Model(s): Roxtec R & RO Series Frames in steel divisions
| Product Design Assessment (PDA) | 20-1960435-PDA-DUP | 05-JUL-2023 | 25-MAR-2025 |
| Manufacturing Assessment (MA) | 23-6047656 | 28-SEP-2023 | 27-SEP-2028 |
Multi and single cable penetrations in Class A0, A15, A30 and A60 bulkheads and decks for ship or
offshore applications . Penetrations of watertight and gastight bulkheads and decks up to the specified
pressure.
Roxtec sealing system with multi diameter technology: composed of a steel sleeve welded, bolted (incl.
SL A), or attached through expansion (SLX sleeve, R X kit) to a steel section. Sleeve is fitted with a
Roxtec R or RO frame (standard, Ex/ATEX or EMC) in sizes 50-200 (50-100 with SL A Sleeve) . The R
or RO frame is filled with Roxtec (standard, Ex/ATEX or EMC) halogen free RM modules.
Fire Rating : A0, A15, A30 and A60 for Bulkheads and Decks
Watertight test pressure
R series Seals, Welded SL, SLF Sleeve, SLX Sleeve: 6 bar
Bolted SLF Sleeve: 5 bar
SL A Sleeve: 4 bar
Gastight test pressure
R series Seals, Welded SL, SLF Sleeve, SLX Sleeve: 3 bar
| 11/17/2023 4:29:21 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 1 of 5 |
| Certificate Number: 20-1960435-PDA-DUP |
Bolted SLF Sleeve: 2.5 bar
SL A Sleeve: 1.5 bar
a) Unit Certification is not required for this product. If the manufacturer or purchaser request an ABS
b) Maximum cable diameter: 60 mm ( with out SL A Sleeve) and 50 mm ( with SL A Sleeve)
c) Maximum frame size tested : Size 200 ( Size 100 for SL A Sleeve)
d) Minimum frame size tested: Size 50
e) SL A sleeve is fitted unsymmetrically into the bulkhead (Unexposed side) and deck (exposed or
unexposed side).
f) Not to be used in tank boundaries.
g) Insulation material is to be A-60 approved type and installed in accordance with the manufacturer’s
ABS approved installation drawings to the satisfaction of the Surveyor.
h) For fire class A-15 and A-30, sleeves are to be insulated as for class A-60 and in addition the division
is to be insulated at least 200 mm around the penetration.
a) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
b) All seal type should be installed in accordance with the manufacturers instructions in accordance with
c) Watertight or fire rated bulkheads or decks for cable penetrations are to be examined and tested as
per ABS Marine Vessel Rules 3-7-1/Table1 and 4-8-4/29.15.
be construed as a substitute for flag Administration’s approval for the purpose of SOLAS.
Report No. DNV40007647-1-2020-03-13, DNV Third Party Inspection Report, Dated 13 December 2011
Revision: -, Pages: 1
Report No. MLM010238-2020-03-13, DNV Third Party Inspection Report, Dated 30 August 2001,
Report No. MLM020401 -2020-03-13, DNV Third Party Inspection Report, Dated 25 March 2002,
Report No. MLM030473-1-2020-03-13, DNV Third Party Inspection Report, Dated 27 January 2003,
Revision: , Pages: 1Report No. N141EX8Z-A0420629-revision2 -2020-03-13, DNV Third Party
Inspection Report, Dated 10 August 2017, Revision: -, Pages: 1
Report No. 6P02249, IMO test of pipe penetration seals in A60 steel deck, SP Technical Research
Institute of Sweden, Dated 17 August 2016 Revision: 0, Pages: 151
Report No. P600993, Fire test of cable transits in a steel bulkhead, SP Technical Research Institute of
| 11/17/2023 4:29:21 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 2 of 5 |
Sweden, Dated 12 April 2006, Revision: -, Pages: 57
Report No. 4P06068, IMO test of penetration seals in A60 Steel Bulkhead, SP Technical Research
Institute of Sweden, Dated 17 January 2015, Revision: -, Pages: 96
Report No. PGA10800A, Examination of the fire resistance performance of cable transits and pipe
penetrations mounted in a class A60 steel deck, Danish Institute of Fire and Security Technology, dated
26 May 2016, Revision: -, Pages: 132
