20-2032853-PDA-DUP-optimized
Model(s): Roxtec RS and RS OMD Series Seals in steel divisions.
Product Design Assessment (PDA) 20-2032853-PDA-DUP 05-JUL-2023 28-SEP-2025
Single cable penetrations in Class A0, A15, A30 and A60 bulkheads and decks for Marine and offshore
applications. Penetrations of watertight and gastight bulkheads and decks up to the specified pressure..
Roxtec sealing system with multidiameter technology: RS-series (steel) consisting of a steel sleeve
welded, bolted (incl. SLA sleeve) or attached through expansion (RS X kit consist of SLX sleeve and RS
seal) to a steel deck or bulkhead. The sleeve is filled with a Roxtec RS or RS OMD type (standard,
Ex/ATEX or EMC version) halogen free rubber seal in sizes 23-150 (23-75 for RS with SLA Sleeve).
Fire Rating: A0, A15, A30 and A60 for Bulkheads and Decks.
Watertight test pressure 6 bar (except bolted versions test pressure at 5 bar).
Gastight test pressure 4 bar (except bolted versions test pressure at 2.5 bar).
Watertight test pressure with SLA sleeve- 4 bar
Gastight test pressure with SLA sleeve-1.5 bar
a) Maximum cable diameter 86 mm (without SLA Sleeve) and 32 mm (with SLA Sleeve).
b) Minimum and Maximum frame sizes tested are 23-125 for RS/ RS OMD and 23-75 for RS with SLA
11/17/2023 4:26:58 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 4
Certificate Number: 20-2032853-PDA-DUP
Sleeve.
c) Not for use in tank boundaries.
d) Tested with Marine Power/ Instrumentation/Control Cables.
e) Insulation material is to be A-60 approved type and installed in accordance with the manufacturer’s
ABS approved installation drawings to the satisfaction of the Surveyor.
f) Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
b) Watertight or fire rated bulkheads or decks for cable penetrations are to be examined and tested as
(Consolidated Edition 2020). This approval of penetrations passing through watertight bulkhead is not to
be construed as a substitute for flag Administration’s approval for the purpose of SOLAS.
a) SP Technical Research Institute of Sweden Test reports:
6P10024- 31-01-2017- Steel Bulkhead Divisions, RS with SLA
8P07092rev 1 – 16-01-2020- IMO test of pipe penetration seals in A60 steel deck, RS with SLA
b) Danish Institute of Fire and Security Technology test reports
PGA 10800A Dated 26-05-2016-Steel Deck Divisions, RS Seals
PGA10871A dated 31-10-2016-Steel Deck Divisions, RS Seals
PGA10870A dated 22-12-2011-01-11-2016- Steel Bulkhead Divisions, RS with SLA
PGA10652 dated 15-06-2015-Steel Bulkhead divisions, RS Seals
PGA10723A dated 15-12-2015- Stell Deck Divisions, RS Seals
c) Centrum Techniki Okretowej SA Test reports
RS-17/B-396/E, dated 31-10-2017, Steel Bulkhead Divisions, RS Seals
RS-18/B-022/E dated 29-01-2018, Steel Bulkhead Divisions, RS Seals
RS-18/B-484/E dated 10-12-2018, Steel Deck Divisions, RS Seals
RS-18/B-023/E dated 29-01-2018, Steel Deck Divisions, RS Seals
11/17/2023 4:26:58 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 4
RS-20/B-017/E dated 23-01-2020, Steel Bulkhead Divisions, RS Seals
RS-20/B-191/E dated 05-06-2020, Steel Bulkhead Divisions, RS Seals
d) Pressure test reports
DNV40007647-1, DNV Third Party Inspection Report, Dated 13 December 2011.
MLM010238, DNV Third Party Inspection Report, Dated 30 August 2001.
MLM020401, DNV Third Party Inspection Report, Dated 25 March 2002.
MLM030473-1 (RS X), DNV Third Party Inspection Report, Dated 27 January 2003.
N141EX8Z Rev 2, DNV Third Party Inspection Report, Dated 10 August 2017.
e)Drawings
1)S1558181 rev A for RS/RS OMD with Cable A-60 Class Steel BLKHD/DECK
2)S1558184 rev A for RS/RS OMD with Cable A-0 Class Steel BLKHD/DECK
3)S1558203 rev A for RS-Seal with SLA Sleeve and Cable A-60 Class Steel DECK/BLKHD
4)1558204 rev A for RS-Seal with SLA Sleeve and Cable A-0 Class Steel DECK/BLKHD
This Product Design Assessment (PDA) Certificate remains valid until 28/Sep/2025 or until the Rules
2020 ABS Rules for Building and Classing Marine Vessels: 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-8-4/21.13,
4-8-4/29.15.
2020 ABS Rules for Conditions of Classification - Offshore Units and Structures 1-1-4/9.7, 1-1-A2,
1-1-A3.
2020 ABS Rules for Building and Classing Mobile Offshore Units 2020: 4-3-3/5.13.
SOLAS Consolidated Edition 2020, Regulation 9.3.1
2010 FTP Code, Annex1, part 3 (2012 Edition)
11/17/2023 4:26:58 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 4
This PDA conforms to Transport of Canada requirements.as per Transport Canada Policy Letter
A8706-1 RDIMS#1961446
Print Date and Time: 17-Nov-2023 4:26
11/17/2023 4:26:58 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 4
