6.8.4
swidetelxstwo o tipowom odobrenii
sudowoj protiwopovarnoj konstrukcii
FOR FIRE-PROOF DIVISION
nAIMENOWANIE I TIP OGNESTOJKOSTI Система кабельных и трубных проходов в конструкциях класса H
| Designation and class of fire resistance | Cable and Pipe Penetrations system through H Class Divisions |
| Roxtec Cable and Pipe Sealing System with Multidiameter TM | |
| S - series, S EMC - series, S BG/BGB - series | |
| rAZRABOT^IK (IZGOTOWITELX) | Roxtec International AB |
| Designer (manufacturer) | |
| VAT No. SE556370806301 |
| aDRES | Box 540, SE-371 23 Karlskrona, Sweden |
| Address Места производства: |
1. Box 540, SE-371 23 Karlskrona, Sweden.
- Россия, 142802 Московская обл., г. Ступино, ул. Транспортная, 22/2.
Places of manufacturing:
- Russia, 142802 Moskovskaya obl., Stupino, Transportnaya str., 22/2
nA OSNOWANII OSWIDETELXSTWOWANIQ I PROWEDENNYH ISPYTANIJ UDOSTOWERQETSQ, ^TO WY[EUPOMQNUTAQ(YE)
KONSTRUKCIQ(I) UDOWLETWORQET(@T) TREBOWANIQM rOSSIJSKOGO MORSKOGO REGISTRA SUDOHODSTWA.
This is to certify that on the basis of the survey and tests carried out the above mentioned division(s) complies(ly) with
the requirements of Russian Maritime Register of Shipping.
п.1.2.2 части VI, п.п.16.8.6 и 16.8.7 части X Правил классификации, постройки и оборудования плавучих буровых установок и морских стационарных
платформ, изд.2018 года.
item 1.2.2 of Part VI, items 16.8.6 and 16.8.7 of Part X of Rules for the Classification, Construction and Equipment of Mobile Offshore Drilling Units and Fixed
Offshore Platforms, ed.2018.
nASTOQ]EE sWIDETELXSTWO O TIPOWOM ODOBRENII DEJSTWITELXNO DO
This Type Approval Certificate is valid until
30.12.2025
nASTOQ]EE sWIDETELXSTWO O TIPOWOM ODOBRENII TERQET SILU W SLU^AQH, USTANOWLENNYH W pRAWILAH
TEHNI^ESKOGO NABL@DENIQ ZA POSTROJKOJ SUDOW I IZGOTOWLENIEM MATERIALOW I IZDELIJ DLQ SUDOW.
This Type Approval Certificate becomes invalid in cases stipulated in Rules for the Technical Supervision during
Construction of Ships and Manufacture of Shipboard Materials and Products.
| dATA WYDA^I | " | 20.10096.262 |
| Date of issue | 30.12.2020 | |
| kOD NOMENKLATURY | 06010005MK | |
| Code of nomenclature |
| rOSSIJSKIJ MORSKOJ REGISTR SUDOHODSTWA | Терехов В.Ю. / V. Terekhov |
| Russian Maritime Register of Shipping | |
| m.p. ( signature) | ( FAMILIQ, |
| PODPISX | INICIALY |
| name | |
| L.S. |
kRATKOE OPISANIE KONSTRUKCII
Brief description of the division
Система кабельных и трубных проходов через палубы и переборки является огнестойкой, водонепроницаемой и газонепроницаемой конструкцией
класса H. Система установливается в стальных рамках с различными типами покрытий (S, SO, SF, SFO, SK, SR, SRCr20/40 или SBTB) и размерами No. 1-8 и
их комбинаций. Также могут устанавливаться кабели с металлической броней диаметром до 103 мм. Рамки привариваются или крепятся болтами к
корпусной конструкции, заполняются Roxtec (стандартными или ЕМС) безгалогенными вставками типа RM Modules и уплотняемые сальниками
Roxtec Wedgekit (стандартными или EMC).