Report No. P701755, Fire test of pipe penetrations and cable transits in a steel deck, SP Technical
Research Institute of Sweden, Dated 12 June 2007, Revision: -, Pages: 132
Report No. 7P02167, IMO test of pipe penetration seals in A60 steel deck, RISE Research Institutes of
Sweden AB, Dated 07 August 2017, Revision: -, Pages: 73
Report No. PX05454 rev1, Fire test of cable transits and pipe penetrations, SP Technical Research
Institute of Sweden, Dated 08 September 2011, Revision: 1, Pages: 76
Report No. 8P07094 (rev 1), IMO test of pipe penetration seals in A60 steel bulkhead, RISE Research
Institutes of Sweden AB, Dated 16 January 2020, Revision: 1, Pages: 1
Report No. PGA10025, Examination of the fire-resistance of a steel deck containing pipe penetrations
and cable transits, Danish Institute of Fire and Security Technology, Dated 22 December 2011, Revision:
-, Pages: 126
Report No. PGA10724A, Examination of the fire resistance performance of cable transits and pipe
penetrations mounted in a class A0 steel bulkhead, Danish Institute of Fire and Security Technology,
Dated 15 December 2015, Revision: -, Pages: 63
Report No. PGA10871A, standard fire test complying with the International Code for Application of Fire
Test Procedures, 2010 Resolution MSC.307(88), 2010 FTP Code, Annex 1 Part 3, Test for“A”, “B” and
“F” Class Divisions., Dated 16 January 2018, Revision: 1, Pages: 125
Report No. RS-18/B-484/E, Test on fire resistance of pipe penetrations and cable transits installed in
A60 class steel deck made according to technical documentation No. TST-000939, CENTRUM
TECHNIKI OKRETOWEJ S.A., Dated 10 December 2018, Revision: -, Pages: 76
Report No. RS-18/B-485/E, Test on fire resistance of pipe penetrations and cable transits installed in
A60 class steel deck made according to technical documentation No. TST-000932, CENTRUM
TECHNIKI OKRETOWEJ S.A., Dated 10 December 2018, Revision: -, Pages: 66
Report No. RS-19/B-255/E, Test on fire resistance of pipe penetrations and cable transits installed in
A60 class steel deck made according to technical documentation No. TST-001117, CENTRUM
TECHNIKI OKRETOWEJ S.A., Dated 20 August 2019, Revision: -, Pages: 42
Drawing No. S1552538, Certificate Drawing, Revision: A, Pages: 1
Drawing No. S1552540, Certificate Drawing, Revision: A, Pages: 1
Drawing No. S1509319 rev C, Revision: C, Pages: 1
Drawing No. S1531345 rev B, Revision: B, Pages: 1
Drawing No. S1531344 rev B, Revision: B, Pages: 1
This Product Design Assessment (PDA) Certificate remains valid until 25/Mar/2025 or until the Rules
| 11/17/2023 4:29:21 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 3 of 5 |
2020 Rules for Conditions of Classification, 1-1-4/7.7, 1-1-A3, 1-1-A4, which covers
the following:
ABS Rules for Building and Classing Marine Vessels 2020: 4-8-4/21.13, 4-8-4/29.15,
ABS Rules for Building and Classing High Speed Craft 2020: 4-6-3/5.13
ABS Rules for Building and Classing Steel Vessels for Service on Rivers and Intracoastal Waterways
2020: 4-5-3/5.13
2020 Rules for Conditions of Classification - Offshore Units and Structures 1-1-4/9.7, 1-1-A2, 1-1-A3,
which cover
the following:
ABS Rules for Building and Classing Mobile Offshore Units 2020: 4-3-3/5.13
ABS Rules for Building and Classing Facilities on Offshore Installations 2020: 3-8/9.13, 4-8/9.13
SOLAS Ch. II-2, Reg. 9.3.1 (2014 consolidated edition)
IMO Resolution A.754 (18) adopted on 4 November 1993 as amended by MSC.61(67) adopted on 5
December 1996
2010 FTP Code, Annex1, part 3 (IMO Resolution MSC.307 (88) adopted on 3 December 2010)
A8706-1 RDIMS #1961446
Print Date and Time: 17-Nov-2023 4:29
| 11/17/2023 4:29:21 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 4 of 5 |
| 11/17/2023 4:29:21 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 5 of 5 |
