18-LD1722578-PDA-optimized
Certificate Number: 18-LD1722578-PDA
07/JUN/2018
Please refer to the “Service Restrictions” shown below to determine if Unit Certification is required for this product.
This certificate reflects the information on the product in the ABS Records as of the date and time the certificate is
printed.
Pursuant to the Rules of the American Bureau of Shipping (ABS), the manufacturer of the below listed product held
a valid Manufacturing Assessment (MA) with expiration date of 29-MAY-2023. The continued validity of the
Manufacturing Assessment is dependent on completion of satisfactory audits as required by the ABS Rules.
And; a Product Design Assessment (PDA) valid until subject to continued compliance with the Rules or standards
used in the evaluation of the product.
The above entitle the product to be called Product Type Approved.
The Product Design Assessment is valid for products intended for use on ABS classed vessels, MODUs or facilities
which are in existence or under contract for construction on the date of the ABS Rules used to evaluate the
Product.
ABS makes no representations regarding Type Approval of the Product for use on vessels, MODUs or facilities
built after the date of the ABS Rules used for this evaluation.
Due to wide variety of specifications used in the products ABS has evaluated for Type Approval, it is part of our
contract that; whether the standard is an ABS Rule or a non-ABS Rule, the Client has full responsibility for
continued compliance with the standard.
Product Name: Penetration Device for Pipe Deck and Bulkhead Penetration
Sealing
Model Name(s): Roxtec SPM seal series in Aluminium divisions.
Presented to:
ROXTEC INTERNATIONAL AB
ROMBVAGEN 2
SE 371 65
Intended Service: Single pipe penetration in Class A-0, A15, A30 and A60 bulkheads and decks for
Marine and Offshore Applications. Penetration of watertight and gas-tight
aluminium bulkheads and decks up to rated pressure.
Description: Roxtec Sealing System, Roxtec SPM seal series , consisting of halogen free
rubber seal in sizes 39-279 attached through expansion to steel sections.
Tier: 3
Ratings: Fire Resistance - A0, A15, A30 and A60 Bulkheads and Decks Water tightness test
pressure: 1.5 bar g. Gas tightness test pressure : 1.0 bar g.
Service Restrictions: a) Maximum and Minimum tested Steel Pipes: 222 mm & 8 mm outside diameter.
b) Maximum and Minimum tested Copper Pipes: 110 mm & 8 mm outside
diameter. c) Maximum and Minimum Size of Transit Frame - SPM 279 ( Aperture
Diameter 283 mm) & SPM 39 ( Aperture Diameter 41 mm) d) Not for use in tank
boundaries. e) Transits are to be insulated as per the approved ABS drawings for
all fire division ratings. f) For fire class A-0, A-15 and A-30, sleeves are to be
insulated as for class A-60 and in addition the division is to be insulated at least
200 mm around the penetration. g) Unit Certification is not required for this product.
If the manufacturer or purchaser’s request an ABS Certificate for compliance with a
specification or standard, the specification or standard, including inspection
06/07/2018 1:33:13 AM Copyright 2001 American Bureau of Shipping. All rights reserved. Page 1 of 3
standards and tolerances, must be clearly defined.
Comments: a) All seal type should be installed in accordance with the manufacturers
instructions and ABS approved installation drawings. b) Insulation material is to be
A60 approved type and properly installed in accordance with ABS approved
drawings to the satisfaction of the Surveyors. c) Watertight bulkheads or decks are
to be tested as per ABS Steel Vessels Rules 3-7-1/Table 1. d) When requested to
be used in watertight bulkheads on passenger ships or special purpose ships, the
penetration system has to comply with the requirements give in SOLAS Ch. 11-1
Reg. 13.2.3 (2014 Consolidated Edition or latest issue). This approval of
penetrations passing through watertight bulkhead is not to be construed as a
substitute for flag Administration’s approval for the purpose of SOLAS 74/78 (2014
Consolidated Edition). e)The product or packing is to be marked with name of
manufacturer, type designation and fire rating. f) The Manufacturer has provided a
declaration about the control of, or the lack of Asbestos in this product.
