17-LD1633274-PDA-optimized
Certificate Number: 17-LD1633274-PDA
14/JUN/2017
Please refer to the “Service Restrictions” shown below to determine if Unit Certification is required for this product.
This certificate reflects the information on the product in the ABS Records as of the date and time the certificate is
printed.
Pursuant to the Rules of the American Bureau of Shipping (ABS), the manufacturer of the below listed product held
a valid Manufacturing Assessment (MA) with expiration date of 13-JUN-2022. The continued validity of the
Manufacturing Assessment is dependent on completion of satisfactory audits as required by the ABS Rules.
And; a Product Design Assessment (PDA) valid until subject to continued compliance with the Rules or standards
used in the evaluation of the product.
The above entitle the product to be called Product Type Approved.
The Product Design Assessment is valid for products intended for use on ABS classed vessels, MODUs or facilities
which are in existence or under contract for construction on the date of the ABS Rules used to evaluate the
Product.
ABS makes no representations regarding Type Approval of the Product for use on vessels, MODUs or facilities
built after the date of the ABS Rules used for this evaluation.
Due to wide variety of specifications used in the products ABS has evaluated for Type Approval, it is part of our
contract that; whether the standard is an ABS Rule or a non-ABS Rule, the Client has full responsibility for
continued compliance with the standard.
Product Name: Penetration Device for Pipe Deck and Bulkhead Penetration
Sealing
Model Name(s): Roxtec SPM Seal Series – SPM 39- 279
Presented to:
ROXTEC INTERNATIONAL AB
BOX 540
S-371 23
Intended Service: Single pipe penetration in Class A-0, A15, A30 and A60 bulkheads and decks for
Marine and Offshore Applications. Penetration of watertight and gas-tight steel
bulkheads and decks up to rated pressure.
Description: Roxtec Sealing System, Roxtec SPM seal series consisting of halogen free rubber
seal in sizes 39-279 attach through expansion to steel sections.
Tier: 3
Ratings: Fire Resistance - bulkheads and decks A0, A15, A30 and A60 Bulkheads and
Decks, Water tightness test pressure: 1.5 bar g. Gas tightness test pressure : 1.0
bar g.
Service Restrictions: a) Outside diameter 8 to 220mm for steel pipes for bulkheads and decks. b)
Outside diameter 8 to 220mm for copper pipes for bulkheads. c) Outside diameter
8 to 222mm for copper pipes for decks. d) Not for use in tank boundaries. e)
Transits are to be insulated as per the approved ABS drawing for all fire division
ratings. f) Unit Certification is not required for this product. If the manufacturer or
purchaser’s request an ABS Certificate for compliance with a specification or
standard, the specification or standard, including inspection standards and
tolerances, must be clearly defined.
Comments: a) All seal type should be installed in accordance with the manufacturers
| 06/14/2017 6:06:50 AM | Copyright 2001 American Bureau of Shipping. All rights reserved. | Page 1 of 3 |
instructions in accordance with ABS approved installation drawings. b) Insulation
material is to be A60 approved type and properly installed in accordance with ABS
approved drawings to the satisfaction of the Surveyors c) Watertight bulkheads or
decks are to be tested as per ABS Steel Vessel Rules 3-7-1/Table 1. d) When
requested to be used in watertight bulkheads on passenger ships or special
purpose ships, the penetration system has to comply with the requirements give in
SOLAS Ch. 11-1 Reg. 13.2.3 (2014 Consolidated Edition or latest issue). e) This
approval of penetrations passing through watertight bulkhead is not to be
construed as a substitute for flag Administration’s approval for the purpose of
SOLAS 2014 Consolidated Edition. f) The Manufacturer has provided a declaration
about the control of, or the lack of Asbestos in this product.
Notes / Documentation: a) Test Report No. 5P03451, SP Technical Research Institute of Sweden, IMO
Test of Pipe Penetration Seals in A60 Steel Bulkhead, dated 3 November 2015 b)
Test Report No. 5P03457, SP Technical Research Institute of Sweden, IMO Test
of Cable Penetration Seals in A60 Steel Deck, dated 12 November 2015 c) Test
Report No. 5P08346, SP Technical Research Institute of Sweden, IMO Test of
Pipe Penetration Seals in A60 Steel Bulkhead , dated 21 December 2015 d) Test
Report No. 5P08343, SP Technical Research Institute of Sweden, IMO Test of
Pipe Penetration Seals in A60 Steel Deck, dated 21 December 2015 e) Test
Report No. 5P08395, SP Technical Research Institute of Sweden, IMO Test of
Pipe Penetration Seals in A60 Steel Deck, dated 17 March 2016 f) Test Report
No.6P05989, SP Technical Research Institute of Sweden, IMO Test of Pipe
Penetration Seals in A60 Steel Deck, dated 24 October 2016 g) Test Report
No.6P05990, SP Technical Research Institute of Sweden, IMO Test of Pipe
Penetration Seals in A60 Steel Bulkhead, dated 24 October 2016 h) Test Report
No. PGA10870A , DBI, Danish Institute of Fire and Security Technology, IMO Test
of Pipe Penetration Seals in A60 Steel Bulkhead, dated 13 December 2016 I)
Drawing No. S1522607, Roxtec SPM Seal With Steel Pipe A-Class Steel
Bulkhead, Revision: A, Dated 8 May 2017 j) Drawing No. S1522614, Roxtec SPM
Seal With Copper Pipe A-Class Steel Bulkhead, Revision: A, Dated 8 May 2017 k)
Drawing No. S1522615, Roxtec SPM Seal With Steel Pipe A-Class Steel Deck,
Revision: A, Dated 8 May 2017 l) Drawing No. S1522616, Roxtec SPM Seal With
Copper Pipe A-Class Steel Deck, Revision: A, Dated 8 May 2017 m) Drawing No.
