19-1837304-PDA-DUP-optimized
Model(s): Roxtec R Series Frames
Product Design Assessment (PDA) 19-1837304-PDA-DUP 05-JUL-2023 17-JUN-2024
Multi and Single pipe and cable penetrations in Class H-60/-120 bulkheads and decks. Penetrations of
watertight and gastight steel bulkheads and decks up to the specified pressure.
“Roxtec pipe and cable sealing system with multidiameter technology” composed of steel sleeves
(welded or bolted) with R & RO type (EMC versions included) halogen free rubber frames in size 50-200,
and filled with Roxtec halogen free insert modules, mounted in steel decks or bulkheads.
H-60/-120 Decks for Steel Pipes and Cables
H-60/120 Bulkheads for Steel Pipes
H-60 / 120 Bulkheads for R50 with Cables
H-60 Bulkheads for R70- R200 with Cables
a) Maximum tested Marine cable diameter: 88 mm and maximum tested steel pipe outside diameter 51
mm
11/17/2023 4:28:36 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 4
Certificate Number: 19-1837304-PDA-DUP
b) For cables and pipes penetration on H60/ H120 bulkheads, fire is to be from insulated side only.
b) Maximum frame size tested : Size 200
c) Minimum frame size tested: Size 50
d) Not to be used in tank boundaries.
e) Tested with Marine Power/ Instrumentation/Control Cables.
f) Insulation material is to be H-60/-120 approved type and installed in accordance with the
manufacturer’s ABS approved installation drawings S1540305 Rev A , S1540306 Rev A, S1014912 Rev
A, S1014914 Rev A ( as applicable to the division) to the satisfaction of the Surveyor.
g) Unit Certification is not required for this product. If the manufacturer or purchaser request an ABS
b) Watertight or fire rated bulkheads or decks for cable penetrations are to be examined and tested as
be construed as a substitute for flag Administration’s approval for the purpose of SOLAS (Consolidated
Edition 2014).
SP Fire Test Report Numbers P601739, P601740 both dated 28 June 2006
CTO Fire Test Report Numbers RS-19-B-036-E & RS-19-B-037-E both dated 21 March 2019
SWRI Fire Test Report Number 01.24214.01.002 dated 14 February 2019
DNV Inspection Report Nos.: MLM 010238 (30 August 2001) , MLM 010247 ( dated 28 September 2001)
Insulation/Installation drawings No:
Drawing No. S1540305, Revision: A- Deck/ Bulkhead H-120, Cables
Drawing No. S1540306, Revision: A,- Deck/ Bulkhead H-60, Cables
Drawing No.S1014912, Revision: A- Deck/ Bulkhead H-60, Pipes
Drawing No. S1014914, Revision: A- Deck/ Bulkhead H-120, Pipes
This Product Design Assessment (PDA) Certificate remains valid until 17/Jun/2024 or until the Rules
11/17/2023 4:28:36 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 4
2019 ABS Marine Vessels Rules 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-6-2/9.7, 4-8-4/21.13, 4-8-4/29.15
2019 ABS Facilities on Offshore Installations Rules 1-1-4/9.7, 1-1-A2, 1-1-A3 and 3-8/9.13, 3-8/9.15
2019 ABS Mobile Offshore Unit Rules 1-1-4/9.7, 1-1-A2, 1-1-A3, 4-2-1/11.15, 4-3-3/5.13.1, 5-1-1/3.5
IMO 2010 FTP Code (2012 Edition) , Annex 1, Part 3 with Norwegian Petroleum Directorate H Class
Temperature Curve
Acts, Regulations and Provisions for the Petroleum Activities, Volume 2, Norwegian Petroleum
Directorate, Issue June 1, 1999- For H Class Temperature Curve
A8706-1 RDIMS#1961446.
Print Date and Time: 17-Nov-2023 4:28
11/17/2023 4:28:36 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 4
11/17/2023 4:28:36 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 4
