Model(s): Sleev-it marine penetration sealing systems
| Product Design Assessment (PDA) | 19-1914369-1-PDA | 25-AUG-2020 | 18-NOV-2024 |
| Manufacturing Assessment (MA) | 24-6227546 | 25-JAN-2024 | 08-JAN-2029 |
Roxtec Sleev-it Fire Penetration Seal and Roxtec Sleec-it Watertight Penetration Seal for plastic pipe
penetrations in A0, A15, A30 and A60 steel bulkheads and decks. Roxtec Sleev-it transition collar for
transitions between plastic- and steel pipe systems in A0, A15, A30 and A60 steel bulkheads and decks.
Roxtec Sleev-it marine penetration sealing system is divided into three different product groups :
Roxtec Sleev-it Fire Penetration Seal consist of an intumescent strip material inserted in an openable
stainless steel casing, equipped with an openable flange, intended for bolted or spot welded installation
onto steel divisions.
Roxtec Sleev-it Watertight penetration seal consist of an intumescent strip material inserted in a closed
stainless steel casing, equipped with a closed flange with an EDPM rubber grommet, intended for fully
welded installation onto steel divisions.
Roxtec Sleev-it Transition collar consist of an intumescent strip material inserted in an openable
stainless steel housing, intended for protections of transitions between plastic pipe and steel pipe
systems.
Fire Rating: A0, A15, A30 and A60 Bulkheads and Decks as per attachment for various sizes and pipe
materials.
| 02/13/2024 12:47:02 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 1 of 6 |
| Certificate Number: 19-1914369-1-PDA |
Fire penetration Seal: Tested for air tightness up to 30 mbar for pipes with outer diameter 16- 160 mm
diameter.
Watertight penetration seal: Watertightness rating 1 bar and air tightness rating 0.5 bar for pipes with
outer diameter 16- 110 mm.
Note penetrations in A-0, A-30 or A-15 bulkheads and decks must be insulated to A-60 standards since
that was the configuration when the penetrations were fire tested
a) Pipe materials and outside diameters specified in the attachment.
b) Not for use in tank boundaries.
c) The product or packing is to be marked with the name of the manufacturer and type designation
d) When requested to be used in watertight bulkheads on passenger ships and Special Purpose Ships
(SPS), the penetration system has to comply with the requirements given in SOLAS Ch.II-1 Reg. 13.2.1
(2014 issue). Penetrations passing through watertight bulkheads are subject for separate examination
and approval by flag Administration.
e) Each product is to be supplied with its manual for installation and maintenance.
f) Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
g) If penetration seals are to be used in A-0, A-15 or A-30 deck or bulkhead, insulation must be to A-60
standard to reflect the tested configuration.
a) All seal types should be installed in accordance with manufacturer’s ABS approved installation
drawings.
b) Insulation material is to be A-60 approved type and properly installed to the satisfaction of the
Surveyors.
c) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
Approval of the arrangements and materials based on:
Bodycote Warrington fire Test Reports:
164476B Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Ten Specimens of Pipe Penetrations, dated 23 July 2007, initial revision
170080B Fire Resistance Test generally in Accordance with IMO Resolution A.754(18) on an ‘A’ Class
Deck Incorporating Sixteen Specimens of Pipe Penetration Sealing Systems, dated 30 April 2008, initial
revision
175486A Fire Resistance Test generally in Accordance with IMO Resolution A.754(18) on an ‘A’ Class
Deck Incorporating Nine Specimens of Pipe Penetration Sealing Systems, dated 31 October 2008, initial
revision
177105A Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Eight Specimens of Pipe Penetrations, dated 06 January 2009, initial revision
| 02/13/2024 12:47:02 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 2 of 6 |
180251A Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Eleven Specimens of Pipe Penetrations, dated 26 May 2010, initial revision
BRE Test Reports:
223968 A Marine Fire Resistance Test on Ten Sleev-it Penetration Sealing Systems Installed in an A-60
steel deck, dated 05 September 2005
Supplementary Test Report 223969A dated 15 September 2005
Exova Warringtonfire Test Reports:
183387A Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Eight Specimens of Pipe Penetration Seals, dated 23 October 2009, initial revision
190890A Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Deck
Incorporating Seven Specimens of Pipe Penetration Seals, dated 23 October 2009, initial revision
303584A Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Eight Specimens of Pipe and Cable Penetration Seals, dated 07 April 2011, initial revision
307171A Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Nine Specimens of Pipe Penetration Seals, dated 17 June 2011, Issue 2
309638A Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Deck
Incorporating Sixteen Specimens of Pipe Penetration Sealing Systems, dated 20 September 2011, initial
