Model(s): Roxtec RS/RS OMD Seals in aluminium divisions
| Product Design Assessment (PDA) | 20-1958482-PDA-DUP | 05-JUL-2023 | 25-MAR-2025 |
| Manufacturing Assessment (MA) | 23-6047656 | 28-SEP-2023 | 27-SEP-2028 |
Single pipe penetrations in Class A0, A15, A30 and A60 bulkheads and decks. Penetrations of watertight
and gastight aluminium bulkheads and decks up to the specified pressure.
“Roxtec pipe sealing system with multi-diameter technology” composed of aluminium sleeves (welded or
bolted) or sleeves of SLX-RS type with RS or RS OMD type (EMC versions included) halogen free
rubber sealing outside diameter size 23 mm to 150 mm, mounted in aluminium decks or bulkheads. RSX
kits consist of SLXRS type sleeves including an RS seal.
A0, A15, A30 and A60 Aluminium Bulkheads and Decks for single pipe penertrations
A0, A15, A30 and A60 Aluminium Bulkheads for single bundle pipe penetrations
a) Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
b) Copper pipes up to 108 mm, Steel pipes and Titanium pipes up to 119 mm.
| 11/17/2023 4:27:37 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 1 of 4 |
| Certificate Number: 20-1958482-PDA-DUP |
c) Bundle pipes/ multi core tubes (in stainless steel and copper versions) up to 50 mm outside diameter,
sizes R43 - R100 only
d) Glass fiber reinforced pipe (GRP) / Fiberglass Composite Pipe (FGCP) outside diameter up to 90 mm
for decks and 89 mm for bulkheads.
e) Maximum fitting outside diameter range 150 mm to 168 mm
f) Not for use in tank boundaries.
g) Watertight bulkheads or decks are to be examined and tested as per ABS Marine Vessel Rules
3-7-1/Table 1 .
h) When requested to be used in watertight bulkheads on passenger ships or special purpose ships, the
penetration system has to comply with the requirements given in SOLAS Ch. II -1 Reg. 13.2.3. This
approval of penetrations passing through watertight bulkhead is not to be construed as a substitute for
flag Administration’s approval for the purpose of SOLAS (Consolidated Edition 2014) as amended.
a) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
b) All seal types should be installed with the manufacturer’s instructions in accordance with the attached
drawings.
c) Insulation material is to be A-60 approved type and installed in accordance with the attached drawings
to the satisfaction of the Surveyor.
Report No. 9P02428, Comparison of titanium & steel pipes, RISE Research Institutes of Sweden AB
Safety - Fire Research Resistance,13 September 2019 Revision: 1, Pages: 3
Report No. MLM010235, Tested for Watertightness and gastightness, DNV, dated 21 August 2001
Revision: -, Pages: 7
Report No. PG11955, Test report for examination of the fire-resistance of an aluminium deck containing
pipe penetrations, DBI Danish Institute of Fire and Security Technology, dated 17 April 2009, Revision: -,
Pages: 130
Report No. PG11898, Test report for examination of the fire-resistance of an aluminium bulkhead
containing pipe penetrations and cable transits, DBI Danish Institute of Fire and Security Technology,
dated 17 April 2009 Revision: -, Pages: 103
Report No. P603001 - Jan 23 2007, Test report for the fire test of cable transits and pipe penetrations
mounted in a bulkhead of aluminium, SP Technical Research Institute of Sweeden, dated 23 January
2007, Revision: -, Pages: 101
Report No. RS-17_B-555_E, Test on fire resistance of pipe penetrations and cable transits installed in
A60 class aluminium bulkhead made according to technical documentation No. TST 000670, CENTRUM
TECHNIKI OKRETOWEJ S.A, Dated 15 January 2018, Revision: 1, Pages: 50
Drawing No. RS-18-B-179-E, Test on fire resistance of pipe penetrations and cable transits installed in
A60 class aluminium bulkhead made according to technical documentation No. TST 000739, CENTRUM
TECHNIKI OKRETOWEJ S.A, Dated 25 June 2018, Revision: 1, Pages: 70
Drawing No. RS_19_B_020_E, Test on fire resistance of pipe penetrations and cable transits installed in
A60 class aluminium bulkhead made according to technical documentation No. TST 000948, CENTRUM
TECHNIKI OKRETOWEJ S.A, Dated 27 May 2018, Revision: 1, Pages: 74
Drawing No. S1552419, Certificate drawing, Revision: A, Pages: 1
Drawing No. S1019824, RS/RS OMD Cu Pipe, A-Class Alu Deck-Bulkhead, Revision: -, Pages: 1
| 11/17/2023 4:27:37 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 2 of 4 |
Drawing No. S1019832, RS/RS OMD Fiberglass Composite Pipe, A-Class Alu Deck-Bulkhead, Revision:
-, Pages: 1
Drawing No. S1040796, RS/RS OMD Bundle Pipe, A-Class Alu Deck-Bulkhead, Revision: B, Pages: 1
This Product Design Assessment (PDA) Certificate remains valid until 25/Mar/2025 or until the Rules
2020 Rules for Conditions of Classification, 1-1-4/7.7, 1-1-A3, 1-1-A4, which covers the following:
ABS Rules for Building and Classing Marine Vessels 2020: 4-6-2/9.7, 4-6-3/7.11,
ABS Rules for Building and Classing Steel Barges 2020: 4-1-2/5, 4-1-2/7
ABS Rules for Building and Classing High Speed Craft 2020: 4-4-1/9.9, 4-4-1/9.11, 4-4-1/9.13
ABS Rules for Building and Classing Steel Vessels for Service on Rivers and Intracoastal Waterways
2020: 4-3-1/7.9
2020 Rules for Conditions of Classification - Offshore Units and Structures 1-1-4/9.7, 1-1-A2, 1-1-A3,
which cover the following:
ABS Rules for Building and Classing Mobile Offshore Units 2020: 4-2-1/11.15
ABS Rules for Building and Classing Facilities on Offshore Installations 2020: 3-8/9.13, 4-8/9.13,
SOLAS Ch. II-2, Reg. 9.3.1 (2014 consolidated edition)
IMO Resolution A.754 (18) adopted on 4 November 1993 as amended by MSC.61(67) adopted on 5
December 1996
2010 FTP Code, Annex1, part 3 (IMO Resolution MSC.307 (88) adopted on 3 December 2010)
A8706-1 RDIMS #1961446
| 11/17/2023 4:27:37 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 3 of 4 |
Print Date and Time: 17-Nov-2023 4:27
| 11/17/2023 4:27:37 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 4 of 4 |
