19-LD1875603-PDA-optimized
Model(s): Roxtec S Series Frames in Steel Divisions
Product Design Assessment (PDA) 19-LD1875603-PDA 16-AUG-2019 15-AUG-2024
Multi and single pipe/cable (armoured or non-armoured) penetrations in Class H-0/ H-60/ 120 bulkheads
and decks as per corresponding rating. Penetrations of watertight and gastight steel bulkheads and
decks up to the specified pressure.
“Roxtec pipe and cable sealing system with multidiameter technology” consisting of Roxtec S series
frames (S, SO, SF, SFO, SR, SK, SKR, SRC r20&r40 and BTB) in sizes 1-8 and combinations thereof,
bolted or welded on to the steel sections, filled with Roxtec (standard, Ex or EMC of type PE, ES and
BG, BGB) halogen free insert modules (which consist of two halves of EPDM based rubber, with
removable layers to handle cables of different sizes), and assembled with Roxtec Wedge Kit or Roxtec
Wedge Kit ( Standard, Ex or EMC).
Fire resistance: Cables: H-60 for Bulkheads and H0/ H60 /H120 for Decks
Pipes: H-60/ H120 for Bulkheads and Decks
a) Maximum marine cable outside diameter up to 96 mm, maximum CLX cables outside diameter up to
103 mm & maximum pipe diameter up to 51 mm.
b) For H-120 Decks with BG/BGM Module, maximum marine cable outside diameter up to 82 mm,
02/13/2024 12:47:41 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 4
Certificate Number: 19-LD1875603-PDA
maximum CLX cables outside diameter up to 98 mm
c) Maximum combination frame size tested for cables penetrations: 8+8x3 for Bulkheads and 8+8x2 for
Decks
d) Maximum combination frame size for pipes: 8x2 for Bulkheads and Decks.
e) EMC Modules types BG and BGB approved to use only on steel deck penetrations.
f) Not for use in tank boundaries
g) Chartek 7 reinforced epoxy intumescent fireproofing coating is to be applied in accordance with
manufacturer’s instructions to protect steelwork (thickness of approximately 12 mm), and armoured
cables painted to a length of 250 mm on the fire exposed side of the bulkhead. The use of btb frames is
acceptable without any use of coating on the transit face or cables as per drawing S1023004 rev.C.
h) Unit Certification is not required for this product. If the manufacturer or purchasers request an ABS
a) All seal types should be installed in accordance with manufacturer’s ABS approved installation
drawings.
b) Insulation material is to be H-60/ 120 approved type and properly installed to the satisfaction of the
Surveyors. (Insulation drawing No.: S1011758 Rev.B, S1544621 Rev.A and S1023004 Rev.C for CLX
Cable).
c) Refer to ABS approved drawing numbers S1018761 and S1018762 for pipes.
d) Watertight or fire rated bulkheads or decks for cable penetrations are to be examined and tested as
e) When requested to be used in watertight bulkheads on passenger ships or special purpose ships, the
be construed as a substitute for flag Administration’s approval for the purpose of SOLAS 1974
f) The product or packing is to be marked with name of manufacturer, type designation and fire rating.
g) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
CTO Fire Test Report Number RS-19/B-036/E and RS-19/B-037/E both dated 21 March 2019
SP Fire Test Report Numbers 4P02192 dated 26 May 2014, 6P02536 dated 08 June 2016, PX07235
dated 15 December 2010, P601740 dated 28 June 2006, P703775 dated 7 December 2007, 3P04210
dated 24 September 2013.
DNV Watertight and Gastight Test Reports MLM 020106, MLM 020133 both dated 26 February 2006,
MLM 020408 dated 28 September 2001
Insulation/Installation drawings Nos:
Drawing No. S1011758 Rev. B, S- Frames With Cables H60/H120 Steel Division
Drawing No: S1023004 Rev.C, S- Frame Including MC/CLX Cable H60/H120 Steel Division.
02/13/2024 12:47:41 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 4
Drawing Number S1544621 Rev.A, , S-Frames With Cables H-0 Steel Deck
Drawing Number S1018761, S-Frames With Pipes H-60 Steel Division
Drawing Number S1018762, S-Frames With Pipes H-120 Steel Division
This Product Design Assessment (PDA) Certificate 19-LD1875603-PDA, dated 16/Aug/2019 remains
valid until 15/Aug/2024 or until the Rules or specifications used in the assessment are revised
(whichever occurs first).
This PDA is intended for a product to be installed on an ABS classed vessel, MODU or facility which is in
existence or under contract for construction on the date of the ABS Rules or specifications used to
evaluate the Product.
Use of the Product on an ABS classed vessel, MODU or facility which is contracted after the validity date
of the ABS Rules and specifications used to evaluate the Product, will require re-evaluation of the PDA.
Use of the Product for non ABS classed vessels, MODUs or facilities is to be to an agreement between
the manufacturer and intended client.
2019 ABS Marine Vessels Rules 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-6-2/9.7, 4-8-4/21.13.1
2019 ABS Mobile Offshore Units Rules 1-1-4/9.7, 1-1-A2, 1-1-A3, 4-2-1/11.15, 4-3-3/5.13
2019 ABS Rules for Building and Classing Facilities on Offshore Installations 1-1-4/9.7, 1-1-A2, 1-1-A3,
3-8/9.13.
IMO FTP Code 2010 ( 2012 Edition), Annex 1, Part 3 with Norwegian Petroleum Directorate H Class
Temperature Curve
Acts, Regulations and Provisions for the Petroleum Activities, Volume 2, Norwegian Petroleum
Directorate, Issue June 1, 1999- For H Class Temperature Curve
This PDA conforms to Transport Canada requirements as per Transport Canada Policy Letter A8706-1
RDIMS#1961446 dated 15 November 2006
02/13/2024 12:47:41 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 4
Print Date and Time: 13-Feb-2024 12:47
02/13/2024 12:47:41 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 4
