Product: Watertight and Fire Resistant Penetration Device
Model(s): Roxtec S Series Frames in aluminium divisions
| Product Design Assessment (PDA) | 20-1941096-PDA-DUP | 05-JUL-2023 | 26-JAN-2025 |
| Manufacturing Assessment (MA) | 23-6047656 | 28-SEP-2023 | 27-SEP-2028 |
Multi and single cable and pipe penetrations in Class A0, A15, A30 and A60 aluminium bulkheads and
decks. Penetrations of watertight and gastight aluminium bulkheads and decks up to the specified
pressure.
“Roxtec cable and pipe sealing system with multidiameter technology” consisting of Roxtec S series
frames (S, SO, SF, SFO, SR, SK, SKR, SRC r20&r40 and BTB) in sizes 1-8 and in combinations
thereof, bolted or welded on to the aluminium sections, filled with Roxtec (standard, Ex or EMC) halogen
free insert modules.
Assembled with Roxtec Wedge Kit ( Standard, Ex or EMC)
A-0, A-15, A-30 and A-60 Bulkheads and Decks
a) Maximum cable outside diameter up to 81 mm for bulkheads and decks.
b) Maximum steel pipe outside diameter up to 54 mm for bulkheads and decks.
c) Maximum copper pipe outside diameter up to 57 mm for bulkheads and decks.
| 11/17/2023 4:30:23 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 1 of 4 |
| Certificate Number: 20-1941096-PDA-DUP |
d) Maximum tested frame size:
1) Single - 8x1 ( One frame of size 8)
- Multiple Frames -For decks and bulkheads up to A60 rating, two frames of size 8 arranged vertically
and three
arranged horizontally, designated S 8+8x3.
e) Minimum tested frame size 1x1 ( Size 1 frame)
f) For fire class A-0, A-15 and A-30, the sleeve is to be insulated as for class A-60, and in addition the
division shall be insulated at least 200 mm around the penetration.
g) Not for use in tank boundaries.
h) Unit Certification is not required for this product. If the manufacturer or purchaser request an ABS
a) All seal types should be installed with the manufacturer’s instructions in accordance with approved
rawings.
b) Refer to ABS approved Drawings S1019806 Rev.- & S1019808 Rev.-
c) Watertight or fire rated bulkheads or decks for pipe and cable penetrations are to be examined and
tested as per ABS Marine Vessels Rules 3-7-1/Table1 and 4-8-4/29.15
penetration system has to comply with the requirements given in SOLAS Ch. 11-1 Reg. 13.2.3 (2014
Consolidated Edition). This approval of penetrations passing through watertight bulkhead is not to be
construed as a substitute for flag Administration’s approval for the purpose of SOLAS (2014 consolidated
edition).
f) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
Test Report number P603001 dated 23 Jan 2007, A-60 Bulkhead / SP Technical Research Institute of
Sweden, Boras
Test Report number PG11898 dated 10 Sep 2008, A-60 Bulkhead / Danish Institute of Fire and Security
Technology, Hvidovre
Test Report number PG11955 dated 11 Sep 2008, A-60 Deck / Danish Institute of Fire and Security
Test Report number RS-19-B-224-E, dated 01 August 2019, A-60 deck / CTO, Poland
Test Report number RS-17-B-210-E, dated 02 June 2017, A-60 deck / CTO, Poland.
Test Report number RS-18-B-179-E, dated 25 June 2018, A-60 deck / CTO, Poland.
Test Report number RS-18-B-180-E, dated 25 June 2018, A-60 Bulkhead/ CTO, Poland.
Test Report number RS-19-B-020-E, dated 27 May 2019, A-60 Bulkhead / CTO, Poland.
DNV Third Party Inspection Report number MLM020106 dated 19 Dec 2001
| 11/17/2023 4:30:23 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 2 of 4 |
DNV Third Party Inspection Report number MLM020133 dated 26 Feb 2002
RM Module and Wedge Kit Drawings S1005711 Rev D, S1016608 Rev. B, S1011086 Rev A, S1000716
Rev D, S1016671 Rev: -
Roxtec sealing system, Roxtec product sheet
Roxtec Ex sealing system, Roxtec Product sheet
Drawings
Drawing No S1019806 Rev. - , S Frames W Cables A-Class Alu Deck/Blkhd
Drawing No S1019808 Rev. -, S-Frames W ST/CU Pipes A-Class Alu Deck/Blkhd
This Product Design Assessment (PDA) Certificate remains valid until 26/Jan/2025 or until the Rules
ABS Marine Vessels Rules 2020 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-6-2/9.7, 4-8-4/21.13.1
ABS Mobile Offshore Units Rules 2020 1-1-4/9.7, 1-1-A2, 1-1-A3, 4-2-1/11.15, 4-3-3/5.13.1
SOLAS (consolidated edition 2014) Chapter II-2 Reg. 9.3.1
IMO FTP Code 2010, Annex I : Part 3
This PDA conforms to Transport Canada requirements as per Transport Canada Policy Letter A8706-1
RDIMS#1961446 dated 15 November 2006
| 11/17/2023 4:30:23 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 3 of 4 |
Print Date and Time: 17-Nov-2023 4:30
| 11/17/2023 4:30:23 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 4 of 4 |