Одобрена для стальных трубопроводов диаметром от 14.0 мм до 51.0 мм.
Одобрена для палубных конструкций класса H-60 и H-120 и для переборок H-0 – H-120.
Установку изоляции производить в соответствии с чертежами S1006279, S1008896, S1009999, S1019867, Rev. B, S1505299, Rev. A, S1505300, Rev. A.
Cable and Pipe Penetrations system through decks and bulkheads is a fire-resistant, gastight and watertight construction of
H Class Divisions. The system is fitted in steel frames with different types of coating (S, SO, SF, SFO, SK, SR, SRCr20/40 or SBTB)
and sizes Nos. 1 - 8 and theirs combinations. Also metal armored cables with OD up to 103 mm can be installed. Frames are welded or bolted to a hull
constructions, filled with Roxtec (standard or EMC) halogen free RM Modules and sealed with Roxtec Wedgekit (standard or EMC).
Approved for steel pipes in diameter from 14.0 mm to 51.0 mm.
Approved for decks constructions of H-60 and H-120 Class and for bulkheads of H-0 – H-120 Class.
Insulation installation in accordance with drawings S1006279, S1008896, S1009999, S1019867, Rev. B, S1505299, Rev. A, S1505300, Rev. A.
tEHNI^ESKAQ DOKUMENTACIQ I DATA EE ODOBRENIQ rOSSIJSKIM MORSKIM REGISTROM SUDOHODSTWA
Technical documentation and the date of its approval by Russian Maritime Register of Shipping
Чертежи и протоколы испытаний одобрены письмом № / Drawings and Test Reports were
approved by Letter No. 262-381-243-337074 от / dd 30.12.2020.
oBRAZEC IZDELIQ IZGOTOWLEN POD TEHNI^ESKIM NABL@DENIEM rOSSIJSKOGO MORSKOGO REGISTRA SUDOHODSTWA.
Product’s specimen has been manufactured under the technical supervision of Russian Maritime Register of Shipping.
| aKT(Y) (", DATA) | 20.30126.262 от / dd 30.12.2020 |
| Report(s) (No., date) | 20.04066.120 от / dd 24.12.2020 |
iSPYTANIQ NA OGNESTOJKOSTX PROWEDENY (NAZWANIE ORGANIZACII)
Fire tests carried out by (name of organization)
SP Technical Research Institute of Sweden, Boras, Sweden
Danish Institute of Fire and Security Technology, Hvidovre, Denmark
в соответствии с частью 3 Приложения 1 Кодекса ПИО (Резолюция ИМО А.754(18)) и тестовой углеводородной температурной
кривой согласно стандарта EN 1363-2.
in accordance with Part 3 of the Annex I of the FTP Code (IMO Resolution А.754(18)) and test hydrocarbon temperature
curve according to Standard EN 1363-2.
pROTOKOL(Y) ISPYTANIJ (", DATA) P703775 от / dd 07.12.2007, P400834 от / dd 31.03.2004, 3P04210
| Test report(s) (No., date) | от / dd 24.09.2013, P601740 от / dd 28.06.2006, PG11199 serial |
| No.9138 от / dd 04.07.2003. |
oBLASTX PRIMENENIQ I OGRANI^ENIQ
Application and limitations
- Для использования в конструктивной противопожарной защите плавучих буровых установок и морских
стационарных платформ. / For use in structural fire protection of Mobile Offshore Drilling Units and Fixed
Offshore Platforms.
- Палуба или переборка в районе проходов должны быть изолированы согласно классу конструкции в
соответствии с одобренными чертежами. / Deck or Bulkhead in the area of penetrations to be insulated
according to Class Division in accordance with approved drawings.
wID DOKUMENTA, WYDAWAEMOGO NA IZDELIE
| Type of document issued for product | Изделие должно поставляться с копией настоящего Свидетельства |
| о типовом одобрении. | |
| The product shall be delivered with a copy of this Type Approval Certificate. |
| 01/2010 | 20.10096.262 |