revision
309855A Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Ten Specimens of Pipe Penetration Seals, dated 23 December 2011, initial revision
314669 Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Deck
Incorporating Twenty Seven Specimens of Pipe Penetration Sealing Systems, dated 26 April 2012, initial
revision
314670 Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Sixteen Specimens of Pipe Penetration Seals, dated 25 June 2012, initial revision
316943 Fire Resistance Test in Accordance with IMO Resolution A.754(18) on an ‘A’ Class Bulkhead
Incorporating Seventeen Specimens of Pipe Penetration Seals, dated 26 April 2012, initial revision
320402A Fire Resistance Test in Accordance with IMO Resolution MSC 307/88 Annex 1 Part 3 on an ‘A’
Class Deck Incorporating Seventeen Specimens of Pipe Penetration Sealing Systems, dated 29 October
324083 Fire Resistance Test in Accordance with IMO Resolution MSC.307(88), Annex I:Part 3 on an ‘A’
Class Bulkhead Incorporating Seventeen Specimens of Pipe Penetration Seals, dated 24 April 2013,
initial revision
325332 Fire Resistance Test in Accordance with IMO Resolution MSC 307/88 Annex 1 Part 3 on an ‘A’
Class Deck Incorporating Eighteen Specimens of Pipe Penetration Sealing Systems, dated 10 July
2013, initial revision
329449 Fire Resistance Test in Accordance with IMO Resolution MSC 307/88 Annex 1 Part 3 on an ‘A’
Class Deck Incorporating Twenty Four Specimens of Pipe Penetration Sealing Systems, dated 13
August 2013, initial revision
330891 Fire Resistance Test in Accordance with IMO Resolution MSC 307/88 Annex 1 Part 3 on an ‘A’
Class Deck Incorporating Fifteen Specimens of Pipe Penetration Sealing Systems, dated 5 September
334429 Fire Resistance Test in Accordance with IMO Resolution MSC 307/88 Annex 1 Part 3 on an ‘A’
Class Deck Incorporating Thirteen Specimens of Pipe Penetration Sealing Systems, dated 17 December
| 02/13/2024 12:47:02 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 3 of 6 |
337717 Fire Resistance Test in Accordance with IMO Resolution MSC.307(88), Annex I:Part 3 on an ‘A’
Class Bulkhead Incorporating Eighteen Specimens of Pipe Penetration Seals, dated 13 May 2014, initial
revision
Gerbam Test reports:
878/07/A/NP/R 102 Fire Resistance of Type A Penetrations in a Type A60 deck in line with the Code for
FTP Part 3 (IMO Resolution A754(18)), dated 28 March 2007, initial issue
Danish Institute of Fire and Security Technology (DBI) Test Reports :
PGA11611A Fire Resistance of Type A Penetrations in a Type A60 deck in line with the Code for FTP
Part 3 (IMO Resolution A754(18)),dated 11 January 2020, Revision 0
PGA11388A Fire Resistance of Type A Penetrations in a Type A0 deck in line with the Code for FTP
Part 3 (IMO Resolution A754(18)),dated 14 August 2019, Revision 0
Fire test report Centrum Techniki Okretojew S.A. (CTO SA)
No.RS-19/B-424/E Test on fire resistance of cable transits and pipe penetrations installed in A60 class
steel bulkhead made according to technical documentation No. TST-001264, dated 27 November 2019
Tightness Test Reports:
DNV LDN-08-045 with Setup drawing Annex-1 & 2, Lloyds SOU 090158_1 with Setup drawing
S1041742 rev.A, dated 31 January 2005
DNV Survey report LDN-8-045 Sleev-It Marine Fire Collar, DWg. No. SLV 174 Rev. a dated 31 Jan 2008
Lloyd’s Register Report SOU 0901586/1 Sleev-it Fire Systems Limited Fire Collars for Plastics Pipe
Penetrations dated 08 January 2010
Roxtec Drawings:
ASS2012001101 Sleev-it Transition Collar Installation Dwg
ASS2012001201 Sleev-it Watertight Penetration Seal
ASS2012001301 Sleev-it Fire Penetration Seal
S1026329 Fire Penetration Seal Assembly, Rev G dated 2013-10-11
S1026334 Transition Collar Assembly, Rev B dated 2013-01-07
S1026339 Watertight Penetration Seal Assembly, Rev. D, dated 2013-01-10
S1039663 FC/WT Installation A15-A60 St Blkhd/Deck, Rev. B dated 2014-06-05
S1039664 FC/WT Installation A0 St Blkhd/Deck, rev A, dated 2014-06-10
S1039696 TR Collar Installation A15-A60 St Blkhd, rev A dated 2014-06-09
S1039702 TR Collar Installation A15-60 St Deck , rev. A dated 2014-06-10
S1555844 FC/WT W Preinsulated pipes A60 St Blkhd/Deck, Rev A, dated 2020-06-01
S1555846 FC/WT W Preinsulated pipes, A0 St Blkhd/Deck, Rev A, dated 2020-06-01
| 02/13/2024 12:47:02 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 4 of 6 |
S1555847 FC/WT W Plastic PVC PIPES, A0 St Deck, Rev A, dated 2020-06-01
This Product Design Assessment (PDA) Certificate remains valid until 18/Nov/2024 or until the Rules
ABS Rules for Conditions of Classification (2020) 1-1-4/7.7, 1-1-A3 and A4, which covers the following :
2020 Rules for Building and Classing Marine Vessels : 4-6-3/7.11
SOLAS Ch. II-2, Reg. 9.3.1 (2014 Consolidated Edition), as amended
IMO Resolution A.754 (18)
Print Date and Time: 13-Feb-2024 12:47
| 02/13/2024 12:47:02 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 5 of 6 |
| 02/13/2024 12:47:02 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 6 of 6 |
