Model(s): Roxtec GK Firestop Sealing Kit (GK FS SK) in steel divisions
| Product Design Assessment (PDA) | 20-1990057-PDA | 02-JUN-2020 | 01-JUN-2025 |
| Manufacturing Assessment (MA) | 24-6227546 | 25-JAN-2024 | 08-JAN-2029 |
Roxtec “GK Firestop Sealing Kit” is intended for bundle cables or as a blank fire stop solution in Class A0
to A60 bulkheads and decks for ship or offshore applications.
Roxtec “GK Firestop Sealing kit“ consisting of a fiberglass cloth with built in heat activated intumescent
material to be wrapped around cable bundles and fitted into circular or oval steel pipe sleeves. Folded
back on each side with ends sealed off to create a cold smoke tight seal and secured by metal cable
ties.
Sealing kits for round sleeves:
GK FS SK KIT 89 :
Pipe sleeve outer diameter (Min - Max) :84mm - 89mm
Pipe Sleeve Depth (Min- Max): 105mm - 205mm
GK FS SK KIT 127 :
Pipe sleeve outer diameter (Min - Max) :107mm - 127mm
GK FS SK KIT 140 :
| 02/12/2024 1:53:25 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 1 of 6 |
| Certificate Number: 20-1990057-PDA |
Pipe sleeve outer diameter (Min - Max) :120mm - 140mm
GK FS SK KIT 168 :
Pipe sleeve outer diameter (Min - Max) :138mm - 168mm
GK FS SK KIT 219 :
Pipe sleeve outer diameter (Min - Max) :179mm - 219mm
GK FS SK KIT 244 :
Pipe sleeve outer diameter (Min - Max) :204mm - 244mm
GK FS SK KIT 273 :
Pipe sleeve outer diameter (Min - Max) :233mm - 273mm
Sealing kits for oval sleeves:
GK FS SK KIT 200X150:
Fits sleeve outer circumference (min-max): 531mm - 571mm
GK FS SK KIT 200X170:
Fits sleeve outer circumference (min-max): 554mm - 594mm
GK FS SK KIT 250X170:
Fits sleeve outer circumference (min-max): 654mm - 694mm
Fire rating: A0, A15, A30 and A60 for Bulkheads and Deck
- Unit Certification is not required for this product. If the manufacturer or purchaser request an ABS
| 02/12/2024 1:53:25 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 2 of 6 |
- The penetration system is not designed or tested for applications where water tightness or gas
tightness is required. Accordingly, product should not be installed in bulkheads and decks if water and
gas tightness is a requirement.
3. Maximum cable diameter: 50mm
4. Maximum fill ratio: 68%
Cable/bundle are to be supported on both sides of the pipe sleeve
For use in fire classes A-15 and A-30, sleeves are to be insulated as per A-60 class requirements, and
in addition the division is to be insulated at least 200 mm around the penetration -
Insulation details for A60 Deck according drawings Roxtec No. S1554737
Insulation details for A0 Deck according drawings Roxtec No. S1554738
Insulation details for A60 Bulkhead according drawings Roxtec No. S1554739
Insulation details for A0 Bulkhead according drawings Roxtec No. S1554740
Installation shall be made according to installation instruction DOC-001835 revision E.
12. Not for use in tank boundaries.
a) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
b) All seal type should be installed in accordance with the manufacturers instructions in accordance with
c) Insulation material is to be A60 approved type and properly installed in accordance with ABS
approved drawings. This is to be verfied to the satisfaction of the attending surveyor
d) Fire rated bulkheads or decks for cable penetrations are to be examined as per 4-8-4/29.15 of ABS
Marine Vessels Rules. This is to be verified to the satisfaction of the attending surveyor.
f) Water & Gas tightness of the product has not been tested.