S1522617, Roxtec SPM Seal With Steel Pipe A-0 Class Steel Bulkhead, Revision:
A, Dated 8 May 2017 n) Drawing No. S1522618, Roxtec SPM Seal With Copper
Pipe A-0 Class Steel Bulkhead, Revision: A, dated 08 May 2017 o) Drawing No.
S1522619, Roxtec SPM Seal With Steel Pipe A-0 Class Steel Deck, Revision: A,
Dated 08 May 2017 p) Drawing No. S1522620, Roxtec SPM Seal With Copper
Pipe A-0 Class Steel Deck, Revision: A, Dated 08 May 2017 q) Drawing No.
S1502970 , ESPM 39-279 Assembly, Revision: D, r) Document DOC-0000116,
Installation Instructions Roxtec SPM Seal, Version A s) Pressure Test Report No.
N1417RRN, DNV Survey Report, dated 29 January 2016 t) Pressure Test Report
No. N141805A, DNV Survey Report, dated 20 December 2016 u) Certificate
Number. MEDB00000NV, DNV GL Issued Updated MED Certificate, Revision: 2 u)
Roxtec SPM seal Product presentation, Revision: A,
Term of Validity: This Product Design Assessment (PDA) Certificate 17-LD1633274-PDA, dated
14/Jun/2017 remains valid until 13/Jun/2022 or until the Rules or specifications
used in the assessment are revised (whichever occurs first). This PDA is intended
for a product to be installed on an ABS classed vessel, MODU or facility which is in
existence or under contract for construction on the date of the ABS Rules or
specifications used to evaluate the Product. Use of the Product on an ABS classed
vessel, MODU or facility which is contracted after the validity date of the ABS Rules
and specifications used to evaluate the Product, will require re-evaluation of the
PDA. Use of the Product for non ABS classed vessels, MODUs or facilities is to be
to an agreement between the manufacturer and intended client.
ABS Rules: The Rules applicable to this assessment are: 2017 Rules for Building and Classing
Steel Vessels 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-6-2/9.7; 2017 Rules for Building and
Classing Facilities on offshore installations 1-1-A2, 1-1-A3, 1-1-4/9.7, 3-8/9.13,
4-8/9.13; 2017 Mobile Offshore Drilling Units Rules 1-1-A2, 1-1-A3, 1-1-4/9.7,
4-2-1/11.15
National Standards:
International Standards: Regulation II-2/ 9.3.1 of SOLAS (2014 Consolidated Edition); IMO Resolution
MSC.307(88) - (2010 FTP Code), Annex I: Part 3, adopted on 3 December 2010
06/14/2017 6:06:50 AM Copyright 2001 American Bureau of Shipping. All rights reserved. Page 2 of 3
Government Authority: This PDA conforms to Transport of Canada requirements
EUMED:
Others:
Model Certificate Model Certificate No Issue Date Expiry Date
PDA 17-LD1633274-PDA 14-JUN-2017 13-JUN-2022
ABS Programs
ABS has used due diligence in the preparation of this certificate and it represents the information on the product in the ABS Records as of the
date and time the certificate was printed. Type Approval requires Drawing Assessment, Prototype Testing and assessment of the
manufacturer’s quality assurance and quality control arrangements. Limited circumstances may allow only Prototype Testing to satisfy Type
Approval. The approvals of Drawings and Products remain valid as long as the ABS Rule, to which they were assessed, remains valid. ABS
cautions manufacturers to review and maintain compliance with all other specifications to which the product may have been assessed. Further,
unless it is specifically indicated in the description of the product; Type Approval does not necessarily waive witnessed inspection or survey
procedures (where otherwise required) for products to be used in a vessel, MODU or facility intended to be ABS classed or that is presently in
class with ABS. Questions regarding the validity of ABS Rules or the need for supplemental testing or inspection of such products should, in all
06/14/2017 6:06:50 AM Copyright 2001 American Bureau of Shipping. All rights reserved. Page 3 of 3
