19-1835887-PDA-DUP-optimized
Model(s): Roxtec RS Seals
Product Design Assessment (PDA) 19-1835887-PDA-DUP 05-JUL-2023 16-JUN-2024
Single pipe and cable penetrations in Class H-60/-120 bulkheads and decks. Penetrations of watertight
and gastight steel bulkheads and decks up to the specified pressure.
“Roxtec cable sealing system with multidiameter technology” composed of steel sleeves (welded or
bolted) with RS- type (EMC versions included) halogen free rubber sealings mounted in steel decks or
bulkheads.
H-60/-120 Bulkheads and Decks- For Steel Pipes and Cables
H-60/-120 Bulkheads- For Fibreglass composite pipes
H-60/H120 Bulkheads and Decks - For Titanium Pipes with RS23 seal
H-60 Bulkheads and Decks - For Titanium Pipes with RS50 seal
Gastight test pressure 4 bar (except bolted versions test pressure at 2.5 bar and 3 bar test pressure for
penetrations installed with fibreglass composite pipes)
a) Maximum tested cable diameter is 96 mm, maximum tested steel pipe outside diameter is 323 mm,
maximum tested fibreglass composite pipe outside diameter is 90 mm, maximum tested Titanium pipe
11/17/2023 4:25:09 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 4
Certificate Number: 19-1835887-PDA-DUP
outside diameter is 26.7 mm.
b) Maximum and Minimum tested seal sizes:
- 23-150 for cable penetrations ( bulkhead )
- 23-125 for cable penetrations ( Deck )
- 23-400 for steel pipe services
  • 68 -125 for fibreglass composite pipe services.( Bulkhead)
- 23-50 for Titanium Pipes
c) For cables penetration on H60/ H120 bulkheads, fire is to be from insulated side only.
d) Tested with Marine Power/ Instrumentation/Control Cables.
e) Not for use in tank boundaries
f) Unit Certification is not required for this product. If the manufacturer or purchaser request an ABS
a) All seal types should be installed in accordance with the manufacturer’s instructions and ABS
approved installation drawings.
b) Insulation material is to be H-60/-120 approved type and properly installed to the satisfaction of the
Surveyors. (Insulation drawings: S1014898 Rev A, S1014894 Rev A, S1014895 Rev A, S1014896 Rev
A , S1014897 Rev A, S1014899 Rev A).
c) Watertight or fire rated bulkheads or decks for cable penetrations are to be examined and tested as
be construed as a substitute for flag Administration’s approval for the purpose of SOLAS (2014
Consolidated Edition).
f) The product or packing is to be marked with name of manufacturer, type designation and fire rating.
g) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
CTO Fire Test Reports: RS-19-B-036-E & RS-19-B-037-E.both dated 21 March 2019
SP Swedish National Testing & Research Institute - Fire Test Reports: P703775 dated 7 December 2007
, P601739 dated 28 June 2006, P601740 dated 28 June 2006
DNV Inspection Report Nos.: MLM 010235,dated 21 August 2001, MLM 020133 dated 27 January 2003,
, MLM 060561 dated 1 December 2006, MLM 010247 dated 21 August 2001 and SKM-04-4088.
Drawings:
11/17/2023 4:25:09 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 4
Drawing No. S1014894, H60 STEEL BULKHEAD, PIPES, Revision: A,
Drawing No. S1014895, H120 STEEL BULKHEAD, PIPES, Revision: A,
Drawing No. S1014896, H60 STEEL DECK, PIPES, Revision: A,
Drawing No. S1014897, H120 STEEL DECK,PIPES, Revision: A,
Drawing No. S1014898, H60/H120 STEEL DECK/BULKHEAD, CABLE
Drawing No. S1014899, H60/H120 STEEL BULKHEAD, GRP/GRE PIPES
This Product Design Assessment (PDA) Certificate remains valid until 16/Jun/2024 or until the Rules
2019 Marine Vessels Rules 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-6-2/9.7, 4-8-4/21.13, 4-8-4/29.15
2019 Facilities on Offshore Installations Rules 1-1-4/9.7, 1-1-A2, 1-1-A3, 3-8/9.13, 3-8/9.15
2019 Mobile Offshore Unit Rules 1-1-4/9.7, 1-1-A2, 1-1-A3, 4-2-1/11.15, 4-3-3/5.13.1, 5-1-1/3.5
IMO 2010 FTP Code (2012 Edition) , Annex 1, Part 3 with Norwegian Petroleum Directorate H Class
Temperature Curve
A8706-1 RDIMS#1961446.
Acts, Regulations and Provisions for the Petroleum Activities, Volume 2, Norwegian Petroleum
Directorate, Issue June 1, 1999- For H Class Temperature Curve
11/17/2023 4:25:09 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 4
Print Date and Time: 17-Nov-2023 4:25
11/17/2023 4:25:09 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 4
