, RS OMD, RS EMC or RS EX, depending on application.
The RS-seal is installed into a steel sleeve that is either welded or bolted onto the steel division.
penetration,
H-60 / H-120
Division SizeMax. cable Frame depth Frame Max. filling Insulation arrangement
[mm]
Bulkhead 23-125 90 Diam. 23-31: Any
min. 35
Diam. 43-125:
min. 65
Bulkhead* 23-150 90 Diam: 23-31 Any N/A S1596206 Rev B dated 30/10/2023 ID 2
min. 35
Diam: 43-125:
min. 65
Deck 23-125 88 Diam. 23-31: Unexposed N/A S1596206 Rev B dated 30/10/2023 ID 3
min. 35
Diam. 43-125:
min. 65
NOTE : filling ratio indicated in the tables is to be considered as the ratio between the total section of cables fitted inside the
penetration and the total available packing space area.
2. DOCUMENTS AND DRAWINGS
2.1 - As per the Manufacturer’s insulation drawings quoted in tables in §1.
2.2 - For S-series : technical statement (effect of the orientation on fire performance) n°PHD10048A dated 12/01/2022, from
DBI, Denmark.
3. TEST REPORTS :
3.1 – S-Series
Division Orientation Test report N° Dated Laboratory
Deck 846007.06* 19/09/1997 SINTEF, Norway
Deck PG11088 18/02/2003 DBI, Denmark
Bulkhead PG11199* 04/07/2003 DBI, Denmark
Bulkhead P400834* 31/03/2004 DBI, Denmark
Bulkhead P703775* 07/12/2007 DBI, Denmark
Bulkhead PX07235* 15/12/2010 DBI, Denmark
Deck 3P04210 24/09/2013 SP, Sweden
Deck 4P02192 30/06/2014 SP, Sweden
Deck 6P02536 12/07/2016 SP, Sweden
Bulkhead R23234.01.301 13/04/2018 SWRI, USA
Bulkhead RS-19/B-037/E 21/03/2019 CTO, Poland
Bulkhead PGB10170A 20/05/2022 DBI, Denmark
Bulkhead PGB10171A 20/05/2022 DBI, Denmark
Bulkhead RS-22/B-396/E 28/11/2022 CTO, Poland
Deck PGB10215A 04/05/2023 DBI, Denmark
Deck PGB10216A 09/05/2023 DBI, Denmark
All tests as per IMO 2010 FTP Code, Annex 1, part 3 with Hydrocarbon Fire Temperature Curve,
except * as per IMO FTP Code, Annex 1, part 3 [test standard: IMO Resolution A.754(18) with Hydrocarbon Fire Temperature
Curve].
3.2 – R-Series
Bulkhead PG11087* 12/02/2003 DBI, Denmark
Deck RS-19/B-036/E 21/03/2019 CTO, Poland
Bulkhead PGB10120A 17/12/2021 DBI, Denmark
Curve].
3.3 – RS-Series
Curve].
4. APPLICATION / LIMITATION :
4.1 - Approved for use as cable transits in H-0 to H-120 Class steel divisions with limitations contained in §1.
4.2 - For S-Series :
- Bulkhead: the use of cable penetration systems in bulkheads is restricted to application where on board fire hazard has
been identified as being from the bulkhead’s insulated side (refer to §1.1.1 and 1.1.2 for concerned cable penetration
systems).
- Deck: Approval is limited to cable penetration systems fitted on the upper side of the deck (refer to §1.1.3, 1.1.4 and 1.1.5
for concerned cable penetration systems) or with frame lowered below deck (refer to §1.1.3 for concerned cable penetration
systems).
4.3 - For R-Series and RS-Series :
  • Bulkhead (refer to §1.2 and §1.3 for concerned cable penetration systems): the use of cable penetration systems in
    bulkheads is restricted to application where on board fire hazard has been identified as being from the bulkhead’s insulated
side.
- Deck : Approval is limited to cable penetration systems fitted on the upper side of the deck.
4.4 - Filling ratio not to exceed the one tested (see § 1).
5.1 - The ROXTEC cable sealing system with multidiameter technologyTM, S-series, R-series and RS-series are to be
supplied by ROXTEC International AB in compliance with the type described in this certificate.
5.4 - For information, ROXTEC International AB has declared to Bureau Veritas the following production site(s):
Rombvägen 2
371 23 KARLSKRONA
6. MARKING OF PRODUCT :
7. OTHERS :
7.2 - This Certificate supersedes the Type Approval Certificate N° 15027/D3 BV issued on 31/08/2022 by the Society.
7.3 - Watertightness and Gastightness:
Third Party Inspection reports from DNV, Norway: N° MLM 010235 dated 21/08/2001
N° MLM 010238 dated 30/08/2001
N° MLM 020106 dated 19/12/2001
N° MLM 020133 dated 26/02/2002
N° MLM 020408 dated 03/06/2002
  • Tested watertightness (before fire exposure): 6 bar during 60 min.
  • Tested gastightness (before fire exposure): 4 bar during 30 min.