Test Reports A60 Fire Class:
Report No. RS-19/B-255/E, A-class Steel Bulkhead, CTO SA. Poland, Dated 20 August 2019, Revision:
-, Pages: 42
Report No. RS/19/B-256/E, A-class Steel Deck, CTO SA. Poland, Dated 20 August 2019, Revision: -,
Pages: 66
Report No. RS/19/B-225/E A-class Steel Deck, CTO SA. Poland. Dated 01 August 2019, Revision: -,
Pages: 80
Report No. 8P07092 A-class steel deck, SP Technical Research Institute of Sweden, Dated 27
September 2019, Revision: -, Pages: 55
Report No. 8P07094 A-class steel Bulkhead, SP Technical Research Institute of Sweden, Dated 23
September 2019, Revision: -, Pages: 54
| 02/12/2024 1:53:25 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 3 of 6 |
Report No. RS-19/B-355/E A-class Steel bulkhead, CTO SA. Poland, Dated 16 October 2019, Revision:
-, Pages: 64
Report No. DMT-DO-53-112 A-class Steel bulkhead, DMT GmbH Germany, Dated 22 May 2019,
Revision: -, Pages: 51
Test Reports A0 Fire Class:
Report No. PGA11387 A-class steel bulkhead, DBI Danish Institute of Fire and Security Technology,
Dated 08 April 2019, Revision: 0, Pages: 66
Report No. RS-20/B-081/E A-class Steel bulkhead, CTO SA. Poland, Dated 31 March 2019, Revision: -.
Pages: 58
Report No. RS-19-B-423E A-class Steel Bulkhead, CTO SA. Poland., Dated 19 November 2019,
Revision: -. Pages: 30
Report No. PGA11610A A-class steel deck, DBI Danish Institute of Fire and Security Technology, Dated
04 December 2019, Revision: 0, Pages: 76
September 2019, Revision: 0, Pages: 55
September 2019, Revision: 0, Pages: 54
Test Reports Cold Smoke:
Report No. 29092016-01, GK-AWL Cold Smoke Tightness Test, DMT GmbH Germany, Dated 29 June
2016, Revision: -, Pages: 11
Report No. 22032017-01, GK-AWL Cold Smoke Tightness Test, DMT GmbH Germany, Dated 23 March
2017, Revision: -, Pages: 5
Report No. 14122016-01, dated 2016-12-14. GK-AWL Cold Smoke Tightness Test, DMT GmbH
Germany, Dated 14 December 2016, Revision: -, Pages: 5
Drawings:
Drawing No. DOC-001835, Installation instruction, Revision: E, Pages: 4
Drawing No. S1535797 Product drawing, S1535797 Product drawing, Revision: C, Pages: 1
Drawing No. S1554737 Certificate drawing, S1554737 Certificate drawing, Revision: A, Pages: 1
Drawing No. S1554738 Certificate drawing, S1554738 Certificate drawing, Revision: A, Pages: 1
Drawing No. S1554739 Certificate drawing, S1554739 Certificate drawing, Revision: A, Pages: 1
Drawing No. S1554740 Certificate drawing, S1554740 Certificate drawing, Revision: A, Pages: 1
This Product Design Assessment (PDA) Certificate remains valid until 01/Jun/2025 or until the Rules
| 02/12/2024 1:53:25 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 4 of 6 |
2020 Rules for Conditions of Classification, 1-1-4/7.7, 1-1-A3, 1-1-A4, which covers the following:
ABS Rules for Building and Classing Marine Vessels 2020: 4-8-4/21.13, 4-8-4/29.15,
ABS Rules for Building and Classing High Speed Craft 2020: 4-6-3/5.13
ABS Rules for Building and Classing Steel Vessels for Service on Rivers and Intracoastal Waterways
2020: 4-5-3/5.13
2020 Rules for Conditions of Classification - Offshore Units and Structures 1-1-4/9.7, 1-1-A2, 1-1-A3,
which cover the following:
ABS Rules for Building and Classing Mobile Offshore Units 2020: 4-3-3/5.13
ABS Rules for Building and Classing Facilities on Offshore Installations 2020: 3-8/9.13, 4-8/9.13
SOLAS Ch. II-2, Reg. 9.3.1 (2014 consolidated edition)
2010 FTP Code (2012 Edition), Annex1, part 3 (IMO Resolution MSC.307 (88) adopted on 3 December
2010)
A8706-1 RDIMS #1961446
Print Date and Time: 12-Feb-2024 1:53
| 02/12/2024 1:53:25 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 5 of 6 |
| 02/12/2024 1:53:25 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 6 of 6 |