Notes / Documentation: 1) Test Report Number RS-17B-209E, Centrum Techniki Okretowej S. A, ,
Gdanak, Poland, IMO Fire Test of Pipe Penetration Seals in A60 Aluminium
Bulkhead , dated 02 June 2017. 2) Test Report Number RS-17B-210E, Centrum
Techniki Okretowej S. A, , Gdanak, Poland, IMO Fire Test of Pipe Penetration
Seals in A60 Aluminium Deck, dated 02 June 2017 3) Test Report Number
N1419WS4, Pressure test report, DNV Survey Report, dated 20 December 2016 4)
Document Number DOC-0000116 Version C, Installation instructions Drawings: 5)
Drawing No. S1502970, SPM 39-279 Assembly, Revision: D 6) Drawing No.
S1527309, Revision: A, Roxtec SPM Seal With Steel Pipe A-Class Aluminium
Bulkhead. 7) Drawing No. S1527311, Revision: A, Roxtec SPM Seal With Copper
Pipe A-Class Aluminium Bulkhead. 8) Drawing No. S1527305, Revision: A, Roxtec
SPM Seal With Steel Pipe A-Class Aluminium Deck. 9) .Drawing No.S1527306,
Revision: A, Roxtec SPM Seal With Copper Pipe A-Class Aluminium Deck
Term of Validity: This Product Design Assessment (PDA) Certificate 18-LD1722578-PDA, dated
30/May/2018 remains valid until 29/May/2023 or until the Rules or specifications
used in the assessment are revised (whichever occurs first). This PDA is intended
for a product to be installed on an ABS classed vessel, MODU or facility which is in
existence or under contract for construction on the date of the ABS Rules or
specifications used to evaluate the Product. Use of the Product on an ABS classed
vessel, MODU or facility which is contracted after the validity date of the ABS Rules
and specifications used to evaluate the Product, will require re-evaluation of the
PDA. Use of the Product for non ABS classed vessels, MODUs or facilities is to be
to an agreement between the manufacturer and intended client.
ABS Rules: 2018 Rules for Building and Classing Steel Vessels 1-1-4/7.7, 1-1-A3, 1-1-A4,
4-6-2/9.7 2018 Mobile Offshore Drilling Units Rules 1-1-4/9.7, 1-1-A2, 1-1-A3,
4-2-1/11.15
National Standards:
International Standards: Regulation II-2/ 9.3.1 of SOLAS (2014 Consolidated Edition) IMO Resolution
MSC.307(88) - (2010 FTP Code), Annex I: Part 3, adopted on 3 December 2010
Government Authority: This PDA conforms to Transport Canada Requirements
EUMED:
Others:
Model Certificate Model Certificate No Issue Date Expiry Date
PDA 18-LD1722578-PDA 04-JUN-2018 29-MAY-2023
ABS Programs
ABS has used due diligence in the preparation of this certificate and it represents the information on the product in the ABS Records as of the
date and time the certificate was printed. Type Approval requires Drawing Assessment, Prototype Testing and assessment of the
manufacturer’s quality assurance and quality control arrangements. Limited circumstances may allow only Prototype Testing to satisfy Type
Approval. The approvals of Drawings and Products remain valid as long as the ABS Rule, to which they were assessed, remains valid. ABS
cautions manufacturers to review and maintain compliance with all other specifications to which the product may have been assessed. Further,
unless it is specifically indicated in the description of the product; Type Approval does not necessarily waive witnessed inspection or survey
06/07/2018 1:33:13 AM Copyright 2001 American Bureau of Shipping. All rights reserved. Page 2 of 3
procedures (where otherwise required) for products to be used in a vessel, MODU or facility intended to be ABS classed or that is presently in
class with ABS. Questions regarding the validity of ABS Rules or the need for supplemental testing or inspection of such products should, in all
06/07/2018 1:33:13 AM Copyright 2001 American Bureau of Shipping. All rights reserved. Page 3 of 3
