20-HS1948304-PDA-optimized
Model(s): RS PPS and RS PPS/S series (steel divisions)
Product Design Assessment (PDA) 20-HS1948304-PDA 30-JAN-2020 29-JAN-2025
Single plastic pipe penetrations in Class A0, A15, A30, and A60 bulkheads and decks for ships and
offshore application. Penetrations of watertight and gas tight bulkheads and decks up to the specified
pressure.
Roxtec plastic pipe sealing system with multi diameter technology.
RS PPS 31-450 - Consisting of a steel sleeve, bolted or welded to a steel section. The sleeve is fitted at
both ends with Roxtec RS seals (standard or EMC versions) including intumescent material in between.
RS PPS/S 31-150 - Consisting of a steel sleeve, bolted, welded or SLX-type sleeve attached through
expansion, on to the steel sections. The sleeve is fitted with one single RS PPS/S seal with integrated
intumescent material. Minimum thickness for steel sleeve is 1.5 mm.
Fire Rating: A0, A15, A30, and A60 for bulkheads and decks.
RS PPS pressure tested for 6 bar watertightness and 4 bar gastightness.
RS PPS/S pressure tested for 6 bar watertightness and 3 bar gastightness.
A60 Steel bulkhead division (for watertight bulkhead division for Passenger Ships and Special Purpose
Ships as per SOLAS II-1/13.2.3).
RS PPS/S 43-150. The transits are tested for watertightness with 2 bar test pressure for 60 minutes after
02/12/2024 9:08:55 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 4
Certificate Number: 20-HS1948304-PDA
an A60 fire test.
1) Maximum plastic pipe size 355 mm diameter.
2) Not for use in tank boundaries.
  1. Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
  1. All seal types should be installed in accordance with manufacturers ABS approved installation
drawings.
  1. Insulation material is to be A60 approved type and installed in accordance with manufacturers ABS
    approved installation drawings to the Surveyors satisfaction.
  2. Watertight bulkheads or decks for pipe penetrations are to be tested as per ABS Marine Vessels
Rules 3-7-1/Table1.
  1. The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
  1. This approval of penetrations passing through watertight bulkhead is not to be construed as a
    substitute for flag Administration’s approval for the purpose of SOLAS (Consolidated Edition 2014), as
amended.
  1. All seal types should be installed in accordance with manufacturer’s ABS approved installation
drawings.
Certificate Drawings List
  1. Drawing No. S1550955, Rev. A - RS PPS with Pipes - A60 Class Steel Deck/Bulkhead
  2. Drawing No. S1550956, Rev. A - RS PPS with Pipes - A0 Class Steel Deck/Bulkhead
  3. Drawing No. S1550958, Rev. A - RS PPS/S with Pipes - A60 Class Steel Deck/Bulkhead
  4. Drawing No. S1550959, Rev. A - RS PPS/S with Pipes - A0 Class Steel Deck/Bulkhead
  5. Drawing No. S1550982, Rev. A - RS PPS/S Plastic Pipe - A-Class Watertight Steel Divisions
Fire Test Report Report Date Laboratory
P502921 2005-12-01 SP Technical Research Institute of Sweden
P701755 2007-06-12 SP Technical Research Institute of Sweden
P902394 2009-05-25 SP Technical Research Institute of Sweden
6P10024 2017-03-07 SP Technical Research Institute of Sweden
8P04040 2018-08-13 SP Technical Research Institute of Sweden
8P07094 2020-01-16 SP Technical Research Institute of Sweden
02/12/2024 9:08:55 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 4
RS-18/B-023/E 2018-01-29 CTO Centrum Techniki Okretowej S.A. Poland
RS-18/B-484/E 2018-12-10 CTO Centrum Techniki Okretowej S.A. Poland
RS-18/B-291/E 2018-08-20 CTO Centrum Techniki Okretowej S.A. Poland
RS-18/B-292/E 2018-09-13 CTO Centrum Techniki Okretowej S.A. Poland
RS-18/B-293/E 2018-09-13 CTO Centrum Techniki Okretowej S.A. Poland
RS-19/B-256/E 2019-08-20 CTO Centrum Techniki Okretowej S.A. Poland
RS-19/B-356/E 2019-10-18 CTO Centrum Techniki Okretowej S.A. Poland
RS-19/B-424/E 2019-11-27 CTO Centrum Techniki Okretowej S.A. Poland
PGA10025 2011-12-22 DBI - The Danish Institute of Fire and Security, Denmark
PGA10141 2012-07-10 DBI - The Danish Institute of Fire and Security, Denmark
PGA11302A 2019-01-16 DBI - The Danish Institute of Fire and Security, Denmark
N141S7E5 2019-03-10 Roxtec International AB, Sweden
N141UBRY 2019-08-07 Roxtec International AB, Sweden
N141NBR5 2018-11-05 Roxtec International AB, Sweden
N141RA6Z 2019-01-24 Roxtec International AB, Sweden
N141SGZW 2019-03-10 Roxtec International AB, Sweden
N141SMF7 2019-03-15 Roxtec International AB, Sweden
N141SMF8 2019-03-15 Roxtec International AB, Sweden
N141SRGA 2019-03-15 Roxtec International AB, Sweden
Water and Gas Tightness Test - DNV-GL Report Report Date Laboratory
MLM060511 2006-02-28 Roxtec International AB, Sweden
MLM070656 2007-04-18 Roxtec International AB, Sweden
SKM-04-4088 2004-06-16 Roxtec International AB, Sweden
This Product Design Assessment (PDA) Certificate remains valid until 29/Jan/2025 or until the Rules
2020 ABS Rules for Building and Classing Marine Vessels 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-6-2/9.7.1 & 2,
4-6-3/7.11
02/12/2024 9:08:55 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 4
2020 ABS Rules for Building and Classing Mobile Offshore Units 1-1-4/9.7, 1-1-A2, 1-1-A3, 4-2-1/11.15,
4-2-2/7.7.4
SOLAS (2014 Consolidated Edition ) Ch. II-2, Reg. 9.3.1, Ch. II-1, Part B-2, Reg. 13.2.3;
2010 Resolution MSC.307(88), 2010 FTP Code (2012 Edition), Annex 1 Part 3; IMO Resolution A.754
(18).
PDA conforms to Transport of Canada - Marine Machinery Regulations (SOR/90-264), 2019.
Print Date and Time: 12-Feb-2024 9:08
02/12/2024 9:08:55 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 4
